POV-Ray : Newsgroups : povray.advanced-users : Limited Fog?? Server Time
16 Mar 2026 07:38:54 EDT (-0400)
  Limited Fog?? (Message 1 to 4 of 4)
Subject: Limited Fog??
Date: 29 Apr 2001 14:25:06
Message: <3aec5c82@news.povray.org>
How can I limit fog to a certain area or volume without visibility of the
limiting shape?
e.g. I like to fill up one single pit with ground-fog without the infinite
fog area around that pit.
Thanks, Wulf
Subject: Re: Limited Fog??
Date: 29 Apr 2001 15:15:18
Message: <chrishuff-00D8F7.14124829042001@news.povray.org>
> limiting shape?
You would be better off with scattering media for this. It is much more
flexible, and is usually used confined to a certain area.
However, you will probably want to use MegaPOV for its sampling methods
2 and 3, otherwise it will take a long time to render if you want smooth
results.
Christopher James Huff
Date: 30 Apr 2001 00:38:44
Message: <3AECE928.35D35680@faricy.net>
> limiting shape?
Make a big solid shape and add the fade_distance and fade_power keywords (and
hollow if the camera is inside it, I think...).
Date: 30 Apr 2001 15:47:25
Message: <3aedc14d@news.povray.org>
> fade_power keywords (and hollow if the camera is
Fog and fading are two entirely different things as you can se if you render
the code
below (requires MegaPov).
(It simulates interior fog by using an inverted object.)
You could say that if fog is like transmit, fade_color is like filter.
#default {finish {ambient 1 diffuse 0}}
box {<-3,0,7>, <3,-2,8> pigment {color <1,1,1>}}
box {<-3,0,7>, <3,+1,8> pigment {color <1,0,0>}}
box {<-3,1,7>, <3,+2,8> pigment {color <0,1,0>}}
difference {
   sphere {5*z-x, 1 inverse}
   sphere {0, 0.00001}
   pigment {color rgbt 1}
fog {
   fog_type 1
   distance 1
   color rgb <0.0,0.0,1.0>
sphere {
   5*z+x, 1
   pigment {color rgbf 1}
   interior {fade_power 1 fade_distance 0.6 fade_color <0,0,1>}
   hollow
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated March 29)
/ Also visit http://www.povrayusers.org
