Can anyone tell me what's causing the transparent cylinders containing the
media to show up black when viewed through the semi-transparent spheres? I
couldn't get the bug worked out prior to entering it into the IRTC animation
contest. By the way, some of the entries are really good this round -
they're worth checking out! I put the code at the end in case that helps.
Thanks for the help!
- Mike Sobers
"Here's your problem - your Kalman filter's all gunked up. We'll have to
replace it with a clean one." - me, after my linear control systems final
Here's the code for the media:
#declare laser2 = media {
emission 1.5
intervals 5
samples 1, 10
confidence 0.9999
variance 1/1000
density {
cylindrical
ramp_wave
turbulence 0.3
color_map {
[0.0 color rgb <0, 0, 0>]
[0.05 color rgb <0.3, 0.0, 0>]
[0.8 color rgb <1, 0.1, 0.1>]
[1.0 color rgb <1, 0.2, 0.2>]
} scale 0.35
} rotate 90*x
And here's the code for the shields.
#declare SHIELD_GLOW = texture {
wrinkles
turbulence .6
octaves 3
lambda 3
omega 0.4
color_map {
[0 color rgbt <1, 0.6, 1, 1>]
[0.56 color rgbt <1, 0.5, 1, .9>]
[0.56 color rgbt <1, 0.5, 1, 0.7>]
[0.60 color rgbt <0.5, 0.5, 1, 0.7>]
[0.64 color rgbt <1, 0.5, 1, 0.7>]
[0.64 color rgbt <1, 0.5, 1, 0.9>]
[1 color rgbt <1, 0.6, 1, 1>]
scale 10 translate <0,0,10*My_Clock>
finish { diffuse 0 ambient 1 }
#declare shield1 = difference {
sphere { 0 12 scale <1,0.5,1.5> translate <0,1,-1> texture
{ SHIELD_GLOW }}
sphere { 0 12 scale 0.97*<1,0.5,1.5> translate <0,1,-1> texture
SHIELD_GLOW }}
box {<-12.01,-5.01,17.01-36.02*shield_coverage> <12.01,7.01,-19.01>
texture
pigment { color rgbt <0.7,0.7,1,0.4> }
finish { ambient 1 diffuse 0 }
hollow on
no_shadow
Download 'Pursu331.jpg' (13 KB)
Preview of image 'Pursu331.jpg'
Thanks for the tip! I should have figured it out if I'd noticed that
problem only occurs when looking through two layers of transparency, but not
one. I've never had to change the gobal setting before, so I didn't think
about it.
Sorry about the binary . . .
"Ken" <tyl### [at] pacbell net> wrote in message
news:3A6A5E5F.BCF05563@pacbell.net...
> Chris Huff wrote:
> > Most likely you haven't specified a high enough max_trace_level. See:
> > http://www.students.tut.fi/~warp/povVFAQ/languageVFAQ.html#maxtracelevel
> > Also read the manual, section 4.10.6 titled "Max_Trace_Level".
> I agree with your assessment. I also would like to remind Michael
> that we do not allow binary attachements in this group. The example
> image should have been posted in povray.binaries.images.
> Ken Tyler - 1400+ POV-Ray, Graphics, 3D Rendering, and Raytracing Links:
