POV-Ray : Newsgroups : povray.advanced-users : Dual Processor Server Time
10 Jun 2026 00:27:51 EDT (-0400)
  Dual Processor (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: Dual Processor
Date: 13 Dec 2002 17:44:24
Message: <3dfa62c8$1@news.povray.org>
Thorsten Froehlich wrote:
> In article <3DFA3237.11DDBAAE@mail.com> , Gena <obu### [at] mailcom>
> wrote:
>> I ran standard POV-Ray 3.5 as the only task on dual processor machine
>> under Windows XP. Does that mean that it will use both processors ?
> Read the manual, section "9.1.3.2 Can POV-Ray use multiple
> processors?"
Then post in p.g asking 'SMP.... When.....'
PGP Public Key
Version: 6.0.427 / Virus Database: 240 - Release Date: 06/12/2002
Date: 20 Dec 2002 20:34:12
Message: <3E03C50E.A13D0D0E@mail.com>
Is there any trick which I should use if I want to start many instances of
POV-Ray under Windows XP ? It looks like I cannot do that just clicking
shortcut. It always brings up the first copy.
Gena.
> In article <3DFA3237.11DDBAAE@mail.com> , Gena <obu### [at] mailcom>  wrote:
> Read the manual, section "9.1.3.2 Can POV-Ray use multiple processors?"
> > Should I use any non-official build to utilize both processors (PVMPOV
> > or smth. like that)?
> If you want to.
>     Thorsten
> ____________________________________________________
> Thorsten Froehlich, Duisburg, Germany
> e-mail: tho### [at] trfde
> Visit POV-Ray on the web: http://mac.povray.org
Date: 20 Dec 2002 21:15:35
Message: <chrishuff-2A71E9.21102920122002@netplex.aussie.org>
I think unchecking "Keep Single Instance" in the Options menu will give
the behavior you want.
http://tag.povray.org/
Date: 21 Dec 2002 07:40:51
Message: <3e046153$1@news.povray.org>
>> instances of POV-Ray under Windows XP ? It looks like I cannot do
>> that just clicking shortcut. It always brings up the first copy.
> give the behavior you want.
Just remember to assign each instance of povray to a seperate CPU in task
manager before you start rendering
PGP Public Key
Date: 21 Dec 2002 08:45:52
Message: <3e04708f@news.povray.org>
  It would be incredibly stupid multitasking from WinXP if it
assigned two extremely heavy processes to the same processor, while the
other processor is mostly idle.
  I don't believe that even MS can do things that bad.
Date: 21 Dec 2002 13:56:39
Message: <3e04b967@news.povray.org>
>> task manager before you start rendering
> the other processor is mostly idle.
It dosnt know a process is going to be a heavy one when it decides which
processor it will be running on, it just sticks it on the CPU that at that
instant has less load.
PGP Public Key
Date: 21 Dec 2002 15:26:59
Message: <3e04ce93@news.povray.org>
  You mean it can't switch a process from one processor to another on
the fly?-o
  That's hard to believe (no matter how much I would like to believe
something like that from MS). AFAIK that doesn't involve anything
complicated for a multitasking manager.
Date: 21 Dec 2002 15:36:45
Message: <3e04d0dd@news.povray.org>
In article <3e04b967@news.povray.org> , "Rick [Kitty5]" <ric### [at] kitty5com>
No, that isn't how scheduling works.  The next process in the queue will
always be scheduled on the next processor available.  It would be a lot more
difficult to implement it any other way.  And in fact the performance
problems one may get when using the P4 SMT feature suggest that this works
the same on WinDOS.
    Thorsten
Date: 22 Dec 2002 05:06:56
Message: <3e058ec0$3@news.povray.org>
> will always be scheduled on the next processor available.
Which is what I said
PGP Public Key
Date: 22 Dec 2002 09:16:31
Message: <3e05c93f@news.povray.org>
In article <3e058ec0$3@news.povray.org> , "Rick [Kitty5]" <ric### [at] kitty5com>
No, you did not, or at least you don't understand why using this algorithm
will cause two "heavy" processes to end up on two different CPUs exactly as
they should!
    Thorsten
