POV-Ray : Newsgroups : povray.advanced-users : Putting objects into an array, then. . . Server Time
20 Dec 2025 23:21:00 EST (-0500)
  Putting objects into an array, then. . . (Message 1 to 2 of 2)
Subject: Putting objects into an array, then. . .
Date: 21 Sep 2001 22:57:55
Message: <3babfe33$1@news.povray.org>
Hi there,
Is it possible to create a loop such that I create a object (let's say a
sphere), then place that object into a declared array?  After which I can
manipulate an object depending on its place in the array?
Thanks for your help!
Subject: Re: Putting objects into an array, then. . .
Date: 22 Sep 2001 00:19:41
Message: <3BAC127B.B2185357@pacbell.net>
"Arie L. Stavchansky" wrote:
> Hi there,
You can describe the location of an object by storing it's coordinates
in an array and then use the data in the array with a while loop to
locate the objects. A simple example locates 5 spheres using an array -
#declare Dnum = 5;
#declare Data = array [Dnum][2]
  { 0, 0},
  {-1,-1},
  { 1, 1},
  {-1, 1},
  { 1,-1},
#declare Unit = sphere { 0,1 }
#declare Five_Spheres =
    union {
      #declare I=0;
       #while (I < Dnum)
        object { Unit
            translate <Data[I][0],Data[I][1],0>
             pigment{rgb 1}
         #declare I=I+1;
camera{location<0,0,-7>look_at 0}
light_source{<-10,10,-20>rgb 1}
object { Five_Spheres }
Ken Tyler
