POV-Ray : Newsgroups : povray.advanced-users : Making objects into heightfields Server Time
23 Feb 2025 15:43:36 EST (-0500)
  Making objects into heightfields (Message 1 to 9 of 9)
Subject: Making objects into heightfields
Date: 28 Feb 2001 17:35:06
Message: <3a9d7d1a@news.povray.org>
Hello all.  I just wanted your feedback on something.  To my understanding,
you can't use objects like triangle meshes or bicubic patch models in CSG
differences or intersections (correct me if I'm wrong.. I know that in later
releases of the program there will be solid triangle meshes that will be
able to do this).  However, you can use heightfields (again... correct me).
Would it be possible to render an image of a complex object in a gradient z
of white and black, then convert the rendered image into a heightfield that
could be used any old way that you wanted?  In short, could you make a
reasonable representation of an already created object using a heightfield?
You could even use your old textures if you used your old image as an
image_map on the new heightfield (make the background color around the
object GIF transparent, then map it onto the heightfield).  You could make a
whole object by then moving the camera behind the black and white object and
making a second heightfield.  Of course it would be better if you used an
ortho perspective, as the camera perspective would throw off your finished
heightfield model.  I don't know if all of this makes sense, or if it would
even be useful to anyone, but the idea popped into my head and I was
wondering if it would actually work.  Basically it amounts to converting any
POV object (even CSG) into two images that would become a heightfield.  Just
curious.  Thanks.
Stephen Bell
http://students.oc.edu/stephen.bell
Subject: Re: Making objects into heightfields
Date: 28 Feb 2001 17:54:50
Message: <chrishuff-0D9744.17530928022001@news.povray.org>
In article <3a9d7d1a@news.povray.org>, "Stephen Bell"
> gradient z of white and black, then convert the rendered image into a
> heightfield that could be used any old way that you wanted?  In
> short, could you make a reasonable representation of an already
It is possible, with some restrictions. For example, you obviously will
only get one side of the object, and will miss parts of complex objects
even if you use two height fields back-to-back. You can get the depth
image in many ways...use a black-white gradient texture, make everything
white and use a black fog, or just render it in MegaPOV and use the
"depth" post_process to retrieve the depth information. Also, the
resolution of the object will suffer, and there will probably be some
artifacts...
If mesh objects are fine, you could use MegaPOV, which *can* use meshes
in difference and intersection.
Christopher James Huff
Date: 1 Mar 2001 06:05:22
Message: <3a9e2cf2@news.povray.org>
Chris Huff <chr### [at] maccom> wrote:
: Also, the resolution of the object will suffer
  If this is a problem, then outputting to a 48-bit png can help a lot
(you get basically 65536 depth values instead of the usual 256).
char*i="b[7FK@`3NB6>B:b3O6>:B:b3O6><`3:;8:6f733:>::b?7B>:>^B>C73;S1";
main(_,c,m){for(m=32;c=*i++-49;c&m?puts(""):m)for(_=(
c/4)&7;putchar(m),_--?m:(_=(1<<(c&3))-1,(m^=3)&3););}    /*- Warp -*/
Date: 1 Mar 2001 06:25:00
Message: <chrishuff-76F48D.06231901032001@news.povray.org>
In article <3a9e2cf2@news.povray.org>, Warp <war### [at] tagpovrayorg>
Why not a TGA or ordinary 24-bit PNG with hf_gray_16 enabled?
There should be a high-precision grayscale format somewhere out
there...it'd be nice to store large height fields without the wasted
space.
But anyway, there may still be problems with resolution...areas with a
high slope will get fewer triangles, and you may have trouble getting
them smooth. And holes inside the object or through the sides will not
work correctly. An intersection of several height fields may help some
of this, but will get slower and more memory consuming...the best option
is to simply convert it to a mesh and use MegaPOV.
Date: 1 Mar 2001 06:40:36
Message: <3A9E3534.E9A9254F@gmx.de>
> space.
What's wrong about 16 bit greyscale png?
Just use hf_gray_16 and +fn16.
Date: 1 Mar 2001 07:59:04
Message: <chrishuff-DE2D77.07572301032001@news.povray.org>
In article <3A9E3534.E9A9254F@gmx.de>, Christoph Hormann
I'm thinking more of 32-bit (single-precision float). 16-bit gives you
65536 levels, though, which should be enough for practically
anything...if you have a 5000 foot tall mountain, the smallest change in
height you can represent will be about an inch, and you could use a
"local" height field if you need more precision. (unless I've made an
error in my calculations...)
Date: 1 Mar 2001 08:17:36
Message: <3A9E4BF1.6E9AA2DE@gmx.de>
Sounds correct,
there is a 32 bit floating point format supported by HF-Lab/gforge, but i
don't know how universal it is.
Date: 5 Mar 2001 05:37:37
Message: <3aa36c70@news.povray.org>
: Why not a TGA or ordinary 24-bit PNG with hf_gray_16 enabled?
  Because if you ever want to modify the created image with a painting
program, it would be quite difficult?
  AFAIK the 24-bit hf_gray_16 is more like a hack.
Date: 5 Mar 2001 09:17:23
Message: <slrn9a77vk.4td.ron.parker@fwi.com>
If you use global_settings{hf_gray_16} and put +fn16 on the command line,
POV will output a 16-bit grayscale PNG, which is slightly smaller than the
equivalent 48-bit RGB or 64-bit RGBA file.  3.5 will assume that you wanted
a 16-bit grayscale PNG if you specify hf_gray_16, even if you had +fn8 or
a bare +fn on the command line.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
