POV-Ray : Newsgroups : povray.advanced-users : Random number generator needed ! Server Time
18 May 2026 07:53:49 EDT (-0400)
  Random number generator needed ! (Message 22 to 31 of 41)
Subject: Re: Random number generator needed !
Date: 21 Feb 2001 12:40:52
Message: <3a93fda4@news.povray.org>
Rune <run### [at] inamecom> wrote:
: Basically it will never be of any use to use rand( seed( VAL ) ) no matter
: what "VAL" is, because it won't add any randomness at all.
  What he wanted was that a certain pair of values is converted to some
value (always the same value). Each time the function is called with a
certain pair of values, the same result is returned. This value should
be "random" in the way that there's no (easily) visible connection between
the input values and the result.
  For this rand(seed(VAL)) works quite well. It returns a value from 0 to 1
which is seemingly not related to VAL.
char*i="b[7FK@`3NB6>B:b3O6>:B:b3O6><`3:;8:6f733:>::b?7B>:>^B>C73;S1";
main(_,c,m){for(m=32;c=*i++-49;c&m?puts(""):m)for(_=(
c/4)&7;putchar(m),_--?m:(_=(1<<(c&3))-1,(m^=3)&3););}    /*- Warp -*/
Date: 21 Feb 2001 13:11:43
Message: <3a9404df@news.povray.org>
Warp wrote in message <3a93fda4@news.povray.org>...
but this works fine
I've checked and compared results for independent running and for independent
loops of one running
it is little slow but as I said - it works
// start of file
#declare Generator=seed(0);
#declare RandTable=array[1][3]
#macro Extend(Table,I1,I2,R)
  #local Counter=0;
  #local End=no;
  #while (!End)
    #ifndef (Table[Counter][0])
      #local End=yes;
    #else
      #local Counter=Counter+1;
  #local NewTable=array[Counter+2][3]
  #local NewTable[Counter][0]=I1;
  #local NewTable[Counter][1]=I2;
  #local NewTable[Counter][2]=R;
  #while (Counter>0)
    #local Counter=Counter-1;
    #local NewTable[Counter][0]=Table[Counter][0];
    #local NewTable[Counter][1]=Table[Counter][1];
    #local NewTable[Counter][2]=Table[Counter][2];
  NewTable
#macro RandForRunesParticles(I1,I2)
  #local Counter=0;
  #local Found=no;
  #local End=no;
  #while (!End)
    #ifndef (RandTable[Counter][0])
      #local End=yes;
    #else
      #if ((RandTable[Counter][0]=I1)&(RandTable[Counter][1]=I2))
        #local Found=yes;
        #local End=yes;
  #if (Found)
    #local R=RandTable[Counter-1][2];
  #else
    #local R=rand(Generator);
    #declare RandTable=Extend(RandTable,I1,I2,R)
  R
// end of file
ABX
Date: 21 Feb 2001 13:13:50
Message: <3a94055e@news.povray.org>
Warp wrote in message <3a93e9f3@news.povray.org>...
>Wlodzimierz ABX Skiba <abx### [at] abxartpl> wrote:
>: multiplication has symetry
>: concatenation hasn't
>  Your solution just multiplies I1 with the smallest multiple of 10 that
>is larger or equal to I2 and then adds I2 to the result.
>  This is effectively the same as I1*I2+I2, the only difference being that
>instead of multiplying with a the smallest multiple of 10 which is larger
>or equal to I2, we are multplying with the smallest number which is larger
>or equal to I2, which is, of course, I2 itself.
>  Now, I1*I2+I2 = (I1+1)*I2, and by all practical means this probably will
>not give a too different result than just I1*I2.
>  That's why I think that I1*I2 will probably give an equally good result
>with less overhead.
there was big misunderstand in my thinking
I thought that
#declare A=seed(0);
#declare B=seed(0);
cause A=B
but I've checked it's not true
and that's why this not work as expected
ABX
Date: 21 Feb 2001 13:48:01
Message: <3a940d61@news.povray.org>
> "Geoff Wedig" wrote:
>> > wouldn't it work to make a relative small array, and then
>> > use averages of different numbers from the array?
>> Those wouldn't be equally distributed though.  The mean of
>> three uniformly distributed numbers is not uniformly
>> distributed.
> Yes, I realised that...
> Maybe instead of averaging I can just add together and then use mod() on the
> result. It may cause a kind of repeats in the pattern, but it should be
> possible to reduce it to a minimum.
How big are your numbers?  You could use the nth value off the stream seeded
with m, if you're assured they're not too big (expensive, though)
Another possibility is using some sort of function to hash to a single
value.  a*n1 + b*n2 which you then use as your seed, and get the random
number that way.
Geoff
Date: 21 Feb 2001 15:20:16
Message: <3a942300@news.povray.org>
"Warp" wrote:
> : no matter what "VAL" is, because it won't add any randomness at all.
>   What he wanted
Who?
> was that a certain pair of values is converted to some value (always
> the same value). Each time the function is called with a certain pair
> of values, the same result is returned. This value should be "random"
> in the way that there's no (easily) visible connection between the
Yes, that's what I wanted.
> 0 to 1 which is seemingly not related to VAL.
Yes if wanted just a single random value - but I need dozens of them!
Not only should the random number have no visible connection to VAL. It
should also have no visible connection to the other random numbers. I didn't
explicitly say that, as I thought it was needless to say.
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated January 28)
/ Also visit http://www.povrayusers.org
Date: 21 Feb 2001 21:28:59
Message: <388.452T547T12023756PeterC@nym.alias.net>
If I read your posting correctly, you need what is
called a "hash function".  Try a web search on "one
way hash".  You will most likely find C code or C++ code
within ten minutes or less of searching.  Most hash functions
seem to operate on integers and use bit shifts so you'de need
to write extra macros to emulate an integer bit shift, since
pov uses floats for numbers.
Pete
Date: 22 Feb 2001 05:35:02
Message: <3a94eb56@news.povray.org>
: Yes if wanted just a single random value - but I need dozens of them!
  Now I don't understand.
  You want a macro so that you give it two values and it returns a random
value corresponding to those input values. That is, if you call MyRand(2,5)
it would return something seemingly not related to 2 and 5, like 0.27642.
Is this correct?
  What I don't understand is how it can return several values. Do you mean
that if you call it again with MyRand(2,5) it should return a different
value? What's the difference with regular rand() then?
: Not only should the random number have no visible connection to VAL. It
: should also have no visible connection to the other random numbers.
  What other random numbers?
Date: 22 Feb 2001 08:03:39
Message: <3a950e2a@news.povray.org>
Ok, so you want a random stream created based on two numbers, but one that
doesn't show obvious connection to the strems based on any other two
numbers.
In other words, you can't just use something like:
#macro MyRand(v1,v2)
  seed(v1*19873+v2)
because while it gives a seed value for each pair, and you've got a stream,
it is a stream which is not random when compared to a stream with two other
inputs?  Ie, you need multiple random streams that are also random with
regards to each other.
Is that correct?
Geoff
Date: 22 Feb 2001 11:45:41
Message: <MPG.14ff60ef8ab352fd98969c@news.povray.org>
In article <3a94eb56@news.povray.org>, war### [at] tagpovrayorg says...
> value?
No, if I understand Rune correctly, he means if you call it several times
with different, but somehow linked to each other, pairs of values, the
resulting "random" values should NOT have a visible link to each other.
example:
#declare R1 = random(1,5);
#declare R2 = random(2,6);
#declare R3 = random(3,7);
#declare R4 = random(4,8);
#declare R5 = random(5,9);
#declare RT = random(1,2);
now the resuling values Rn (n=1...5) should not have a visible link to
each other (although te input values are obviously linked) and RT = R1.
Lutz-Peter
Date: 22 Feb 2001 17:24:07
Message: <3a959187@news.povray.org>
> times with different, but somehow linked to each other, pairs of
> values, the resulting "random" values should NOT have a visible
> link to each other.
Exactly.
Rune
