POV-Ray : Newsgroups : povray.advanced-users : Tetrahedron Macro that uses Prism primative Server Time
17 May 2026 21:07:08 EDT (-0400)
  Tetrahedron Macro that uses Prism primative (Message 5 to 14 of 24)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Tetrahedron Macro that uses Prism primative
Date: 7 Dec 2002 04:42:43
Message: <3DF1C3CD.A9BA456F@hotmail.com>
Warp wrote:
> Dan Johnson <zap### [at] hotmailcom> wrote:
> > Anyone know if this approach
> > is actually faster than plane intersections?
>   There was once a long thread in some group about the most efficient way
> of making a box with all six sides textured differently.
>   Several approaches were made and their rendering times measured. For
> example it was done with the intersection of six planes, the union of
> six 2-dimensional boxes, six polygons and a mesh. (Also using a single
> box with a clever pattern was suggested, but that's irrelevant in this case).
>   Perhaps a bit surprisingly, with such a low triangle count the mesh was
> not the fastest option. I don't remember which one was, but it might have
> been the union of polygons. (The problem with it is that it's not usable
> in CSG.)
Interesting..
>   In your case the intersection of planes might be just ok. You simply have
> to manually bound the tetrahedron eg. with a sphere.
If my thinking is correct that can be done such that each vertex is
exactly on the surface of the sphere.
>   You might also try using a mesh (with inside_vector you can make it
> CSG'able). If you don't need to use the tetrahedron in CSG, you might want
> to try a union of four triangles, or even polygons, though I doubt it will
> be faster than the union of triangles.
>   I think that with such a low triangle count, the union of triangles may
> be faster than a mesh.
Of course a union of triangles is so much easier that what I did.  I
used more than one in the process of debugging my code.  CSG is
important for pretty much everything I ever do.
> #macro N(D)#if(D>99)cylinder{M()#local D=div(D,104);M().5,2pigment{rgb M()}}
> N(D)#end#end#macro M()<mod(D,13)-6mod(div(D,13)8)-3,10>#end blob{
> N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}//  - Warp -
Dan Johnson
http://www.livejournal.com/userinfo.bml?user=teknotus
http://www.geocities.com/zapob
Date: 7 Dec 2002 12:18:20
Message: <chrishuff-34E328.12151607122002@netplex.aussie.org>
In article <3df1b593@news.povray.org>, Warp <war### [at] tagpovrayorg>
Did anyone try using "heirarchy off"? With 4 triangles arranged like
that, it has to be more overhead than benefit.
http://tag.povray.org/
Date: 7 Dec 2002 15:30:20
Message: <chrishuff-E9ABBB.15271707122002@netplex.aussie.org>
In article <3DF1C3CD.A9BA456F@hotmail.com>,
You are correct (assuming no uneven scaling or shearing), but I think a
box would be a better choice. A sphere doesn't fit a tetrahedron that
closely, a box isn't much if at all better but is faster to test.
Date: 7 Dec 2002 17:19:19
Message: <3df273e6@news.povray.org>
  Have you actually made the math, which shape "wastes" more space when
bounding (optimally) a regular tetrahedron ("regular" meaning all sides
have the same length), the sphere or the box?
  I wouldn't be so sure that the optimal box is smaller than the optimal
sphere ("smaller" meaning that its volume is smaller), although I can't
be sure of the contrary either.
  Also I think that a ray-sphere intersection is faster than a ray-box
intersection, so the sphere is in that sense a better bounding object.
Date: 7 Dec 2002 20:22:46
Message: <3DF2A029.A55D1FD2@hotmail.com>
In my example one of the tetrahedrons is regular, and exactly fits
inside a 2X2X2 box.  Both exactly fit in a sphere with radius sqrt(3).
object{Tet_prism(<1,1,1>,<-1,1,-1>,<1,-1,-1>,<-1,-1,1>) pigment{Green}
finish{Dull}}
box{-1,1 pigment{color rgbft<1,0,0,0,.6>}finish{Dull}}
sphere{0,pow(3,(1/2)) pigment{color rgbft<0,0,1,0,.8>}finish{Dull}}
sphere {<1,1,1>,.1 pigment{Yellow}}
sphere {<-1,1,-1>,.1 pigment{Yellow}}
sphere {<1,-1,-1>,.1 pigment{Yellow}}
sphere {<-1,-1,1>,.1 pigment{Yellow}}
Don't know about using a box to bound an irregular tetrahedron.  Sounds
relatively tricky.
Dan Johnson
Date: 8 Dec 2002 14:50:59
Message: <chrishuff-4B87D1.14475808122002@netplex.aussie.org>
In article <3df273e6@news.povray.org>, Warp <war### [at] tagpovrayorg>
Ok, for a tetrahedron with these corners:
<-1, 1,-1>
< 1, 1, 1>
<-1,-1, 1>
< 1,-1,-1>
(regular tetrahedron, every point equidistant from the other three)
The radius of a perfect bounding sphere is sqrt(3). Volume is pi*3/4*r^3
= 21.763 cubic units. The volume of the perfect axis-aligned bounding
box is 8 cubic units, though it will increase for other orientations (I
think the worst case makes for a bounding box sqrt(8)xsqrt(8)x2, 16
cubic units.
I think the "average visible area" would make a better measurement than
volume, though much harder to compute. And the difference is bigger than
I expected, but I can't find anything wrong with my math, please
re-check it.
Hmm...the bounding box calculation is very well optimized, I think it
only requires 3 intersections with axis-aligned planes and some code for
clipping that. A sphere is fast, but I think a bounding box is faster.
However, I'm not too sure how the bounded_by keyword fits in with the
bounding box heirarchy...it looks like a bounding box is always used,
which bounds the bounding shapes (multiple?), which bound the object.
Much of the bounding code seems to be very per-object...it's pretty
disorganized, and probably not as fast as it could be.
Date: 8 Dec 2002 14:53:39
Message: <chrishuff-CEFA0F.14503708122002@netplex.aussie.org>
In article <3DF2A029.A55D1FD2@hotmail.com>,
> relatively tricky.
Finding an optimal axis-aligned bounding box is very easy, just find the
min and max extents of all four points. A sphere or an aligned bounding
box would be trickier.
Date: 11 Dec 2002 11:45:09
Message: <3df76b95@news.povray.org>
"Dan Johnson" <zap### [at] hotmailcom> wrote in message
news:3DF1C3CD.A9BA456F@hotmail.com...
way
case).
was
have
> > in CSG.)
> Interesting..
have
I bet the Graphics Gems books have code that will allow you to determine a
sphere tangential to 4 points in 3-space.  The code for those books can be
found on-line.
Date: 11 Dec 2002 11:48:43
Message: <3df76c6b$1@news.povray.org>
> all that testing though.  It sounded like a lot of work.  I thought
> perhaps someone might have immediate need for millions of tetrahedrons.
> Well no I didn't, but I can dream can't I?  Today I was thinking, and I
Actually, I was considering rendering a D&D game with a 17,000,000th level
wizard casting Magic Missile...  ;-)
Date: 11 Dec 2002 20:57:32
Message: <3DF7EBBA.4A556875@hotmail.com>
> have
> found on-line.
I once made a macro for POV that finds such a sphere,
but I'm afraid that a sphere that tuches all the 4
vertexes will not be the optimal solution in all cases.
In fact it will sometimes be a very non-optimal sphere to
choose for bounding of tetrahedrons.
But if anyone is interested in having a look at my macro,
then it can be found here:
http://news.povray.org/povray.general/17701/?mtop=114652&moff=22
news://news.povray.org/3B82F267.36412849%40hotmail.com
Tor Olav
