POV-Ray : Newsgroups : povray.advanced-users : A Question about water Server Time
21 Dec 2025 09:06:03 EST (-0500)
  A Question about water (Message 1 to 9 of 9)
Subject: A Question about water
Date: 5 Dec 2000 19:00:27
Message: <3a2d819b$1@news.povray.org>
Any ideas about making water look as though it is funneling or spiralling as
in a whirlpool. The trick is that it needs to be 3-dimensional and not just
look 3D. Any suggestons would be appreciated.
Subject: Re: A Question about water
Date: 5 Dec 2000 19:31:25
Message: <3A2D8958.70C3A3ED@peak.edu.ee>
You could probably do it  with isosurfaces in MegaPOV, using some sort of spiral
pattern as the function.
Another possibility is to do it with a heightfield, again a spiral pattern is
should be able to do the job.
Margus Ramst
Home page http://www.hot.ee/margusrt
Date: 5 Dec 2000 20:30:40
Message: <chrishuff-2338CA.20312405122000@news.povray.org>
In article <3a2d819b$1@news.povray.org>, "Randolph Robnett"
> spiralling as in a whirlpool. The trick is that it needs to be
> 3-dimensional and not just look 3D. Any suggestons would be
> appreciated.
There was a thread a while ago about doing this with isosurfaces...in
povray.unofficial.patches, I think, but I couldn't find the exact thread.
The code I came up with in that thread could still be improved, but here
it is:
#declare Vortex =
function {
    y+(1/(sqr(x)+sqr(z)+0.3))
    +sin(atan2(x,z)*7 + y*10)*0.025
isosurface {
    function {Vortex(x,y,z)}
    threshold 0
    eval
    max_gradient 4
    contained_by {box {<-5,-5,-5>, < 5, 1, 5>}}
    pigment {color rgb < 0.5, 0.85, 1>}
Christopher James Huff
Date: 6 Dec 2000 03:39:04
Message: <3a2dfb28$1@news.povray.org>
Randolph Robnett wrote in message <3a2d819b$1@news.povray.org>...
spiralling as
just
wait a few days for my patch
supporting nonlinear transformations
I think with this stuff this could be possible
as twisted cones and spheres placed around center
but currently this is possible as isosurfaces but need math a little
ABX
Date: 6 Dec 2000 06:09:52
Message: <3a2e1e7f@news.povray.org>
Why everyone suggests all the hard ways of doing the most simple thing?
Isosurfaces? Patched versions for non-linear transformations? Come on!
You really don't need any patched version for this.
camera { location <0,2,-2> look_at y*.2 angle 35 }
light_source { <10,10,-5>, 1 }
#declare WPRadius = 1;
#declare WPCurvRadius = 1.5;
intersection
{ #declare IPH = sqrt(pow(WPCurvRadius,2)-pow(WPRadius,2));
  torus { WPRadius, WPCurvRadius translate -y*IPH}
  cylinder { 0, y*(WPCurvRadius-IPH), WPRadius }
  pigment
  { spiral1 1 color_map { [0 rgb <.5,.75,1>][1 rgb <0,.5,1>] }
    turbulence .1
    rotate x*90
    scale <.1,1,.1>
  normal
  { spiral1 1 .15 slope_map
    { [0 <0,0>][.25 <.5,1>][.5 <1,0>][.75 <.5,-1>][1 <0,0>] }
    rotate x*90
    scale <.2,1,.2>
  finish { specular .5 reflection .3 }
Date: 6 Dec 2000 09:54:35
Message: <3a2e532b@news.povray.org>
Warp wrote in message <3a2e1e7f@news.povray.org>...
thing?
a) selfadvertising
b) lack skills
c) looking long time at one source
d) we are hollow, not inverted
ABX
Date: 6 Dec 2000 17:22:07
Message: <chrishuff-0C793C.17225306122000@news.povray.org>
In article <3a2e1e7f@news.povray.org>, Warp <war### [at] tagpovrayorg>
But...but that doesn't look as realistic! :-)
Really, I prefer the shapes I can get with isosurfaces(though you can
probably do similar ones with lathe or sor), and the fact that the waves
are real waves, not just normal perturbation.
Date: 7 Dec 2000 09:33:11
Message: <3a2f9fa7@news.povray.org>
Chris Huff <chr### [at] maccom> wrote:
: Really, I prefer the shapes I can get with isosurfaces(though you can
: probably do similar ones with lathe or sor), and the fact that the waves
: are real waves, not just normal perturbation.
  Well, if it's a question of principle, then be my guest.
  However, if the final image will look almost exactly the same independently
of whether a normal modifier or an isosurface was used, then my opinion is
that small and simple is beatiful.
  Rendering speed may be another issue. Which one renders faster, a spiral
normal modifier or an isosurface?
  I haven't tested, so I can't know, but I wouldn't be surprised if the
isosurface would be slower.
Date: 11 Dec 2000 18:03:03
Message: <chrishuff-523B03.18035711122000@news.povray.org>
In article <3a2f9fa7@news.povray.org>, Warp <war### [at] tagpovrayorg>
> independently of whether a normal modifier or an isosurface was used,
> then my opinion is that small and simple is beatiful.
Well, even a smooth isosurface with a simple spiral normal would look
better than a torus, in my opinion anyway. The shape of the function I
posted is quite different from a torus, and to me looks more like a
whirlpool.
Also, you can get better looking spiral waves with an isosurface
function. Small and simple may be beautiful, but realism counts too.
> spiral normal modifier or an isosurface?
If you use a torus CSG, the torus would almost definitely be faster
compared to the function I gave. If you used a lathe or sor...you might
have to use the isosurface just to avoid the artifacts. :-)
