POV-Ray : Newsgroups : povray.advanced-users : How to do a fill in Server Time
13 Jan 2025 03:53:48 EST (-0500)
  How to do a fill in (Message 1 to 9 of 9)
Subject: How to do a fill in
Date: 17 Jan 2001 10:46:51
Message: <3a65be6b@news.povray.org>
I have a set of points on the XY plane which have a clockwise order to form
a shape.  I want to fill this shape with something.  I can't use a prism
object for this purpose as it will eventually add a height element.  Does
anyone know how to generate a mesh to do this?
Geoff
Subject: Re: How to do a fill in
Date: 17 Jan 2001 11:04:29
Message: <3A65C29A.7DBEF76C@via.ecp.fr>
Then just use a polygon{}.
JM
Date: 17 Jan 2001 13:41:09
Message: <3a65e745@news.povray.org>
No planar form will work, since the height component will get added later.
I am attempting to project a 2D shape onto a 3D shape.  I was working with
differences, but that didn't work, so I was trying to generate a mesh to do
it.  Since the base shape is 2D, I should be able (perhaps by breaking it
down further) to generate a mesh for the shape.  If I cannot, I can't hope
to do so in 3D.
Geoff
Date: 17 Jan 2001 13:56:07
Message: <slrn96bqma.f6b.ron.parker@fwi.com>
Please explain what you mean by "the height component will get added later."
Are the vertices going to have different heights?  If so, there are lots
of different solutions for the same problem, but none of the easy ones will
look good.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 17 Jan 2001 16:44:47
Message: <3A6612A3.AE801980@spiritone.com>
Choose a point in the center of the object and create a mesh of triangles,
taking two points and connecting them with the center.
You may create internal "rings" depeding on how your xy points are set up, then
you can add the height.
So if your points are in an array of position vectors
#decalre points = array[5]
 { <1,0,0> <1,0,1> <0,0,1> <-1,0,0> <0,0,-1> }
mesh{
#declare cnt = 1;
#while ( cnt < dimension_size(points,1) )
  triangle { <0,0,0> points[cnt] points [cnt-1] }
  #declare cnt = cnt + 1;
texture definition
} // end mesh
That should get you started, then you can start to play with height values. If
you want to smooth them out, take a look at
http://www.spiritone.com/~english/cyclopedia/smooth2.html
Josh
> Geoff
eng### [at] spiritonecom
Date: 17 Jan 2001 16:49:42
Message: <slrn96c4rp.fap.ron.parker@fwi.com>
This doesn't work in the general case.  It'll work with convex polygons,
and some nonconvex polygons, but it's trivial to construct a polygon it
doesn't work with.
Date: 17 Jan 2001 19:09:51
Message: <3A6633C2.16DA40EB@videotron.ca>
Method 1:  (The fan)
- You have a set of n points.  Let's call them p1, p2, ... pn
- Make a triangle with {p1, p2, p3}
- Make a triangle with {p1, p3, p4}
- Repeat until you  {p1, pn-1, pn}
Method 2: (The potato-chip)
- Find the average of your points .  This is the center of your shape.
Let's call it C
- Make a triangle with {C, p1, p2 }
- Make a triangle with {C, p2, p3 }
- repeat until you hit {C, pn-1, pn }
- Make a last triangle with { C, pn, p1}
This works with 2D as well as 3D points.
This shouldn't be too hard to script or program.
Francois Labreque | In the future, performance will be measured
    flabreque     | by the size of your pipe.
        @         |             - Dogbert, on networking
   videotron.ca
Date: 18 Jan 2001 08:09:35
Message: <3a66eb0f$1@news.povray.org>
> look good.
Ok, let me see if I can explain.  I have a general surface that is never
perpendicular to the z plane  (ie, there are no caves or cliffs).  I
take a set of 2D coordinants <x,y> that I want to raise the surface from  In this
case, raising is defined as moving outwards according to the normal at the
surface at the points <x,y,z(x,y)> where z(x,y) is the height of the surface
at <x,y>.  The set of <X,y> elements have been chosen so that there is not a
great deal of curvature between pairs of x,y elements.  In general, the z
surface is well behaved in this fashion.
Now, I want to create a companion surface above the general surface, with
points <x', y', z'> = <x,y,z(x,y)> + d * N(<x,y,z(x,y)>) where d is some
distance and N(p) is the normal of the surface at point p.
I've tried a variety of methods to do this, and if there is another one, I'd
be interested, but the mesh tesselation approach seems the most promising.
In this case, I have the outer ring of points and must make a surface based
on it.  What Might be required is a more detailed tesselation, so that
surface details are not lost.
However, even assuming that the surface is totally flat, it is not obvious
how to fill the hole with an accurate mesh without resorting to polygon or
some other primitive that won't work in the 3D case.
What I am now considering is doing a circular reduction.  Ie, for each point,
there is an inside and an outside.  There is also a direction of the inside,
defined by the angle at the point.  So, given some small distance, we can
calculate two points that are offset from the main point that are guaranteed
to be inside the surface.  We can place two triangles between the two
original points and there inside points.  Do this all the way around the
object.  Repeat for the reduced object.  When the line segments from point
to inside point cross, average the insides and do a single triangle instead.
The above should work for anything, assuming the distance is small enough.
But it would generate a large mesh, which may be unnecessary if the 3D
object is close to flat.  One possibility is determining where the inside
direction lines cross, and checking the normal at that point.  If it doesn't
vary much from the normals at the two original points, create a single
triangle and short circuit this whole mess.  But this is getting very
complex for something that should be mostly simple.
So, anyone got any bright ideas?
Geoff
Date: 18 Jan 2001 08:50:17
Message: <3A66F4F2.3CBB8E63@spiritone.com>
I'm aware of the limitations (I just didnt' post them, oops) but from what I
understood, it would work for his issue. He didn't go into enough detail, I
guess.
Josh
> doesn't work with.
