POV-Ray : Newsgroups : povray.advanced-users : Memory questions... Server Time
25 Mar 2026 22:46:49 EDT (-0400)
  Memory questions... (Message 1 to 8 of 8)
Subject: Memory questions...
Date: 28 Mar 2002 16:50:52
Message: <3CA39043.4D0DF734@gmx.de>
So, when using meshes in unions, how efficiently are they saved?
How do unions save anyway?
How are scaled instances of meshes handled?
When putting a union around 2000 spheres and cylinders,
does it make a difference when using instances of that
union-object, or when rather placing several of those
2000 spheres and cylinders directly?
Just some "trivia" for memory stuff I would like to know
for some macros and file-output etc. Anything related to
the questions may be mentioned as well, I'm really interested!
Tim Nikias
Subject: Re: Memory questions...
Date: 28 Mar 2002 17:30:37
Message: <chrishuff-4E37BC.17312228032002@netplex.aussie.org>
In article <3CA39043.4D0DF734@gmx.de>, Tim Nikias <tim### [at] gmxde>
A copy of a union containing a mesh will get a copy of the mesh, but
that mesh copy will only contain a reference to the original data, just
like ordinary mesh copies. (I'm making an assumption here, I haven't
tested this...but if it does something different it is probably a bug)
They generally don't. They are intended to make manipulating shapes more
convenient. They are also useful because they can help you set up a
bounding tree to speed tracing, but they don't help memory use at all.
The transformations are stored separately from the mesh data. Scaling a
mesh doesn't affect the data.
No substantial difference. If you make a union, POV obviously has to
store the union itself, but that doesn't take much space. If you are
asking if unions also use the shared data method meshes use, the answer
is no.
Date: 28 Mar 2002 18:48:42
Message: <3CA3ABE1.C494E997@gmx.de>
Ah, some insights! Thank you very much!
If anyone else has some more related insights tucked
up in their brains somewhere... I'm listening!
Tim Nikias
Date: 28 Mar 2002 21:37:35
Message: <3ca3d36f@news.povray.org>
  However, you should note that using a sphere-shaped mesh and copying
this mesh many times will not save any considerable amount of memory
compared to using just regular spheres.
  You will start saving substantial amounts of memory if you make a mesh
with many spherical shapes (eg. tens or hundreds of spheres) and copy this
mesh. Of course it is only possible if there are big groups of spheres which
can be copied as is.
  That is, it's important to make 1 mesh with many spheres in it, and then
copy that mesh (if it's possible in the used model), not making a mesh
with 1 sphere and copying that.
  (Of course I used "sphere" as an example shape. You can, of course, use
any shapes you like.)
Date: 29 Mar 2002 13:16:08
Message: <3CA4B073.401F524B@hotmail.com>
> more convenient. They are also useful because they can help you set up
> a bounding tree to speed tracing, but they don't help memory use at
> all.
Exception:  If all of the objects in a union will have the same
texture, apply the texture to the union.  That saves memory.
Rusty is rendering!
Date: 29 Mar 2002 13:52:24
Message: <mbd28a.q82.ln@linux.local>
> If you are asking if unions also use the shared data method meshes
> use, the answer is no.
Why isn't that possible? Where is the difference to storing mesh data?
(This is not a feature request, just a question :) )
Felix Wiemann
Date: 29 Mar 2002 15:43:56
Message: <chrishuff-F31D9C.15444729032002@netplex.aussie.org>
In article <mbd### [at] linuxlocal>,
It is possible, it would just require redesigning and rewriting the
code. Since a rewrite is planned already for POV-Ray 4.0, there isn't
much point in doing it for 3.5.
One of the possible problems is that the parts of a union are
individually transformable objects, while mesh data is a bunch of points
that are never changed. When transforming a union, I think the current
version of POV transforms the individual objects contained in it.
Storing a reference to the data would mean no union could modify the
data, so would have to store its own transforms. Slightly slower.
A better solution might be a proxy or clone object that is simply a
wrapper for a pointer to another object and some object-specific
information. That way, you could use this object to get
copy-by-reference when necessary without the speed penalty for normal
use.
Date: 29 Mar 2002 17:35:01
Message: <3ca4ec15@news.povray.org>
  Note that this transformation is optimized for many primitives.
For example, translating, rotating or scaling uniformly a sphere does not
add a transformation matrix to the sphere, but just modifies its center
point and radius as needed.
