POV-Ray : Newsgroups : povray.advanced-users : Tetrahedron Macro that uses Prism primative Server Time
17 May 2026 19:51:36 EDT (-0400)
  Tetrahedron Macro that uses Prism primative (Message 15 to 24 of 24)
Subject: Re: Tetrahedron Macro that uses Prism primative
Date: 12 Dec 2002 02:12:49
Message: <6ldgvu8m3haqih3b2cud5narcqn8p82pvi@4ax.com>
On Wed, 11 Dec 2002 11:45:10 -0500, "Rick Gutleber" <ric### [at] hiscom>
wrote:
>I bet the Graphics Gems books have code that will allow you to determine a
>sphere tangential to 4 points in 3-space.  The code for those books can be
>found on-line.
There sure is, but keep in mind that the circumscribed sphere is
usually not the smallest sphere containing four points.
Peter Popov ICQ : 15002700
Date: 13 Dec 2002 03:11:18
Message: <3DF9974D.975896FD@hotmail.com>
Rick Gutleber wrote:
> Actually, I was considering rendering a D&D game with a 17,000,000th level
> wizard casting Magic Missile...  ;-)
> Rick
I didn't know that there have been enough hours since the game was
invented for anyone to get to the 17 millionth level.  Must be quite
some D&D player.  Or is this a theoretical character, or a non player
character.  I once encountered a game bug that gave me perfect stats.
Well except for luck.  My luck in the game was so awful that people in
proximity to my character would do things like critically miss, and kill
themselves.  I had an aura of bad luck.  Or was that a different game?
Dan Johnson
http://www.geocities.com/zapob
Date: 16 Dec 2002 19:10:23
Message: <3dfe6b6f@news.povray.org>
If the points are _tangential_ to the sphere, wouldn't there only be one
solution?
"Peter Popov" <pet### [at] vipbg> wrote in message
news:6ldgvu8m3haqih3b2cud5narcqn8p82pvi@4ax.com...
a
be
> >found on-line.
> Personal e-mail : pet### [at] vipbg
> TAG      e-mail : pet### [at] tagpovrayorg
Date: 16 Dec 2002 20:35:03
Message: <web.3dfe7e1187ba9bcf38149fba0@news.povray.org>
>solution?
Rick,
I don't think one can say about points
that they can be tangential to anything.
You probably mean that they are on the
surface of the sphere.
If you have four points in 3D space that
are not coplanar (*), then yes; there
are only one specific sphere that have
them all on its surface. (And the macro
I mentioned in my other post finds that
very sphere.)
This sphere will, of coarse, enclose a
tetrahedron that has these four points
as its vertices.
But as Peter and I pointed out, this is
not always the most optimal sphere to
choose for bounding of such a tetrahedron.
It will in some cases be possible to
find spheres with smaller radii, that
encloses the tetrahedron.
And in these cases only 2 or 3 of the
4 points (vertices) will be on the surface
of the sphere. The other 2 or 1 will be
inside it.
The problem is now to find the bounding
sphere with the smallest radius.
(*) More precisely I mean:
vdot(p1 - p0, vcross(p2 - p0, p3 - p0)) != 0
Tor Olav
>news:6ldgvu8m3haqih3b2cud5narcqn8p82pvi[at]4ax.com...
>a
>be
>> >found on-line.
Date: 16 Dec 2002 21:16:45
Message: <chrishuff-01A022.21121216122002@netplex.aussie.org>
In article <3dfe6b6f@news.povray.org>, "Rick Gutleber" <ric### [at] hiscom>
> solution?
He said that the circumscribed sphere (with all points on the sphere)
wasn't the smallest sphere *containing* the points. In some cases, the
smallest sphere touches only 2 or 3 points.
For a regular tetrahedron, the smallest sphere does touch all 4 points.
http://tag.povray.org/
Date: 17 Dec 2002 12:33:49
Message: <3dff5ffd@news.povray.org>
> inside it.
I seem to remember the sequence goes something like this:
Find the two points furthest apart and set a sphere so that they are on
the diameter. If both other points are inside the sphere you are done.
If one or two points are outside the sphere find the point furthest
outside the sphere. Produce the sphere that has the circumcircle of the
three points as its great-circle. If the fourth point is inside this
Otherwise find the sphere with all four points on the surface.
I think this is right ...
Mike Andrews.
Date: 17 Dec 2002 14:49:57
Message: <3DFF8126.37A7E1BE@hotmail.com>
> Mike Andrews.
I think you are right.  I don't think it would be too hard to make a
macro to do that either.  Now I guess the next thing is to find the
smallest oriented bounding box, and see which one is smaller.  If one is
always smaller.
Dan Johnson
http://www.livejournal.com/userinfo.bml?user=teknotus
Date: 17 Dec 2002 15:10:15
Message: <3DFF85CA.6BBEFADF@hotmail.com>
> always smaller.
Do bounding boxes with sheer work?  If they do I think you can get even
closer.  Then you could define it as a cube, and a matrix.  I think that
in an ideal bounding box all vertices would also be vertices of the
inclosed tetrahedron.
Dan Johnson
Date: 17 Dec 2002 16:07:20
Message: <3dff9208@news.povray.org>
Yes, of course, you're right about my wording.  I see what you are talking
about WRT to the smallest sphere, too.  Nearly coplanar points would produce
an enormous sphere if you only allowed the points to be on the surface of
the sphere.
"Tor Olav Kristensen" <tor### [at] hotmailcom> wrote in message
news:web.3dfe7e1187ba9bcf38149fba0@news.povray.org...
> >solution?
> Rick,
> very sphere.)
> as its vertices.
> inside it.
> Tor Olav
determine
> >a
can
> >be
> >> >found on-line.
Date: 17 Dec 2002 16:31:50
Message: <chrishuff-29F656.16265717122002@netplex.aussie.org>
In article <3DFF8126.37A7E1BE@hotmail.com>,
> always smaller.
I am almost certain the box is always smaller. The optimal sphere
bounding is a circumscribed sphere around a regular tetrahedron. The
optimal box bounding of that tetrahedron would have each corner of the
tetrahedron at a corner of the box, the least optimal (I think) would
have two edges of the tetrahedron against opposing faces of the box,
parallel to different axii (the best case, rotated 45 degrees around one
axis).
For a regular tetrahedron with 1-unit edges, the best bounding sphere
has a radius of sqrt(3)/sqrt(8) (~0.612), the best-case box a
2/sqrt(8)-unit (~0.707) cube, the worst-case box a 1x1x2/sqrt(8)
(1x1x~0.707) box. The sphere has a volume of 0.96 units^3, the cube
0.353 units^3, and the box 0.707 units^3.
For optimal bounding of irregular tetrahedrons, both will be less
efficient, but I think a box will always be better. Even if the
tetrahedron is a thin rod along a diagonal of the box (the worst case),
the sphere will have a larger volume (having a diameter about equal to
the length of the diagonal of the box).
This is for axis-aligned boxes, if you use oriented boxes the bounding
of a regular tetrahedron or some irregular tetrahedrons (those you can
get by applying an affine transformation to a regular tetrahedron) is
always the best case, for other tetrahedrons it still improves.
