POV-Ray : Newsgroups : povray.advanced-users : Output File Format Server Time
18 Jun 2026 01:25:06 EDT (-0400)
  Output File Format (Message 1 to 4 of 4)
Subject: Output File Format
Date: 22 Jun 2001 08:59:50
Message: <3b334146$2@news.povray.org>
I know this is a newbie question, but I can't find it in the documentation,
and my mind is not what it once was.  How do I get pov to change the format
of the output file in Pov-ray v3.1 for Windows? Thanks.
John
Subject: Re: Output File Format
Date: 22 Jun 2001 09:12:11
Message: <3b33442a@news.povray.org>
In povray.advanced-users John Albarelli <johna@smithandmahoney.com> wrote:
: I know this is a newbie question, but I can't find it in the documentation,
: and my mind is not what it once was.  How do I get pov to change the format
: of the output file in Pov-ray v3.1 for Windows? Thanks.
  Don't want to sound sarcastic, but do you really and honestly think this
is a question for povray.ADVANCED-users or for povray.BINARIES.*?
  Besides, cross-posting is unnecessary and deprecable.
  Anyways, the answer is to put a proper +f command (or the longer version
of it, which I don't remember) in the master povray.ini file (you can edit
it through a menu option; I think it was 'tools/edit master povray.ini' or
something). Read the documentation for the proper syntax of "+f".
Date: 5 Jul 2001 16:02:49
Message: <86n16ji1p3.fsf@nautilus.bursik.net>
"John Albarelli" <joh### [at] smithandmahoneycom> writes:
> documentation, and my mind is not what it once was.  How do I get pov
> to change the format of the output file in Pov-ray v3.1 for Windows?
ALT-C or Render => Edit Settings/Render and there add in the
"Section": Command line Option the prefered Format
From the Help Section "File Output Options":
+FC     Compressed Targa-24 format (RLE, run length encoded)
+FN     New PNG (portable network graphics) format
+FP     Unix PPM format
+FS     System-specific such as Mac Pict or Windows BMP
+FT     Uncompressed Targa-24 format
Hth
al ;-)
Date: 28 Jul 2001 18:30:50
Message: <3B633D02.A1F3999C@libero.it>
When U render by POV U can save Your rendered image in different formats
TGA, BMP or PNG in a Directory U can chose.
Try to edit the Povray.ini file from:
"Tools"--> "Edit master POVRAY.INI"
U can add a raw like:
Output_File_Type=T
if U want a TGA ... or =S insted of T if U want a BMP or =N if You need a
PNG output image
and also the raw :
Output_File_Name=C:\images\
tells POVRay where to save the rendered image
at the end of the ini file there are also the output directory and the
library paths where pov try to search for the files "he" needs when it start
to render.
BTW: the ini file is read only when pov start!!!!
Renzo Del Fabbro
e-mail: ren### [at] liberoit
----------------------------------------------------eof
