POV-Ray : Newsgroups : povray.advanced-users : Distance to line segment? Server Time
10 Feb 2026 10:14:17 EST (-0500)
  Distance to line segment? (Message 1 to 10 of 10)
Subject: Distance to line segment?
Date: 21 Dec 2000 16:25:15
Message: <3a42753b@news.povray.org>
How do I find the distance from the point P to the nearest point in the line
segment defined by point A and point B?
Thanks in advance!
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated December 17)
/ Also visit http://www.povrayusers.org
Subject: Re: Distance to line segment?
Date: 21 Dec 2000 16:38:22
Message: <slrn944u2g.3r9.ron.parker@fwi.com>
The distance to the line defined by A and B is given by
P-A-vdot(P-A,B-A)/vlength(B-A)
However, that ignores the "line segment" part of your question.  If
vdot(P-A,B-A) is less than zero, you should instead use vlength(P-A).
If vdot(P-A,B-A)/vlength(B-A) is greater than vlength(B-A), you should
use vlength(P-B).  So, in POV code:
#macro DistToLS(P,A,B)
  #local SegLen = vlength(B-A);
  #local ParComp = vdot(P-A,B-A)/SegLen;
  #if ( ParComp < 0 )
    vlength(P-A)
  #else
    #if (ParComp > SegLen)
      vlength(P-B)
    #else
      (P-A-ParComp)
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 22 Dec 2000 17:55:46
Message: <3a43dbf2@news.povray.org>
>   #if ( ParComp < 0 )
>     vlength(P-A)
>   #else
>       vlength(P-B)
>     #else
>       (P-A-ParComp)
>     #end
>   #end
> #end
Thanks you!
Rune
Date: 22 Dec 2000 17:58:25
Message: <3A43D9BC.1EBB5DB4@online.no>
I would do it like this:
#macro Dist2LnSegm(pP, pA, pB)
  #local vL = pB - pA;
  #local ss = vdot(pP - pA, vL)/vdot(vL, vL);
  vlength(pP - (ss >= 1 ? pB : pA + max(ss, 0)*vL))
#end // Dist2LnSegm
Tor Olav
mailto:tor### [at] hotmailcom
Date: 22 Dec 2000 18:05:43
Message: <3A43DB80.979B89C3@online.no>
It seems like you are subtracting
a scalar from a vector expression.
Are you that this is the right thing
to do here ?
>   #if ( ParComp < 0 )
>     vlength(P-A)
>   #else
>       vlength(P-B)
>     #else
>       (P-A-ParComp)
>     #end
>   #end
> #end
For me it looks like there are some
problems with the above macro.
When I change it to this:
#macro DistToLS(P, A, B)
  #local SegLen = vlength(B - A);
  #local ParComp = vdot(P - A, B - A)/SegLen;
  #if (ParComp <= 0)
    #local dd = vlength(P - A);
  #else
    #if (ParComp >= SegLen)
      #local dd = vlength(P - B);
    #else
      #local dd = vlength(P - A - ParComp*vnormalize(B - A));
    #end // if
  #end // if
  dd
#end // DistToLS
then it behaves like I would suspect
it too do (in POV v3.1)
Tor Olav
Date: 22 Dec 2000 18:34:06
Message: <3A43E229.47AFFF18@online.no>
> #end // Dist2LnSegm
Changing the last expression in this macro to:
  vlength(pP - pA + max(0, min(ss, 1))*vL)
or
  vlength(pP - (ss >= 1 ? pB : (ss <= 0 ? pA : pA + ss*vL)))
also seems to work.
Tor Olav
Date: 23 Dec 2000 10:31:16
Message: <3a44c544@news.povray.org>
Thank you! The macros work fine, except the one with the line
...but I'll just use one of the others.
Rune
Date: 23 Dec 2000 23:33:14
Message: <slrn94av4e.53d.ron.parker@fwi.com>
>to do here ?
Nope.  That's what I get for posting without testing.  The scalar should be
multiplied by the unit vector in the direction of B-A, or by (B-A)/vlength(B-A).
Date: 24 Dec 2000 09:41:09
Message: <3A460805.A5B814EE@online.no>
That + sign should have been a - sign.
Sorry.
I guess I didn't test it thoroughly enough.
Tor Olav
Date: 24 Dec 2000 09:43:34
Message: <3A460897.582507F8@online.no>
> >to do here ?
> The scalar should be multiplied by the unit vector in
Yes, that's what I found too.
Best regards,
Tor Olav
