POV-Ray : Newsgroups : povray.advanced-users : i still do not have an answer yet Server Time
18 May 2026 06:23:24 EDT (-0400)
  i still do not have an answer yet (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: i still do not have an answer yet
Date: 13 Jan 2001 23:16:43
Message: <3A6126E0.F5C4E9DE@online.no>
Adam Gibbons wrote:
> Thanks very much for you help. i have had a kit of usesless replys.
My opinion is that they weren't useless.
I belive they replied the way they did because you
asked this kind of question in povray.advanced-users
instead of in povray.newusers.   ;)
> but yours it very help full.
> i would very much appiciate it if you can provide me with a formula for what
> i have written.
Now it's tomorrow here in Norway and I have had a few beers ...
So therefore I'll not try to give you a lengthy answer now.
But you may have a look at the code below and then feel free
to ask if you need me to explain more.
Now I'm off to bed.
Tor Olav
mailto:tor### [at] hotmailcom
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
#version 3.1;
#declare nothing = 1/10000;
#declare SphereRadius = 0.1;
// Like you did it
sphere {
  <0.68, 0.425/2 + 0.09, 0>, SphereRadius
  translate <0, 0.85, 0>
  scale 0.75
  rotate <10, -45, -20>
  translate <-0.7, -0.1, 0>
  pigment { Red }
// Use of vrotate to put sphere in same postion
#declare pStart = (<0.68, 0.425/2 + 0.09, 0> + <0, 0.85, 0>)*0.75;
#declare pEnd = vrotate(pStart, <10, -45, -20>) + <-0.7, -0.1, 0>;
sphere {
  pEnd, SphereRadius*0.75 // - nothing
  pigment { Yellow }
// Doing it the "hard way" with trig functions
#declare xAngle = radians(10);
#declare yAngle = radians(-45);
#declare zAngle = radians(-20);
// Rotate around the x-axis
#declare pRot1 = <pStart.x,
                  cos(xAngle)*pStart.y - sin(xAngle)*pStart.z,
                  cos(xAngle)*pStart.z + sin(xAngle)*pStart.y>;
// Rotate around the y-axis
#declare pRot2 = <cos(yAngle)*pRot1.x  + sin(yAngle)*pRot1.z,
                  pRot1.y,
                  cos(yAngle)*pRot1.z  - sin(yAngle)*pRot1.x>
// Rotate around the z-axis
#declare pRot3 = <cos(zAngle)*pRot2.x  - sin(zAngle)*pRot2.y,
                  cos(zAngle)*pRot2.y  + sin(zAngle)*pRot2.x,
                  pRot2.z>
#declare pEnd = pRot3 + <-0.7, -0.1, 0>;
sphere {
  pEnd, SphereRadius*0.75 + nothing
  pigment { Green }
// Show start and end postition points in debug window
#macro PrintVector(Vector)
  #debug "<"
  #debug str(Vector.x, 0, -1)
  #debug ", "
  #debug str(Vector.y, 0, -1)
  #debug ", "
  #debug str(Vector.z, 0, -1)
  #debug ">"
#end // macro PrintVector
#debug "\n\n"
PrintVector(pStart)
#debug "\n\n"
PrintVector(pEnd)
#debug "\n\n"
light_source { 10*<3, -1, 1> color White }
background { color Blue/2 }
  location <1, 1, 1>
  look_at <0, 0, 0>
Date: 14 Jan 2001 07:43:06
Message: <3a619eda@news.povray.org>
I just don't understand why you want to make this. What will you achieve
doing it?
  Your rendering speed will not be affected in any way.
  You will only cause yourself more trouble than it's worth.
  If you keep the transformations that put the object in the right place,
it's easier to see how the location was calculated.
  Also, what happens if you want to slightly modify one of the transformations?
Instead of just modifying one number in the transformations you'll have to
recalculate the whole thing again. Why, when povray can do it for yourself?
  Of course it's good to know the math to get the location of a point which
have been transformed because it can have some uses, but in my experience
one of these uses is not putting the result directly in the object
definition.
char*i="b[7FK@`3NB6>B:b3O6>:B:b3O6><`3:;8:6f733:>::b?7B>:>^B>C73;S1";
main(_,c,m){for(m=32;c=*i++-49;c&m?puts(""):m)for(_=(
c/4)&7;putchar(m),_--?m:(_=(1<<(c&3))-1,(m^=3)&3););}    /*- Warp -*/
Date: 14 Jan 2001 09:02:33
Message: <3a61b179@news.povray.org>
You really want to know why ?? !
ok,
i am drawing a lamp.
i have the head of the lamp and i have the base of the lamp
but i have nothing connecting the two.
i can draw a sphere as a marker at the top and another at the bottem for
where i want the wire to goto and from. but the top of the lamp has been
move and then rotated. but to ray something going between to two i need jus
the X,Y,Z for the top and just the X,Y,Z for the bottem. i have to bottem
co-ordinets, but to work out what the top ones are i have to find the answer
to my problem.
plus it would be usesfull to know in the future for other sceans with maybe
a simaler problem.
if you know the answer then please just tell me.
Adam
news:3a619eda@news.povray.org...
> doing it?
transformations?
yourself?
which
> definition.
Date: 14 Jan 2001 09:22:17
Message: <3A61B595.9D258E29@videotron.ca>
> a simaler problem.
David Fontaine already did:
	This is basically vectors and matrices.
	The matrices for the different transforms and a basic explana-
	tion of how they work is here, but it won't tell you the basics
	of matrix math like multiplying, etc:
	http://davidf.faricy.net/povre.html#Matrices (nothing like a
	little website promotion)
As did Tor Olav Kristensen:
            pRot1.y,
            pRot2.z>
And I remember someone else providing these equations to Rune as well in
an other thread.
> Adam
> > doing it?
> transformations?
> yourself?
> which
> > definition.
Francois Labreque | Unfortunately, there's no such thing as a snooze
    flabreque     | button on a cat who wants breakfast.
        @         |      - Unattributed quote from rec.humor.funny
   videotron.ca
Date: 14 Jan 2001 16:26:37
Message: <3A6219A4.25658654@yahoo.com.au>
Adam, although this isn't a windows program that will do what you want, it may
be the nearest POV equivelent. You could try placing all of those transforms
into a transform identifier, then use that identifier to both move the sphere
_and_ calculate the new coordinates, then output those coords to a text stream
in the POV messages. The example below uses a MegaPOV feature (vtransform) but I
think the rest of the code is 3.1 compatible.
// 1st, declare all of your transformations
#declare Trans_1 =
transform
        translate <0,0.85,0>
        scale <0.75,0.75,0.75>
        rotate < 10 ,-45, -20>
        translate <-0.7,-0.1, 00>
// Calculate the new position using vtransform
#declare Sphere_Pos = vtransform(<0.68,(0.425/2)+0.09,0>,transform Trans_1);
// Stream the x,y, and z coords to the debug steam
#debug concat("\n","X Co-ord = ",str(Sphere_Pos.x,0,-1))
#debug concat("\n","Y Co-ord = ",str(Sphere_Pos.y,0,-1))
#debug concat("\n","Z Co-ord = ",str(Sphere_Pos.z,0,-1),"\n")
// Declare your sphere
sphere
        0.1
        texture { Your_Tex }
        transform Trans_1
Now you have both a transformed sphere, and its new coordinates (both streamed
so that you can see them, and in the Sphere_Pos identifier). Hope this helps.
MJL
Date: 15 Jan 2001 03:51:59
Message: <3a62ba2f@news.povray.org>
So what you want is just a vector telling you the location of the object.
You don't need to calculate the result by yourself but you can let povray
do it, as others have already answered.
  If you are using megapov, you can declare all the transformations in one
identifier and then apply the same transformation to the object and to
a vector (with vtransform), as already pointed out.
  It's also good to know how to make the individual transformations to a
vector:
translate <a,b,c>  <=>  #declare Vector = Vector + <a,b,c>;
    scale <a,b,c>  <=>  #declare Vector = Vector * <a,b,c>;
   rotate <a,b,c>  <=>  #declare Vector = vrotate(Vector, <a,b,c>);
  If you want to make the individual transformations to the vector (eg. because
you don't have megapov to use vtransform, or for other reason), just apply
the abovementioned equivalent operations.
  For example:
sphere
{ 0, 1  #declare Loc = <0,0,0>;
  translate <1,2,-3>  #declare Loc = Loc + <1,2,-3>;
  rotate y*30  #declare Loc = vrotate(Loc, y*30);
  translate -x*2  #declare Loc = Loc - x*2;
  scale .5  #declare Loc = Loc * .5;
  Now 'Loc' will be the coordinate of the center of the sphere.
Date: 15 Jan 2001 20:43:27
Message: <3a63a73f@news.povray.org>
does vrotate work under povray 3.1g for windows ??!!
news:3a62ba2f@news.povray.org...
object.
> vector:
because
>   For example:
> sphere
Date: 15 Jan 2001 21:47:26
Message: <chrishuff-42A9CF.21484915012001@news.povray.org>
In article <3a63a73f@news.povray.org>, "Adam Gibbons"
Yes, the vrotate() function is part of the official version. However,
the vtransform() function isn't, it is a patch that I wrote, but it is
in MegaPOV and will eventually be in POV 3.5. You could imitate it
partially with macros, like:
#macro VTranslate(V, Translation) (V+Translation) #end
#macro VScale(V, Translation) (V*Translation) #end
Another function in the official version that you may find useful is
vaxis_rotate(), which rotates a point around a given axis by a specified
number of degrees instead of x, y, then z.
Christopher James Huff
Date: 16 Jan 2001 11:46:19
Message: <3a647ada@news.povray.org>
Chris Huff <chr### [at] maccom> wrote:
: #macro VScale(V, Translation) (V*Translation) #end
  Your choice of parameter name is not the best possible ;)
: Another function in the official version that you may find useful is
: vaxis_rotate(), which rotates a point around a given axis by a specified
: number of degrees instead of x, y, then z.
  A macro that applies an axis_rotate to an object is not too difficult to
do either (I think someone has already done it; and it can be found in
the matrix page iirc).
Date: 16 Jan 2001 15:50:32
Message: <chrishuff-3F5C60.15513516012001@news.povray.org>
In article <3a647ada@news.povray.org>, Warp <war### [at] tagpovrayorg>
That's what I get for copy-pasting too much... :-)
> to do either (I think someone has already done it; and it can be
> found in the matrix page iirc).
There is one on the Thoroughly Useful Macros page, it's called
AxisRotate().
http://enphilistor.users4.50megs.com/macs.htm
