POV-Ray : Newsgroups : povray.advanced-users : Matrix question Server Time
18 May 2026 08:02:58 EDT (-0400)
  Matrix question (Message 21 to 24 of 24)
Subject: Re: Matrix question
Date: 25 Dec 2000 11:11:23
Message: <3a4771ab@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
:>  But would inverting the whole 4x4 matrix work as well?
: Of course.
  It may be crystal-clear to you, but it isn't to me.
  The decision to put the translation as the fourth column of the matrix
can sound quite arbitrary ("Hey, we need some place to put the translation
along with the other transformations. Where should we put it? Perhaps the
most handy way is just to expand the transformation matrix to 4x4 and put
the translation in the extra places").
  However, if the inversion of this matrix works as expected (that is, the
translation is also inverted as it should), then putting the translation
where it is now has a strong mathematical basis. Which is good, of course :)
Date: 25 Dec 2000 11:49:19
Message: <slrn94euki.6kk.ron.parker@fwi.com>
It does.  Essentially, as long as you put a '1' in the last row of the 4-d
vector, the translation gets added in to the transformation as you'd expect
it to.  The last row should always be 0,0,0,1.  Any other sort of 4-d matrix
doesn't have the same effect.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 31 Dec 2000 15:26:36
Message: <3A4F971F.8C76F672@mail.com>
Here's a slightly different method which might be a little faster,
since it uses intrinsically defined functions and pre-calculates more of
the values.
Taking my cue from Rune, define
#declare bX = <1,-0.05,0>;
#declare bY = <-0.5,0.5,0>;
#declare bZ = <0,0,1>;
#declare bC = <0,0,0>;
// The 16 statements to fill out the 16 elements of the inverse
// New system devised by Ben Birdsey (12/31/00)
#declare xp  = vcross(bY,bZ);
#declare yp  = vcross(bZ,bX);
#declare zp  = vcross(bX,bY);
#declare det = vdot(bX,xp);
#declare c11 = xp.x / det;
#declare c12 = yp.x / det;
#declare c13 = zp.x / det;
#declare c14 = 0;
#declare c21 = xp.y / det;
#declare c22 = yp.y / det;
#declare c23 = zp.y / det;
#declare c24 = 0;
#declare c31 = xp.z / det;
#declare c32 = yp.z / det;
#declare c33 = zp.z / det;
#declare c34 = 0;
#declare c41 = -vdot(xp,bC)/det;
#declare c42 = -vdot(yp,bC)/det;
#declare c43 = -vdot(zp,bC)/det;
#declare c44 = 1;
I checked the math on Mathematica, so it *should* be right.
You could look at this as some kind of matrix transform and lit it go
there, but maybe we can get some more understanding.
1) The new vectors xp,yp, and zp are the closest thing that the original
transformation could give you for an ordinary coordinate system.  (
because <1,0,0> is equal to vcross(<0,1,0>,<0,0,1>) ...)
2) det, which equals vdot(bX,vcross(bY,bZ)) is equal to the volume
inside the box with corners at 0, bX, bY, bZ, bX+bY, bX+bZ, bY+bZ and
bX+bY+bZ
3) the expressions for the c4x are similar to the amount of bC along
xp,yp,and zp
I hope this helps.
Ben
Date: 2 Jan 2001 21:13:30
Message: <3A528A9A.5EF512B@online.no>
> the values.
> #declare c14 = 0;
> #declare c24 = 0;
> #declare c34 = 0;
> #declare c44 = 1;
I haven't checked or tried your code, so I don't know if
it does what it's supposed to do.
But if you are going for optimizations, then I THINK that
doing it this way this will increase the parsing speed:
#declare bX = < 1.00, -0.05,  0.00>;
#declare bY = <-0.50,  0.50,  0.00>;
#declare bZ = < 0.00,  0.00,  1.00>;
#declare bC = < 0.00,  0.00,  0.00>;
#declare det = vdot(bX, vcross(bY, bZ));
#declare xp  = vcross(bY, bZ)/det;
#declare yp  = vcross(bZ, bX)/det;
#declare zp  = vcross(bX, bY)/det;
#declare c11 = xp.x;
#declare c12 = yp.x;
#declare c13 = zp.x;
#declare c14 = 0;
#declare c21 = xp.y;
#declare c22 = yp.y;
#declare c23 = zp.y;
#declare c24 = 0;
#declare c31 = xp.z;
#declare c32 = yp.z;
#declare c33 = zp.z;
#declare c34 = 0;
#declare c41 = -vdot(xp, bC);
#declare c42 = -vdot(yp, bC);
#declare c43 = -vdot(zp, bC);
#declare c44 = 1;
(Note that I haven't checked my modifications either.)
Tor Olav
mailto:tor### [at] hotmailcom
