POV-Ray : Newsgroups : povray.advanced-users : regular polyhedra as solids Server Time
16 Jun 2026 08:54:37 EDT (-0400)
  regular polyhedra as solids (Message 1 to 3 of 3)
Subject: regular polyhedra as solids
Date: 17 Mar 2002 03:22:29
Message: <3C9452AC.3BEEE7D5@pandora.be>
In the binaries newsgroup often appear examples of the 5 regular
polyhedra (the Platonic solids). In most cases they are constructed as
the union or merge of triangles or polygons.
For some application I wanted to apply CSG (difference) on some of those
objects, but for a reason unknown to me this failed. I have the
impression that the union or merge of triangles or polygons doesn't
produce a solid.
Is this exact and if so what can be done to define those objects as
solids.
Thanks,
Herman Serras
Gent (Belgium)
http://cage.rug.ac.be/~hs/
Subject: Re: regular polyhedra as solids
Date: 17 Mar 2002 04:08:38
Message: <3C945D15.2B6986FE@gmx.de>
> produce a solid.
> solids.
> Thanks,
Only objects with defined inside and outside can be used in CSG. Meshes,
triangles and polygons do not.
Have a look at 'shapes2.inc' for CSG-able versions of those shapes.  Note
that right now these shapes are unbounded so they render quite slow.
Last updated 13 Mar. 2002 _____./\/^>_*_<^\/\.______
Date: 19 Mar 2002 03:28:39
Message: <3c96f6b7@news.povray.org>
"Herman Serras" <Her### [at] pandorabe> wrote in message
news:3C9452AC.3BEEE7D5@pandora.be...
> produce a solid.
You can try to use prisms instead.
Gleb
