POV-Ray : Newsgroups : povray.advanced-users : Photon lightmapping questions: Server Time
24 Aug 2025 21:35:56 EDT (-0400)
  Photon lightmapping questions: (Message 1 to 5 of 5)
Subject: Photon lightmapping questions:
Date: 23 Jan 2002 14:02:22
Message: <3C4F089A.6D586854@gmx.de>
Hi there!
I've gotten stuck in an image I'm working on and would like
some information regarding photon lightmapping:
Are the photons brightness dependant on the lightsources RGB
they are shot from? Or are the RGB-values normalized?
Is there a way to use colored photons without showing the
lightsource (and its normal effects of colored lighting)?
If you have a look at the "WIP Sculpt ..." in povray.binaries.images,
you'll see where I'm actually targeting my questions on, and might
know some solution to what I trying to do...
Thanks in advance!
Tim Nikias
Subject: Re: Photon lightmapping questions:
Date: 24 Jan 2002 23:25:58
Message: <chrishuff-178100.23271624012002@netplex.aussie.org>
In article <3C4F089A.6D586854@gmx.de>, Tim Nikias <tim### [at] gmxde>
They are dependant on the brightness of the light. Double the brightness
and your caustics get brighter, any other way wouldn't make sense.
You mean you want caustics to be colored, but direct lighting to be
white? Why?
It could probably be done with light groups, but I haven't done anything
with that particular feature...maybe a colored light which shoots
photons at an invisible "ghost object", but doesn't interact with
anything else, and a white light which interacts with the scene,
including a "real" version of the object.
The light source itself will only be visible if you use looks_like or
scattering media.
I'm not really certain what you're asking...it looks like you
accomplished what you wanted.
Date: 25 Jan 2002 08:48:44
Message: <3C51621B.2B9642DE@gmx.de>
> white? Why?
In the mentioned image "WIP-Sculpt", the reflection of photons cause them
to gradually change their color (into something more greenish, because
the surface-pigment is rgb <1,.5,0>, and at some point, I get lots of
red and some green photons). I wanted to have only orange photons,
not ones with changing colors (looks somewhat strange, even if
calculation-wise correct). But the scene itself should be lit with white...
I could try that, good idea, though I think I'll leave my Sculpt finished
now...
> scattering media.
Yup.
I already mentioned what I wanted above, so I won't duplicate
my sentences (#if (Words=Said) #avoid Spam #end).
Thanks for the answers, it helped (or will, to be honest).
Tim Nikias
Date: 25 Jan 2002 10:51:49
Message: <chrishuff-0F3B99.10531225012002@netplex.aussie.org>
In article <3C51621B.2B9642DE@gmx.de>, Tim Nikias <tim### [at] gmxde>
Are you using metallic reflection? If not, try turning it on by putting
"metallic" in the reflection{} block.
It looks like you are, though...the scene looks right to me.
Photons that reflect more than once are goint to get darker and closer
to red, I think the only way to get what you want is to make the surface
yellower. Or maybe you could try giving reflection a color...you might
need to turn metallic reflection off then. As I said though, the scene
looks right to me as it is...
Date: 25 Jan 2002 11:24:37
Message: <3C5186A5.E2815A34@gmx.de>
I am.
I tried the above mentioned variations, but they all didn't turn out
as I expected them to (wanted them to, to be more precise ;)
Well, thanks for your suggestions and insight!
Tim
Tim Nikias
