POV-Ray : Newsgroups : povray.advanced-users : should be normal weighted ? Server Time
23 Feb 2025 19:18:46 EST (-0500)
  should be normal weighted ? (Message 1 to 10 of 23)
Subject: should be normal weighted ?
Date: 4 Dec 2000 03:31:42
Message: <3a2b566e@news.povray.org>
I have point O and points P1, P2, ... PN
connected as traingles P1OP2, P2OP3, ..., PN-1OPN, PNOP1
I want calculate best normal at point O for all this triangles.
Should it be simple normalized summary of all normals
or waighted one depend of areas of each triangle ?
Maybe other way ?
ABX
Subject: Re: should be normal weighted ?
Date: 4 Dec 2000 04:41:39
Message: <3a2b66d3@news.povray.org>
Wlodzimierz ABX Skiba <abx### [at] abxartpl> wrote:
: Should it be simple normalized summary of all normals
: or waighted one depend of areas of each triangle ?
  It depends on how you want it to look like.
  Try both methods with your object and choose the one you like the most.
Date: 4 Dec 2000 13:20:49
Message: <3A2BE07B.9EE186F8@spiritone.com>
Using Warps read me file for his mesh smoother, I find that normalizing
the normal vectors of each triangle, then averaging them, works the
best. Of course, if you are using the vcross command to find your
normals, remember that the length of the resultant vector has a length
of the dot product, which will be at it's maximum when the vectors are
orthogonal (ie, 90 degrees apart).
Since this doens't make a lot of sence, I'll try to have a few pictures
for you soon.
Josh
> Maybe other way ?
> ABX
eng### [at] spiritonecom
Date: 4 Dec 2000 13:38:39
Message: <slrn92np5i.mrd.ron.parker@fwi.com>
It's not the same as the dot product.  The length of the cross product
vector is A*B*sin(t) and the dot product is A*B*cos(t).
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 4 Dec 2000 15:01:57
Message: <3A2BF82F.BC751AD@spiritone.com>
I thought that I read in the docs that the length was the dot product, but
in fact they say "The resulting vector is perpendicular to the two original
vectors and its length is proportional to the angle between them." In my
experiments, that distance did seem to be at its largest when the vectors
were orthogonal.
Thanks for the clarification.
Josh
Date: 4 Dec 2000 15:40:25
Message: <slrn92o09s.ms8.ron.parker@fwi.com>
>were orthogonal.
Proportional to the sine of the angle between them.  Remind me to check the
docs when I get home.  Sine has a maximum at 90 degrees, so your experiments
were correct.
Date: 4 Dec 2000 15:51:49
Message: <3A2C04A9.5129AD6D@pacbell.net>
Ron Parker wrote:
> Remind me to check the docs when I get home.
Ron,
Check the docs when you get home.
Ken Tyler
Date: 5 Dec 2000 04:19:29
Message: <3a2cb321@news.povray.org>
Josh English wrote in message <3A2BE07B.9EE186F8@spiritone.com>...
normalizing
thanks. little more about my problem
I play with specialized patch for non-linear deforms
I have builded mechanizm to implement different types of deformations
geometry is supported ok but problem is with normals
first I thought just simple - (un)deform IPoint and IPoint+INormal
and calculate new normal
but this isn't correct -
therefore I discover such method:
find INormal and IPoint
find N points around of IPoint (with very small distance)
points are on flat plane perpendicular to normal
(un)deform points
now they are not on plane
this mean that my virtual smooth triangles are very small
I leave simple averaging normals
real problem will be with inherited nonlinear transformed textures....
ABX
Date: 5 Dec 2000 05:52:46
Message: <3a2cc8fe$1@news.povray.org>
>>were orthogonal.
>were correct.
Hm... it certainly does say "proportional to the angle".  That's a doc bug.
Date: 5 Dec 2000 06:18:37
Message: <3a2ccf0d@news.povray.org>
Josh English <eng### [at] spiritonecom> wrote:
: Of course, if you are using the vcross command to find your
: normals, remember that the length of the resultant vector has a length
: of the dot product, which will be at it's maximum when the vectors are
: orthogonal (ie, 90 degrees apart).
  Actually, the length of the normal vector calculated using cross-product
of two vectors is (also) exactly the area of the parallelogram formed by the
two vectors.
  To get the area of the triangle formed by the two vectors, divide the
length of the cross-product by 2.
