POV-Ray : Newsgroups : povray.advanced-users : Question about photons Server Time
15 Jun 2026 11:17:39 EDT (-0400)
  Question about photons (Message 1 to 10 of 11)
Subject: Question about photons
Date: 4 Feb 2001 08:30:50
Message: <3a7d598a@news.povray.org>
well, does the number of photons affect the rendertime ???
I mean, I know it takes longer to parse, but:
If I increase the number of photons, will the rendering also take longer, or
are the photons just a kind of "pigment" (excuse this word), that is mapped
onto the surface, and is handled like a textur ???
PS: My current scene will be done in about 10days ... anybody out there, who
wants to do this on his puter ??? (I only used some photons,area-lights,
dispersion, focal blur and variable reflection ... just a simple scene with
4 objects)
Jan Walzer
Subject: Re: Question about photons
Date: 4 Feb 2001 09:58:16
Message: <3a7d6e08$1@news.povray.org>
In article <3a7d598a@news.povray.org> , "Jan Walzer" <jan### [at] lzernet> wrote:
Yes, they will.
> 4 objects)
Of course it depends on your computer and image size.  If it isn't a 486
rendering 1024*768 it should not take that long.  You may want to tune your
settings and the scene should render is at most a few hours on any Pentium
class system.
    Thorsten
PS: This question better fits in povray.unofficial.patches because photons
are not an official feature...
Date: 4 Feb 2001 10:39:45
Message: <3a7d77c1@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> schrieb im Newsbeitrag
news:3a7d6e08$1@news.povray.org...
> Yes, they will.
Interesting .... didn't know that ...
who
with
> > 4 objects)
your
> class system.
It's a PII-392MHz ... The Output will be in 1024x768
I'll post the scene to pov.text.sc-f
I rendered it with "+SP16 +EP16" to get approximate the rendering time ...
This first pass took about 1 hour, so the final pass will take 16x16 times
as long
(256h) ~10days ... This approx. should be quite ok because I use no AA
(focal blur is on)
To have a smooth image in the far parts I need that much blur-samples and if
I lower the disp_nelems, the glass will get a redish touch ...
So I don't know where to tweak this anymore ...
Date: 5 Feb 2001 11:48:52
Message: <3A7ED973.D8A850EF@gmx.net>
I have tried several things and the result/suggestions are below. But glass (=
many reflections/refractions), photons and folcal blur is a combination that just
will take some time to render.
Suggestions:
- use 'adc_bailout 1/16' in your global_settings
- use '+MB0' switch to turn on boundings
- you probably want to use 'ignore_photons' in your glass object; this will not
speed up the rendering much, but it is suggested in the docs
- focal blut makes your scene rendering about 10 times slower. have you tried
using the focal blur post processing filter? Though I don't know if it can handle
this scene correctly. But it is certainely worth a try
- are the area_lights really neccessary? Have you tried just to put point_lights
and see how much is the difference?
- you might try to group your bubbles according to their location in the glass
sphere and union them together in bounding boxes. I don't know if that will
really result in a speeding up tough.
BTW: I'm just rendering a julia fractal of glass lit by colored spotlights... it
takes a little time for rendering as well.
Micha Riser       email address: mri### [at] gmxnet
http://www.povworld.de/   The World of POV-Ray!
Date: 6 Feb 2001 08:22:53
Message: <3a7ffaad@news.povray.org>
Jan Walzer <jan### [at] lzernet> wrote:
: If I increase the number of photons, will the rendering also take longer, or
: are the photons just a kind of "pigment" (excuse this word), that is mapped
: onto the surface, and is handled like a textur ???
  If you use a more complex pigment instead of a simpler one, the rendering
time gets longer.
  Why photons should be an exception?
char*i="b[7FK@`3NB6>B:b3O6>:B:b3O6><`3:;8:6f733:>::b?7B>:>^B>C73;S1";
main(_,c,m){for(m=32;c=*i++-49;c&m?puts(""):m)for(_=(
c/4)&7;putchar(m),_--?m:(_=(1<<(c&3))-1,(m^=3)&3););}    /*- Warp -*/
Date: 6 Feb 2001 11:23:47
Message: <3a802513$1@news.povray.org>
"Micha Riser" <mri### [at] gmxnet> schrieb im Newsbeitrag
news:3A7ED973.D8A850EF@gmx.net...
glass (=
that just
> Suggestions:
   ^^^ worth a try ...
There is only the main object, and I don't think the single bubbles in the
glass will get bounded extra, will they ???
If they will, than it is surely worth a try, but I don't like to stop it
now, because I'm at line 184 after 2d4h41m.
will not
I want them all ! (also inner refraction and reflection)
tried
handle
I know, that it can't handle this scene, because it "only" works with the
alpha-buffer of the image ...
The things, seen in the sphere would look like an pigment on the sphere...
point_lights
Sure ... I limited them to 2x2 I think ...
glass
will
Group them ??? they're random ... I don't want to raise the parsetime by
doing an cluster-analasys in POV ;-)
spotlights... it
We want to see it then ... *g*
PS: I'm worried about something other ... I got a paper in my Snailmail,
that the electricity
    will be down at 8th.Feb. ... The pic won't have finished till then ...
    Does the "+C"-Switch work together with "+SPxx" ???
    Does it work, when I have startet the original pic with "+SPxx"  ?
    I hope ...
Jan Walzer
Date: 6 Feb 2001 17:51:24
Message: <3A807FEA.D735E0B5@gmx.net>
well, I don't know exactly why, but it gave with me a speeding up of about 10%
> glass
> will
I'll try it out and see if renders faster.
>     I hope ...
It should work fine. Just don't use +SPxx when you continue rendering. What I
don't understand is why you used SPxx at all... this is for preview only, there
is no reason in using that for the final rendering. POV also will not use pixel
which were rendered in the preview process for the final step! ... so if for
example your picture is still at 2x2 preview rendering and you see that you will
want it at final resolution you better stop it and start again (except you have a
HUGE parsing time.)
Date: 7 Feb 2001 04:42:26
Message: <3a811882@news.povray.org>
If you don't make any more scene changes save your photon maps so they aren't
recalculated.
global_settings {
 photons {
  save_file "finalphotons.txt"
  // photon stuff
 // global stuff
Use that for the preview then load_file for the final render.  You might
already have known about that.  I don't know if there's a problem or not with
mosaic preview and a saved photon map, just a suggestion.
Bob H.
Date: 7 Feb 2001 10:58:07
Message: <3a81708f$1@news.povray.org>
> >     I hope ...
What I
there
pixel
for
you will
have a
> HUGE parsing time.)
Is that true ??? I don't believe it ... Why don't they use these Rays again
They are already computed, and mostly they are on the right position ...
I used it, because I didn't know, they're not reused and I wanted to
aproximate the final rendering time ...
Jan Walzer
Date: 7 Feb 2001 12:45:20
Message: <3a8189b0@news.povray.org>
: Is that true ??? I don't believe it ... Why don't they use these Rays again
: They are already computed, and mostly they are on the right position ...
  When the mosaic preview option was first introduced (I think it was in
3.0, or was it even before that? I don't remember), 8 megabytes of RAM was
a really huge amount of memory.
  If you think about what you need in order to be able to reuse the pixel
values of the mosaic preview step, you'll see that in practice you'll have
to keep the entire image in memory. It's not only necessary in order to be
able to save the whole image to disk in the right order but also for things
like antialiasing (antialiasing needs the nearby pixels in order to
calculate the antialiasing threshold).
  POV-Ray has always been designed to be able to create any sized images.
For example creating a 1600x1200 sized image with alpha channel should not be
a problem.
  Now, how much memory does this image take?
  This depends a lot in how do we store the image in memory. The obvious
answer "1 byte per color component" is not as obvious as one could think.
  AFAIK the antialiasing threshold needs floating point numbers to compare
whether the threshold is reached or not. This floating point number
(representing one channel of the pixel) is in the range between 0 and 1.
A byte per color component would give 256 steps between 0 and 1. Well, this
might be enough, or not. This would mean that "+a0.005" would be the same
as "+a0" although it shouldn't.
  Even if we use just 1 byte per color channel, that would be 4 bytes per
pixel in the worst case (that is, alpha channel is used). 1600x1200 pixels
take, thus, 7680000 bytes = 7.3 Megabytes.
  (If we have to use floating point numbers for the color channels and
a float takes 4 bytes, then one pixel would take 16 bytes and the whole
image would take 30720000 bytes = 29.3 Megabytes.)
  When we have 8 megs of RAM, using 7.3 Megs for the image doesn't sound like
a good option.
  Of course nowadays the situation is completely different. 128 Megs of RAM
is not unusual at all.
  However, modifying the mosaic preview code would require some work and
I suppose that the team has its hands full of more important work already.
This kind of optimization has quite low priority, after all.
