POV-Ray : Newsgroups : povray.advanced-users : Re: Problem with Bicubic Patch Server Time
30 Sep 2024 00:11:42 EDT (-0400)
  Re: Problem with Bicubic Patch (Message 1 to 3 of 3)
Subject: Re: Problem with Bicubic Patch
Date: 5 Jul 2001 11:32:39
Message: <3B4488E8.6F2EF805@gmx.de>
Eli Ewok Brody wrote:
>  All --
>     I'm sure this has been a problem before, perhaps even solved before. At
> any rate, I am becoming desperate. sPatch objects (eg. Unions of bicubic
> patches) do not support world xyz coords. This turns shading into a
> nightmare. I've tried lots of combinations - not making it a union, merging
> them, assigning textures individually... nothing works. It's possible to
> make a triangle mesh out of it, but I have never been impressed by meshes,
> and would rather use slightly more resolution independant objects. (The best
> being Our Friend the Primitive.)
>     What can I do? Is there some bug in POV-Ray? Is there something simple
> I'm overlooking?
This is certainly a bit the wrong group for such things (so i set followup
to p.a-u)
First of all bicubic patches are internally converted to meshes in povray
so it's not reasonable why you couldn't achieve the same accuracy with a
mesh.  Another thing which i already mentioned in another reply, bicubic
patches are a very limited shape, only certain surfaces can be modelled
and when you try to approximate cylinders, spheres etc. with several
patches you will have to expect strange results.
Date: 6 Jul 2001 09:58:16
Message: <3b45c3f8@news.povray.org>
You wrote:
    <<First of all bicubic patches are internally converted to meshes in
povray so it's not reasonable why you couldn't achieve the same accuracy
with a mesh.  Another thing which i already mentioned in another reply,
bicubic patches are a very limited shape, only certain surfaces can be
modelled and when you try to approximate cylinders, spheres etc. with
several patches you will have to expect strange results.>>
    Interesting. That's a smart idea - POV probably converts most objects
(excepting primitives) to meshes. I'll have to take a look at the source
code (and hope I can understand some of it).
    I'm really not looking for cylinders and the like. I have an object I
happen to like very much. It looks good, even with bicubic patches. It also
takes up a relatively small space (60K as opposed to five megs of
triangles). It just does strange things with the surface normal.
    The answers will come to me yet....
    Thanks again,
    -Eli
Date: 12 Jul 2001 10:01:19
Message: <chrishuff-FC0E98.08594812072001@povray.org>
In article <3b45c3f8@news.povray.org>,
Only bezier patches and height fields...most objects are rendered
directly, and many just can't be reduced to a mesh.
Christopher James Huff - chr### [at] maccom, http://homepage.mac.com/chrishuff/
