Hi Folks,
I was playing with Gilles' cloud pigment and hit a problem: what is the
best (ie fastest rendering) way to reproduce an arbitrary pigment from
it's function?
For example, given
#declare PIG = pigment { bozo colour_map {[0.2 rgbf 1][0.5 rgb
y*1.3][0.7 rgb x transmit 1] } }
#declare FNPIG = function { pigment { PIG } }
#declare REBUILD = pigment { ... }
how do you define REBUILD to give the same pigment as PIG, based on
FNPIG?
Normally it's just a matter of
average
pigment_map {
[1 function { FNPIG(x,y,z).x } colour_map {[0 rgb 0][1 rgb 3*x]} ]
[1 function { FNPIG(x,y,z).y } colour_map {[0 rgb 0][1 rgb 3*y]} ]
[1 function { FNPIG(x,y,z).z } colour_map {[0 rgb 0][1 rgb 3*z]} ]
but with filter, transmit or colours with values greater than one this
doesn't work.
I've come up with one structure which works, but is very slow for how I
am using it.
So, I was hoping someone can come up with a better method. Any takers?
Bye for now,
Mike Andrews.
On Wed, 10 Apr 2002 14:12:15 +0100, Michael Andrews <m.c### [at] reading ac uk>
> average
> pigment_map {
>doesn't work.
have you teste below ? I'm not sure but I think it should work
average
pigment_map {
[1 function { FNPIG(x,y,z).red } colour_map {[0 rgb 0][1 red 5]} ]
[1 function { FNPIG(x,y,z).green } colour_map {[0 rgb 0][1 green 5]} ]
[1 function { FNPIG(x,y,z).blue } colour_map {[0 rgb 0][1 blue 5]} ]
[1 function { FNPIG(x,y,z).filter } colour_map {[0 rgb 0][1 filter 5]} ]
[1 function { FNPIG(x,y,z).transmit } colour_map {[0 rgb 0][1 transmit 5]} ]
ABX
Sorry, no, this is always black :-/
I hadn't thought of trying this way though ...
Bye for now,
Mike Andrews.
> FNPIG?
AFAIK, it's not currently possible.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
> > FNPIG?
Well, yes it is possible (see the picture I just posted in Gilles' fast
cloud thread on p.b.i) but the method I've found is pretty brute-force
and klutzy. I was hoping somone would have a bright idea on how to do it
better than I have. That's why I haven't posted my attempt yet - I don't
want to predispose folks to look at the problem from one direction.
If noone comes up with anything by the weekend I'll post my solution.
Bye for now,
Mike Andrews.
On Thu, 11 Apr 2002 13:18:26 +0100, Michael Andrews <m.c### [at] reading ac uk>
layers ?
ABX
__________________
RAY
"Michael Andrews" <m.c### [at] reading ac uk> wrote in message
news:3CB### [at] reading ac uk...
> Hi Folks,
> it's function?
> For example, given
> FNPIG?
> average
> pigment_map {
would #declare REBUILD = pigment {function {FNPIG}}; work
> doesn't work.
> am using it.
Yes ;-)
average
pigment_map {
[1 function{FNPIG(x,y,z).red} colour_map {[0 rgbft<-2, 0, 0, 0,
0>][1 rgbft< 3, 0, 0, 0, 0>]}]
[1 function{FNPIG(x,y,z).green} colour_map {[0 rgbft< 0,-2, 0, 0,
0>][1 rgbft< 0, 3, 0, 0, 0>]}]
[1 function{FNPIG(x,y,z).blue} colour_map {[0 rgbft< 0, 0,-2, 0,
0>][1 rgbft< 0, 0, 3, 0, 0>]}]
[1 function{FNPIG(x,y,z).filter} colour_map {[0 rgbft< 1, 1, 1, 0,
0>][1 rgbft< 1, 1, 1, 5, 0>]}]
[1 function{FNPIG(x,y,z).transmit}colour_map {[0 rgbft< 1, 1, 1, 0,
0>][1 rgbft< 1, 1, 1, 0, 5>]}]
This seems to work. I'm fairly certain the math is OK, but I still have
to mull it over. Seemed to worked in a visual comparison test with the
original and rebuilt pigments side by side.
> > > FNPIG?
> Bye for now,
> Mike Andrews.
...except it still will not work for color component values outside of
the range of 0 to 1 since the technique is limited by the color_map
index range. A workaround (if one knew beforehand the color range) would
involve scaling FNPIG by 1/[maximum expected color range] and setting up
the color_map entries to cover the maximum expected color range.
Abe
> average
> pigment_map {
> > > > FNPIG?
> > Bye for now,
> > Mike Andrews.
"RAY" <RAY### [at] yahoo com> wrote in message news:3cb73511@news.povray.org...
> __________________
> RAY
> > Hi Folks,
> > it's function?
> > For example, given
Replace this with a five-parameter function:
#declare FNPIG = function(rd,gr,bl,ft,tr) { pigment { PIG } }
> > FNPIG?
> > average
> > pigment_map {
After replacing the FNPIG function, the simple declare should work:
#declare REBUILD = pigment { function(rd,gr,bl,ft,tr) {FNPIG}}
> > doesn't work.
> > am using it.
> Yes ;-)
