POV-Ray : Newsgroups : povray.advanced-users : Normal vector deformation Server Time
18 May 2026 06:28:51 EDT (-0400)
  Normal vector deformation (Message 10 to 19 of 19)
<<< Previous 9 Messages Goto Initial 10 Messages
Subject: Re: Normal vector deformation
Date: 13 Jan 2001 23:56:11
Message: <3A613022.B2D49A20@online.no>
Tor Olav Kristensen wrote:
> Chris Huff wrote:
> > In article <3A61158D.9D409B1B@online.no>, Tor Olav Kristensen
> > <tor### [at] onlineno> wrote:
> > > Hmmm ... Are you sure about this ?
> > The normal to the -x side of a box is -x. The top of the box is then
> > sheared +x so the -x and +x faces are at a 45 degree angle...but points
> > still remain in the same xz plane as they were before, the -y and +y
> > faces remain perpendicular to the y axis. The normal should be at a 45
> > degree angle now, <-sqrt(2)/2, sqrt(2)/2, 0> to be precise, but since
> > the two sample points were in the same xz plane, their position relative
> > to each other is the same, and the normal is still -x.
> I see.
> Then would this work ?
> #declare dP = Deform(P);
> #declare vN = vnormalize(N);
> #declare AA = 0.01;
> #declare BB = 0.1;
> #declare dNpx = vnormalize(Deform(P + AA*(vN + x*BB)) - dP);
> #declare dNmx = vnormalize(Deform(P + AA*(vN - x*BB)) - dP);
> #declare dNpy = vnormalize(Deform(P + AA*(vN + y*BB)) - dP);
> #declare dNmy = vnormalize(Deform(P + AA*(vN - y*BB)) - dP);
> #declare dNpz = vnormalize(Deform(P + AA*(vN + z*BB)) - dP);
> #declare dNmz = vnormalize(Deform(P + AA*(vN - z*BB)) - dP);
> #declare dN = vnormalize(dNpx + dNmx + dNpy + dNmy + dNpz + dNmz);
I see now that this will probably not work either.
I'll think of it while I sleep.  :)
Goodnight from Tor Olav
mailto:tor### [at] hotmailcom
Date: 14 Jan 2001 06:43:12
Message: <3a6190d0@news.povray.org>
"Chris Huff" wrote:
> are you only using matrix transformations?
No.
> Or were you only using shearing matrices as an example?
Yes.
> I'll be thinking about this problem for a while...
I've tried this:
#local SomeVector = x;
#local Small = 0.001;
#local N1 = Perpendiculize(SomeVector,N);
#local N2 = vcross(N1,N);
#local deformP = mezz_deform(P);
#local nN1 = mezz_deform(N1*Small+P)-deformP;
#local nN2 = mezz_deform(N2*Small+P)-deformP;
#local deformN = vnormalize(vcross(nN1,nN2));
It doesn't work, but I can't understand why.
( Perpendiculize(A,B) adjusts A so it is perpendicular to B. The adjusted A
is returned. )
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated January 6)
/ Also visit http://www.povrayusers.org
Date: 14 Jan 2001 09:44:52
Message: <chrishuff-7859A9.09461714012001@news.povray.org>
In article <3a6190d0@news.povray.org>, "Rune" <run### [at] inamecom>
> adjusted A is returned. )
I think you need to make two vectors perpendicular to the normal, deform
those, and find a vector perpendicular to those. It looks like this
might have been what you are doing...cross products give me a headache.
Maybe something along the lines of:
#macro mezz_deform_dir(P, DP, N) (mezz_deform(P + N*Small) - DP) #end
#macro DeformNormal(Point, deformedPoint, Normal)
    #local N1 = Perpendiculize(Normal, y);
    #local N2 = Perpendiculize(Normal, N1);
    #local N1 = mezz_deform_dir(Point, deformedPoint, N1);
    #local N2 = mezz_deform_dir(Point, deformedPoint, N2);
    #local deformedNormal = Perpendiculize(N1, N2);
    (deformedNormal)
I don't think a third point will be necessary, because the normal
shouldn't change if the surface moves perpendicularly to it...but I may
be wrong, it may be something to try.
Christopher James Huff
Date: 14 Jan 2001 11:14:03
Message: <3a61d04b@news.povray.org>
> normal, deform those, and find a vector perpendicular to
> those. It looks like this might have been what you are
It's exactly what I did. It's not what your solution does though... :)
It wouldn't make sense to use a third point.
The solution I posted myself actually turned to work perfectly after all.
The strange results I was getting were caused by a bug a somewhere else in
my macro.
Thanks for the help anyway.
Rune
Date: 14 Jan 2001 19:23:00
Message: <3a6242e4@news.povray.org>
> my macro.
In effect, you're deforming the plane defined by the current normal at the
point of the current vertex.  For the most accurate results, I guess you'd
use the derivative of your deformation function - in the general case, using
small distances along the plane should be fine.
And yes, as you've found I didn't take this into account when creating the
mesh deformation macros in the Compressed Mesh Macro File.  My only defence
is laziness - and when I first created the macros I only had one mesh that
didn't use smooth triangles, so it didn't bother me much!
Date: 15 Jan 2001 05:39:16
Message: <3a62d354$1@news.povray.org>
Rune wrote in message <3a60d0eb@news.povray.org>...
> I'm working on some deformation macros that deforms the point vectors and
> the normal vectors in a mesh.
> Deforming the points is easy. Deforming the normals is a bit more
> complicated.
yes, little more complicated ...
> To find a deformed normal I try to find the deformed points very close to
> the start point of the normal, and see how the direction changes. However, I
> can't figure out quite how to do it.
in the first version of my deform patch I had such calculation of normal - first
I had calculated n points around of deformed point on plane perpendicualr to the
base normal with distance d, and then deformed and calculated weighted normal of
achived virtual triangles
in symbolic code:
input:
  int n - n points around base/deformed point
  dbl d - distance beetwen points and base point
  vect P - base point
  vect N - normal in base point
  func deform( point ) - deformation as function
output:
  vect ND - normal after deformation
  vect D - point after deformation
code:
  dbl local a,b,c,i,j,p,l[n]
  vect A[n]
  p = N[Y]*N[Y]
  if ( p<(1.0-EPSILON) )
    p=d/sqrt(1-p)
    A[0] = p * < N[Z], 0.0, N[X])
  else
     A[0] = < 0.0 , 0.0 , d >
  for ( i = 1 ; i < n ; i = i + 1 )
    A[i] = vaxis_rotate( A[0] , N , i * 2*pi/n )
  D = deform( P )
  for ( i = 0 ; i < n ; i = i + 1 )
    A[ i ] = deform( A[ i ] + P ) - D
    l[ i ] = vlength( A[ i ] )
  DN=< 0.0, 0.0, 0.0 >
  for ( i=0 ; i < n ; i = i + 1 )
    j = i+1
    j = ( j<n ) ? j : 0
    c = vlength( A[ i ] , A[ j ] )
    p = ( l[ i ] + l[ j ] + c ) / 2.0
    p = sqrt( p * ( p - l[i] ) * ( p - c ) * ( p - l[j] ) )
    DN = DN + p * vnormalize( vcross( A[ i ] , A[ j ] )
  DN = vnormalize( DN )
I hope it helps
ABX
Date: 15 Jan 2001 12:19:50
Message: <3a633136$1@news.povray.org>
> creating the mesh deformation macros in the Compressed Mesh
> Macro File.  My only defence is laziness - and when I first
> created the macros I only had one mesh that didn't use smooth
I intent to release my own macros sometime that can read PCM files.
They will have both advantages and disadvantages compared to your macros.
Rune
Date: 16 Jan 2001 11:49:44
Message: <3a647ba8@news.povray.org>
Chris Colefax <chr### [at] tagpovrayorg> wrote:
: And yes, as you've found I didn't take this into account when creating the
: mesh deformation macros in the Compressed Mesh Macro File.  My only defence
: is laziness - and when I first created the macros I only had one mesh that
: didn't use smooth triangles, so it didn't bother me much!
  A working version would apply transformations differently on vertices and
normals.
  If a PCM is optimized, some vertices and normals can be shared. This causes
a problem (and it's a headache in the mesh compressor program as well).
char*i="b[7FK@`3NB6>B:b3O6>:B:b3O6><`3:;8:6f733:>::b?7B>:>^B>C73;S1";
main(_,c,m){for(m=32;c=*i++-49;c&m?puts(""):m)for(_=(
c/4)&7;putchar(m),_--?m:(_=(1<<(c&3))-1,(m^=3)&3););}    /*- Warp -*/
Date: 16 Jan 2001 15:27:47
Message: <3a64aec3@news.povray.org>
> on vertices and normals.
Yes.
> shared. This causes a problem
That can easily be solved, it just requires more memory in the parsing
stage...
As I said, I'm working on a PCM reading macro that handles normal
deformation correctly. See p.b.i for an example image...
Rune
Date: 17 Jan 2001 06:11:20
Message: <3a657dd7@news.povray.org>
:>   If a PCM is optimized, some vertices and normals can be
:> shared. This causes a problem
: That can easily be solved, it just requires more memory in the parsing
: stage...
  It's, however, a rather rare case. I suppose that most people don't
optimize the PCM, and even if they do, it seldom succeeds (unless they
use a very high error tolerance).
  I'm not sure if it's worth the efforts to take that possibility into
account...
