POV-Ray : Newsgroups : povray.advanced-users : wicker basket Server Time
18 May 2026 06:29:22 EDT (-0400)
  wicker basket (Message 11 to 20 of 24)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: wicker basket
Date: 14 Jan 2001 19:21:28
Message: <3a624288@news.povray.org>
John M. Dlugosz <joh### [at] dlugoszcom> wrote:
> That is beautiful!  Thanks for the pointer.  I'll follow up that thread on
> p.b.i.
Thank you!  As I wrote in the original message with the image, the basket
was created as an example of my Spline Macro File.
The entire construction is defined by four splines giving the profile of the
basket, the weft around the basket (circular in this case), the looped edges
and the handle.  A combination of pipe splines (using cylinders to follow
the shape of the path) and torus pipe splines/coil splines (using torii
segments) is then used to create the basket.  The beauty of the torus
splines is that given the right settings they automatically create the waved
shape of the weft, without having to specify each curve.  The entire scene
file is just over 2 Kb.
If you want to create weavings with non-circular cross sections, you can
define your own macros for creating objects based on splines, using triangle
meshes, bicubic patches (which can be translated directly to spline
segments), or really any type of objects you like.  And in the absence of
complete documentation, please feel free to contact me if you need help....
Date: 15 Jan 2001 00:21:03
Message: <3a6288bf$1@news.povray.org>
on
> > p.b.i.
I sent you email direct after following up on that macro.
the
edges
waved
The part about the beauty of torus splines I see: I figured as much upon
reading your tutorial.  I don't follow the rest of it.  The weaving is a
hierarical system of splines, one for the overall shape and another for the
weave??
Grabbing digital camera... here is a life-model of what I was thinking about
(posted to p.b.i.), but after seeing yours, I really like the open weave,
too.  So now I'm thinking of the diamond-shape "dish" like mine, but with a
more open weave like yours, to show the contents better.  Each of the 4
sides and bottom would be flat, maybe made as individual panels and tied to
a metal frame.
triangle
help....
I'm thinking of thin, flat strips of wood or bark.  Sticking a wood texture
on an isosurface or carefully "carved" undulation pattern would not look
right -- it's more like a U-V mapping, not cut from material in that shape.
Know what I mean?  If strips are cut parallel to the grain, that might be
close enough, though.
--John
Date: 15 Jan 2001 18:51:27
Message: <3a638cff@news.povray.org>
the
> weave??
Yes - one spline defines the profile that is revolved to form the shape of
the basket, another is a simple circle which is repeated at intervals along
the profile spline to create the weave.
about
a
to
> a metal frame.
texture
shape.
Looking at the shape of the basket you posted the photo of, I would say
breaking the construction into parts is probably the best option.  The base
could be created using cylinders and waved torus splines, stretched in the
horizontal direction to flatten them.
The sides might be a little more complicated, particularly as the photo
doesn't clearly reveal exactly how they're woven.  You could define a
continuous spline that follows the perimeter of the basket, using this for
the horizontal canes that build up the sides, and for spacing the binding
canes that hold them together (which could be defined by another spline).
But if you wanted a more open weave, perhaps you could use vertical struts
with a weft around the sides instead.
Texture wise, I think using UV mapping to follow the exact bending of each
object might be termed "overkill"!  Given that the texture will probably
have some amount of turbulence, a little mapping to follow the general shape
of the basket (rather than the individual canes) should be sufficient.
Date: 15 Jan 2001 19:16:43
Message: <3a6392eb$1@news.povray.org>
base
I'll start with the bottom.  This "surface" is then general-purpose and I
can use for sides of things too, like hampers.  Then I'll design the
more-open sides.
I don't know the terminology you used, as I never took basket-weaving in
school.  But I see the straight (not bent) sticks running in one direction
give it strength, and flat ribbons weave among them using a high "tension"
parameter.  I see a blob_spline can be flattened like a ribbon, but I don't
see an option for torus_pipe_spline.  You mean flatten the entire shape
after defining it?  That means I'll need to pre-compensate the amplitude.
--John
Date: 15 Jan 2001 19:26:51
Message: <3a63954b@news.povray.org>
> more-open sides.
don't
I (compulsorily) wove a few baskets at school when I was 10 or so - I would
suggest you don't take me as any sort of expert on the subject!
As for the flattening, this is why I suggested stretching in the horizontal
direction rather than flattening in the vertical, e.g. for a cross section
that measures 5 x 1 units, use a radius of 0.5 and scale by <5, 1, 1>
(presuming the spline runs in the +z direction, weaving up and down in the
+y).  Otherwise, you can use inverse spline transformations, e.g.:
   object {create_spline_object (MySpline, spline_scale (1/<1, 0.2, 1>))
      scale <1, 0.2, 1>}
This way you can define the shape of the spline exactly as you want it,
because the transformations cancel out any effect on the shape of the spline
path itself (but still change the shape of the cross-section).
Date: 15 Jan 2001 21:28:08
Message: <3a63b1b8$1@news.povray.org>
horizontal
Oh, that would be easier.  In my tests, I found that a vector for
spline_radius did not work for torus, and pre-multiplied the amplitude (in
the vector parameter, not using spline_scale) and then reduced the scale.
On my next go, I'll scale up the other direction instead.
I've posted a test render on p.b.i. that shows flattened slats weaving
around fixed sticks.
I think to give a less orderly result, I can start with a grid of points
that represent the intersections, and peterb them a little.  The sticks can
bend too, but very slightly, using the same technology.  I can also vary the
tension a little from strip to strip, to simulate the effect of thicker or
thinner pieces.
--John
Date: 15 Jan 2001 23:01:32
Message: <3a63c79c$1@news.povray.org>
Why does changing the spline_steps from 120 to 60 (1210 frame level objects
vs. 610, a factor of 2)affect the rendring time by a factor of 7.6?  It's
even slow on the blank "sky" area above the image and the blank "desk"
below.  Bounding boxes, where art thou?
--John
Date: 16 Jan 2001 17:49:36
Message: <3a64d000@news.povray.org>
objects
Where indeed?  I don't specify any bounding boxes internally in the Spline
Macro File, as these will be overridden by POV-Ray unless the -UR command
line option is used.  Instead, each torus is clipped using boxes that fit
the desired segment as closely as possible.  Ideally, POV-Ray would the
bound each torus by its clipping box.  You may find it's best to perform
some manual bounding, however (at least for the union that forms the
weaving, to prevent slow rendering above and below).
Date: 16 Jan 2001 22:48:17
Message: <3a651601$1@news.povray.org>
Right, I thought POV will autobound just fine.  There is no way the empty
areas should be computing intersections with the clipped segments!  Why
would manual bounding be required?  Is POV falling down on this particular
shape somehow?  Is there an infinite object somewhere in your macro that
messes it up?
--John
Date: 16 Jan 2001 23:43:37
Message: <slrn96a8nt.ekk.ron.parker@fwi.com>
Isn't that what bounded_by{clipped_by} is for?
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
