POV-Ray : Newsgroups : povray.advanced-users : Normal vector deformation Server Time
23 Feb 2025 19:21:49 EST (-0500)
  Normal vector deformation (Message 1 to 10 of 19)
Subject: Normal vector deformation
Date: 13 Jan 2001 17:04:27
Message: <3a60d0eb@news.povray.org>
I'm working on some deformation macros that deforms the point vectors and
the normal vectors in a mesh.
Deforming the points is easy. Deforming the normals is a bit more
complicated.
To find a deformed normal I try to find the deformed points very close to
the start point of the normal, and see how the direction changes. However, I
can't figure out quite how to do it.
Say the macro Deform(V) will return a deformed version of V.
If I have the point P I can find the deformed point dP:
#declare dP = Deform(P)
If I have the normal N, how can I find the deformed normal dN?
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated January 6)
/ Also visit http://www.povrayusers.org
Subject: Re: Normal vector deformation
Date: 13 Jan 2001 17:36:49
Message: <chrishuff-6A6177.17382013012001@news.povray.org>
In article <3a60d0eb@news.povray.org>, "Rune" <run### [at] inamecom>
Try something like:
#declare SmallValue = 0.01;
#declare dN = vnormalize(Deform(P+V*SmallValue) - dP);
In other words, deform the point and a second point a short distance
along the normal from it, and use the direction from dP to the new point
as your normal. This should work in most circumstances, and you could
decrease SmallValue for more accuracy.
Christopher James Huff
Date: 13 Jan 2001 19:07:50
Message: <3a60edd6@news.povray.org>
"Chris Huff" wrote:
> Try something like:
> distance along the normal from it, and use the direction from
> dP to the new point as your normal. This should work in most
> circumstances, and you could decrease SmallValue for more
> accuracy.
Nope, I've already tried that, and it doesn't work.
Imagine a box deformed by a shearing matrix. The normals on the skewed sides
should change, but they won't using your method. I think I need several
points for reference (two points forming vectors perpendicular to the normal
vector?), but I haven't had any luck so far.
Rune
Date: 13 Jan 2001 21:33:46
Message: <chrishuff-DDC14F.21351713012001@news.povray.org>
In article <3a60edd6@news.povray.org>, "Rune" <run### [at] inamecom>
wrote:
> Nope, I've already tried that, and it doesn't work. Imagine a box
> deformed by a shearing matrix. The normals on the skewed sides should
> normal vector?), but I haven't had any luck so far.
Right, this only approximates, and only "works" for some
distortions...are you only using matrix transformations? Or were you
only using shearing matrices as an example?
I'll be thinking about this problem for a while...
Date: 13 Jan 2001 21:58:27
Message: <3A61148C.66317755@online.no>
Rune wrote:
> "Chris Huff" wrote:
> > Try something like:
> > accuracy.
If N is the normal at the point P, then how about trying this ?
#declare dN = vnormalize(Deform(P + 0.01*vnormalize(N)) - Deform(P));
Tor Olav
mailto:tor### [at] hotmailcom
Date: 13 Jan 2001 22:02:43
Message: <3A61158D.9D409B1B@online.no>
> should change ...
Hmmm ... Are you sure about this ?
If so, then how would you define a
normal of a surface at a given point ?
Tor Olav
Date: 13 Jan 2001 22:36:43
Message: <chrishuff-F60238.22381413012001@news.povray.org>
In article <3A61148C.66317755@online.no>, Tor Olav Kristensen
That is exactly the same as what I suggested (and which won't work),
though it is slightly reworded and I assumed the normal was already
normalized.
Date: 13 Jan 2001 22:42:35
Message: <chrishuff-EE1B2C.22440613012001@news.povray.org>
In article <3A61158D.9D409B1B@online.no>, Tor Olav Kristensen
The normal to the -x side of a box is -x. The top of the box is then
sheared +x so the -x and +x faces are at a 45 degree angle...but points
still remain in the same xz plane as they were before, the -y and +y
faces remain perpendicular to the y axis. The normal should be at a 45
degree angle now, <-sqrt(2)/2, sqrt(2)/2, 0> to be precise, but since
the two sample points were in the same xz plane, their position relative
to each other is the same, and the normal is still -x.
The vector perpendicular to the surface at that point.
Date: 13 Jan 2001 23:40:11
Message: <3A612C65.7FC6012@online.no>
I see.
Then would this work ?
#declare dP = Deform(P);
#declare vN = vnormalize(N);
#declare AA = 0.01;
#declare BB = 0.1;
#declare dNpx = vnormalize(Deform(P + AA*(vN + x*BB)) - dP);
#declare dNmx = vnormalize(Deform(P + AA*(vN - x*BB)) - dP);
#declare dNpy = vnormalize(Deform(P + AA*(vN + y*BB)) - dP);
#declare dNmy = vnormalize(Deform(P + AA*(vN - y*BB)) - dP);
#declare dNpz = vnormalize(Deform(P + AA*(vN + z*BB)) - dP);
#declare dNmz = vnormalize(Deform(P + AA*(vN - z*BB)) - dP);
#declare dN = vnormalize(dNpx + dNmx + dNpy + dNmy + dNpz + dNmz);
Tor Olav
Date: 13 Jan 2001 23:56:11
Message: <3A613022.B2D49A20@online.no>
> I see.
> #declare AA = 0.01;
> #declare BB = 0.1;
I see now that this will probably not work either.
I'll think of it while I sleep.  :)
Goodnight from Tor Olav
