POV-Ray : Newsgroups : povray.advanced-users : Strange (undesireable) effect Server Time
14 Oct 2025 03:26:14 EDT (-0400)
  Strange (undesireable) effect (Message 1 to 4 of 4)
Subject: Strange (undesireable) effect
Date: 20 Jan 2001 15:33:31
Message: <3a69f61b@news.povray.org>
Can anyone tell me what's causing the transparent cylinders containing the
media to show up black when viewed through the semi-transparent spheres?  I
couldn't get the bug worked out prior to entering it into the IRTC animation
contest.  By the way, some of the entries are really good this round -
they're worth checking out!  I put the code at the end in case that helps.
Thanks for the help!
- Mike Sobers
"Here's your problem - your Kalman filter's all gunked up.  We'll have to
replace it with a clean one." - me, after my linear control systems final
Here's the code for the media:
#declare laser2 = media {
  emission 1.5
  intervals 5
  samples 1, 10
  confidence 0.9999
  variance 1/1000
  density {
    cylindrical
    ramp_wave
    turbulence 0.3
    color_map {
      [0.0 color rgb <0, 0, 0>]
      [0.05 color rgb <0.3, 0.0, 0>]
      [0.8 color rgb <1, 0.1, 0.1>]
      [1.0 color rgb <1, 0.2, 0.2>]
    } scale 0.35
  } rotate 90*x
And here's the code for the shields.
#declare SHIELD_GLOW = texture {
     wrinkles
     turbulence .6
     octaves 3
     lambda 3
     omega 0.4
     color_map {
      [0 color rgbt <1, 0.6, 1, 1>]
      [0.56 color rgbt <1, 0.5, 1, .9>]
      [0.56 color rgbt <1, 0.5, 1, 0.7>]
      [0.60 color rgbt <0.5, 0.5, 1, 0.7>]
      [0.64 color rgbt <1, 0.5, 1, 0.7>]
      [0.64 color rgbt <1, 0.5, 1, 0.9>]
      [1 color rgbt <1, 0.6, 1, 1>]
     scale 10 translate <0,0,10*My_Clock>
   finish { diffuse 0 ambient 1 }
#declare shield1 = difference {
    sphere { 0 12 scale <1,0.5,1.5> translate <0,1,-1> texture
{ SHIELD_GLOW }}
    sphere { 0 12 scale 0.97*<1,0.5,1.5> translate <0,1,-1> texture
 SHIELD_GLOW }}
    box {<-12.01,-5.01,17.01-36.02*shield_coverage> <12.01,7.01,-19.01>
      texture
        pigment { color rgbt <0.7,0.7,1,0.4> }
        finish { ambient 1 diffuse 0 }
    hollow on
    no_shadow
Download 'Pursu331.jpg' (13 KB)
Preview of image 'Pursu331.jpg'
Subject: Re: Strange (undesireable) effect
Date: 20 Jan 2001 15:46:15
Message: <chrishuff-9A8CC4.15472220012001@news.povray.org>
In article <3a69f61b@news.povray.org>, "Michael Sobers"
> containing the media to show up black when viewed through the
> semi-transparent spheres?  I couldn't get the bug worked out prior to
> entering it into the IRTC animation contest.  By the way, some of the
> entries are really good this round - they're worth checking out!  I
Most likely you haven't specified a high enough max_trace_level. See:
http://www.students.tut.fi/~warp/povVFAQ/languageVFAQ.html#maxtracelevel
Also read the manual, section 4.10.6 titled "Max_Trace_Level".
Christopher James Huff
Date: 20 Jan 2001 22:56:43
Message: <3A6A5E5F.BCF05563@pacbell.net>
I agree with your assessment. I also would like to remind Michael
that we do not allow binary attachements in this group. The example
image should have been posted in povray.binaries.images.
Date: 22 Jan 2001 18:52:07
Message: <3a6cc7a7@news.povray.org>
Thanks for the tip!  I should have figured it out if I'd noticed that
problem only occurs when looking through two layers of transparency, but not
one.  I've never had to change the gobal setting before, so I didn't think
about it.
Sorry about the binary . . .
"Ken" <tyl### [at] pacbellnet> wrote in message
news:3A6A5E5F.BCF05563@pacbell.net...
> Ken Tyler - 1400+ POV-Ray, Graphics, 3D Rendering, and Raytracing Links:
