POV-Ray : Newsgroups : povray.advanced-users : How to remove wood uniformity? Server Time
30 Sep 2024 02:15:08 EDT (-0400)
  How to remove wood uniformity? (Message 1 to 6 of 6)
Subject: How to remove wood uniformity?
Date: 19 May 2001 05:59:59
Message: <3b06441f@news.povray.org>
A wood floor. All the planks use the same declared colour map. How do
I vary the apparent colour of each plank - lighter or darker? I've
tried adding a random component to diffuse and ambient, and also a
second texture layer. They both work but is there a better or easier
way?
Alf
http://www.peake42.freeserve.co.uk/
http://ourworld.compuserve.com/homepages/Alf_Peake/
gw3### [at] thersgbnet
Subject: Re: How to remove wood uniformity?
Date: 19 May 2001 08:47:01
Message: <Xns90A696637A895seed7@povray.org>
in news:3b06441f@news.povray.org Alf Peake wrote:
> I've
> way?
 Easiest I to me is adding a second layer, but not on top of the wood
but as a base. It's the way we print wood-designs in our factory.
 Start with a base colour, on top of that the wood pattern, in one or
more layers, with some transparency. Now all you have to do is vary the
colour of the base to get a differnt wood.
 Makes me think, it could be made closer to the printing method. Make a
wood design in several layers. Eatch layer only uses gray-scale. Colour
is given to a layer by a multiplication factor. All that would be
needed to make another colour-way is changing the colour of the factor.
Ingo
Date: 19 May 2001 12:11:38
Message: <3B069C54.3686E46E@erols.com>
Declare a different colour map for each plank.  Use the rand() function
to slightly vary the colors.
John
ICQ: 46085459
Date: 20 May 2001 06:07:04
Message: <3b079748@news.povray.org>
"ingo" <ing### [at] homenl> wrote in message
news:Xns### [at] povrayorg...
> > I've
easier
> > way?
wood
I hadn't thought about a base layer. Much simpler than what I've tried
so far. Thanks, I'll have a play with that.
Alf
Date: 20 May 2001 06:07:05
Message: <3b079749@news.povray.org>
"John VanSickle" <van### [at] erolscom> wrote in message
news:3B069C54.3686E46E@erols.com...
do
function
Yes, nice and simple, I had thought about it, but as the map had
around 100 entries I thought it was probably overkill. I used Qbasic
to generate the map so there would be no problem making variations on
a theme. Thanks for the input.
I'll try Ingo's suggestion first.
Alf
Date: 21 May 2001 05:35:34
Message: <3b08e166@news.povray.org>
Alf Peake wrote in message <3b06441f@news.povray.org>...
> way?
If you are using megapov you can try my method for real random planks. Just look
at my old message (image was sended to p.b.i)
From: "Wlodzimierz ABX Skiba" <abx### [at] abxartpl>
Newsgroups: povray.text.tutorials
Subject: no-repeat in mosaic
Date: Thu, 22 Mar 2001 10:52:51 +0100
Message-ID: <3ab9cc26@news.povray.org>
it uses noise3d to distribute planks
#macro Sig(A,B,X)_(A,B)_(B,X)_(X,A)#end#macro _(A,B)cylinder{<A.x,A.y,3>,<B.u,
B.v,3>.1,9}#end global_settings{max_trace_level 9}light_source{0 1}camera{up y
*4right-3*x}blob{_(<3,1>,<1,-5>)_(<2,-2>,<4,-2>)Sig(x,<-1,1.5>,<1,3>)_(z-1,z-4
)pigment{rgb 1}}box{-3 3pigment{rgb 0}finish{reflection 1}hollow} // POV-Ray31
