POV-Ray : Newsgroups : povray.advanced-users : Modeling a Brain with Povray Server Time
21 Feb 2025 13:21:16 EST (-0500)
  Modeling a Brain with Povray (Message 1 to 10 of 14)
Subject: Modeling a Brain with Povray
Date: 7 Jan 2003 21:30:51
Message: <3E1B8BD6.9040709@nodomain.com>
Hello guys, I was wondering if any of you have attempted to model a
brain with povray.
How would you go about creating such a complex structure?
Thanks in advance
Fidel.
Subject: Re: Modeling a Brain with Povray
Date: 8 Jan 2003 01:53:33
Message: <3e1bcaed$1@news.povray.org>
I would think about media with high turbulence. I don't have too much
experience with media though...
Date: 8 Jan 2003 02:40:31
Message: <3e1bd5ef$1@news.povray.org>
hey guys
i would propably go for sphere_sweeps. they would also look "real" in a
closer view.
i thought somewhere on the net existed already such a project..
*asking the great oracle of google*
oh, there are _several_ such projects. i'm afraid they're not using pov, but
this page for example can show you how it could look like:
http://astronomy.swin.edu.au/~pbourke/modelling/cortex/impl.html
the fastest solution (both in creation and rendering time) would imho be to
search for a existing mesh-model. but it's rather boring. if you got the
time, make one up in pov, it would be great!
greetings:florian
Date: 8 Jan 2003 02:46:01
Message: <Xns92FD597463D53seed7@povray.org>
> pov, but this page for example can show you how it could look like:
Find a brain data-set, convert it to df3 and render it as an
isosurface.The first part wil be the problem :(
Ingo
Date: 8 Jan 2003 02:53:56
Message: <06mn1vo6rfqkprt50qa73osnhm8r4vb3fr@4ax.com>
I have not investigated it much but perhaps
http://www.google.com/search?q=brain+surface+data could be enough ?
ABX
Date: 8 Jan 2003 05:57:56
Message: <Xns92FD79FF373CAseed7@povray.org>
http://graphics.stanford.edu/data/voldata/
Ingo
Date: 8 Jan 2003 13:07:26
Message: <3E1C6759.3010501@nodomain.com>
> Ingo
Hi Guys, thanks for the information. I am not familiar with df3, and I
need to have a look at isosurfaces. Is there a good tutorial on how to
process df3 files? And what about its format?
Does the povray manual cover it? I couldn't find it. I'll double check
it anyway.
All the best and thank you.
Fidel.
Date: 10 Jan 2003 11:02:56
Message: <3e1eeeb0$1@news.povray.org>
"fidel viegas" <fid### [at] nodomaincom> wrote in message
news:3E1### [at] nodomaincom...
> brain with povray.
> Thanks in advance
> Fidel.
I played around with doing this (for a brain coral).
Wouldn't do if the brain was the main component of the scene, but might be a
help if it's just a few of 'em in jars on a backshelf or something...
#include "functions.inc"
#declare F_1 = function(x,y,z){(pow(x,2)+pow(y,2)+pow(z,2)) +
f_ridged_mf(x*10,y*10,z*10,1,1,1,1,0,3)/5 - 2}
#declare Brain1 =
isosurface {
  function {F_1(x,y,z)}
  max_gradient 20
  contained_by {box {-5,5}}
  pigment { rgb<0.7,0.5,0.5> }
object{Brain1}
Date: 10 Jan 2003 11:39:09
Message: <Xns92FFB3D8FE701seed7@povray.org>
> process df3 files?
No, but there is a tga2df3 convertor at http://www.users.on.net/pod/df3/
See 6.7.11.11  Density_File
Ingo
Date: 10 Jan 2003 18:23:52
Message: <3E1F547C.8040504@nodomain.com>
>>process df3 files?
Thanks for the link. I've looked into it already.
I also read this on the documentation. Now I came across another program
called df3maker and it takes text version of the data and outputs the
binary version. I know how to create the binary file, but I have a doubt
regarding its format. I found the data below at the df3maker web site:
4,3,5
0,50,50,0
50,100,100,50
0,50,50,0
10,100,100,10
100,200,200,100
10,100,100,10
50,150,150,50
150,255,255,150
50,150,150,50
10,100,100,10
100,200,200,100
10,100,100,10
0,50,50,0
50,100,100,50
0,50,50,0
Ok, I understand the 4, 3 and 5, which are the dimensions of the cube in
x, y and z respectively. My question is how do we come up with the data
values? In the docs it had x*y*z, does it mean that each cell is the
result of multiplying x, y and z? For instance the second value 50, is
it the result of this multiplication?
Another question is regarding the tga2df3 converter. How does the 2D
grid of pixels found in a tga picture translate to a 3D grid?
I hope my queries are clear.
Thanks once again.
You guys have been great.
Fidel.
