POV-Ray : Newsgroups : povray.advanced-users : Embarrasing Trig Question Server Time
18 May 2026 02:33:42 EDT (-0400)
  Embarrasing Trig Question (Message 1 to 7 of 7)
Subject: Embarrasing Trig Question
Date: 28 Jun 2001 15:24:41
Message: <3B3B847B.36941B5E@torgo.net>
Can anyone help a trig simpleton bisect an angle in POVRay?
If I have three points in space (A, B & C), how can I
1) Find the angle of ABC
2) Find the point (D) which lies at a point bisecting an arc AC so that
line DB equals line AB equals line CB ?
I'd like this to work for any three arbitrary points, so I can create a
rounded mesh "box" macro for "boxes" that aren't necessarily regular.
Any help would be appreciated.
TIA,
DeanZ
Subject: Re: Embarrasing Trig Question
Date: 28 Jun 2001 15:56:57
Message: <slrn9jn30b.563.ron.parker@fwi.com>
There's stuff you can do with the cross product and the dot product to
do this, but you don't really need it if all you want to do is bisect
the angle.  In case you do need it for some other reason, though,
atan2(vdot(A-B,C-B),vlength(vcross(A-B,C-B)))
should give you an answer for non-pathological cases (i.e. those where
A, B, and C are distinct points.)
B+vlength(C-B)*vnormalize(A/2+C/2-B);
Just like in geometry class: first bisect the line connecting A and C,
then project that out to the circle.  Note that this assumes that A and
C are the same distance from B.  If they aren't, there's no such solution
(because AB won't equal CB as specified.)
I haven't tested either equation, so there are probably embarrassing
errors in them.
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
Date: 28 Jun 2001 16:43:49
Message: <3B3B9707.FD723F20@torgo.net>
Thanks-- that helps a lot, especially since geometry class is a distant memory.
-DZ
(nice signature line by the way)
> errors in them.
Date: 29 Jun 2001 09:21:03
Message: <slrn9jp061.5mq.ron.parker@fwi.com>
>errors in them.
Well, at least one embarrassing error is that I got those backwards.  You
want atan2(vlength(vcross(A-B,C-B)),vdot(A-B,C-B)).
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Date: 1 Jul 2001 19:55:19
Message: <3B3FB78C.DF0C73F1@hotmail.com>
Ron Parker wrote:
> You want atan2(vlength(vcross(A-B,C-B)),vdot(A-B,C-B)).
Yes, that's one way of doing it.
He could also try this:
acos(vdot(vnormalize(A-B),vnormalize(C-B)))
or even:
asin(vlength(vcross(vnormalize(A-B),vnormalize(C-B))))
But I would suspect POV to parse your expression faster.
Is this true Ron ?
Best regards,
Tor Olav
mailto:tor### [at] hotmailcom
http://hjem.sol.no/t-o-k
http://www.crosswinds.net/~tok
Date: 2 Jul 2001 08:46:42
Message: <slrn9k0r9i.7lp.ron.parker@fwi.com>
>or even:
>Is this true Ron ?
I suspect they're all about the same in parsing time.  I chose atan2 because
it automatically handles angles beyond pi/2, but that might not be an issue
in this case if you use acos.  asin would have a problem.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)union{R(z+a z)R(-z a-z)R(a
-z*3a+z)torus{1F clipped_by{plane{a 0}}}translate z+V}#end#macro S(g)9-(D-g)*(D-
g)#end#macro Z(D a T F)union{P(a)P(-a)R(y-z-1a)translate.1*D-y*8pigment{rgb<S(7)
S(5)S(3)>}}#if(D)Z(D-.2a,T F)#end#end Z(10x*-2x.2)camera{rotate x*90}
Date: 3 Jul 2001 12:29:47
Message: <3B41F328.815FC204@hotmail.com>
> >or even:
> >Is this true Ron ?
I see.
I'm so used to doing it the acos way
that I didn't give the input ranges
any thoughts when I posted my last
message.
Of course; The asin wouldn't be able
to discriminate between vectors having
an angle Theta between them and vectors
having an angle pi-Theta between them.
Tor Olav Kristensen
