I need a way to visualize the Birth-Field of my
Particle-System. What I came up with, is a macro,
which you call like this:
Birth_Field(texture{})
It would then create and place an object in scene
according to the birth-field of the most recent
system.
Question is: Is there a way can avoid the texture{}?
I would like to make it very easy to use, like a
POV-Primitive. Thus, I'd like to have the macro
handle a material{...}, a pigment{} or texture{}.
So, the essential question is:
Is it possible for POV to just take the given input
and place it in an object, regardless of how it looks
like (as long as its in correct POV-SDL, something
like
Birth_Field( do something )
shouldn't work of course...
Tim Nikias
Email: Tim### [at] gmx de
If I understand what you want then using POV3.5 try .
#macro Birth-Field (String)
Parse_String(String)
The String could be a material{...}, a pigment{} or texture{} or any thing you
want.
> system.
> like
> Tim Nikias
> Homepage: http://www.digitaltwilight.de/no_lights/index.html
Have Fun!
Subject: Re: Parameters sent to Macros... Question:
Date: 29 May 2002 13:01:13
Message: <3CF50946.BAB6A393@gmx.de>
Ha! I looked at the macro and found what I expected:
File I/O.
I was thinking about doing just that, but wasn't sure if there
was some POV-internal (and thus faster, almost everything
hardcoded is faster) way.
So, I'll write my own macro for that, as I always do...
But thanks for the suggestion!
> #end
> want.
> > system.
> > like
> > Tim Nikias
> Have Fun!
Tim Nikias
