POV-Ray : Newsgroups : povray.advanced-users : Random, Displaying values, and a parsing logistics question: Server Time
10 Feb 2026 08:11:25 EST (-0500)
  Random, Displaying values, and a parsing logistics question: (Message 1 to 5 of 5)
Subject: Random, Displaying values, and a parsing logistics question:
Date: 2 May 2001 15:04:26
Message: <3AF0680F.102B9B08@netvision.net.il>
1. How do I use a random value? I remember that a sample had shown that.
2. is it possible to display a value to debug? #debug doesn't do that,
nor #warning.
3. if I use a random texture for a single object:
#declare myObject = box {<0,0,0> <1,1,1> pigment {color rgb <random,
random, random>}}
and do:
object {myObject}
object {myObject translate <1,0,0>}
will they have different colors?
Subject: Re: Random, Displaying values, and a parsing logistics question:
Date: 2 May 2001 15:18:24
Message: <slrn9f0nbb.d8q.ron.parker@fwi.com>
First, declare a seed:
#declare S=seed(124526); // use some other value for different sequences
                         // of random numbers.
Then use it with the rand function:
#declare R=rand(S) sets R to a random number between 0 and 1 (including 0
but not including 1.)  More info can be found in the "float functions" topic
in the Fine Manual.
>nor #warning.
#debug wants string arguments.  Look at the "string functions" topic in
the Fine Manual.  You want the "str" function.
>random, random>}}
>and do:
>object {myObject}
No.  Declaring an object actually creates that object in memory,  It doesn't
reparse the object declaration every time you use it like C's #define does.
To do that, you need #macro:
#macro myObject()
  box {0 1 pigment {color rgb <rand(S), rand(S), rand(S)>}}
object {myObject()}
object {myObject() translate x}
#local R=<7084844682857967,32787982,826975826580>#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
Date: 2 May 2001 15:38:42
Message: <3af06242$1@news.povray.org>
"Eitan Tal" <eit### [at] netvisionnetil> wrote in message
news:3AF0680F.102B9B08@netvision.net.il...
#declare S=seed(123) // any aritrary number
#declare R=rand(S) // the random number put into R
> nor #warning.
You can send a float or string to the message stream by:
#declare MessageNumber=R;
#debug concat("Random number is ", str(MessageNumber,3,1),"\n")
> random, random>}}
> and do:
> object {myObject}
No.  Were it a pigment pattern instead and you moved it before adding
texture it would potentially change.  You're asking if the colors randomize
later though and no it does not (should not).
Bob H.
Date: 3 May 2001 06:12:35
Message: <3af12f13@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
: #debug wants string arguments.
  I still think #debug (and other streams) should be more user-friendly,
as printing functions in other scripting languages, so that you could
write something like:
#declare F1 = 5;
#declare F2 = 3.86;
#declare V = <1,2.8,-3>;
#declare S = "Hello!"
#debug "Some values: ", F1, "; ", F2, "; ", V, "; ", S, "\n"
  This would print:
5; 3.86; <1,2.8,-3>; Hello!
  With the current implementation you have to do this:
#debug concat("Some values: ", str(F1,0,0), "; ", str(F2,0,2), "; <",
              str(V.x,0,0), ",", str(V.y,0,1), ",", str(V.z,0,0), ">; ",
              S, "\n")
#local D=array[6]{11117333955,7382340,3358,3900569407,970,4254934330}
#local I=0;#macro M()<mod(D[I],13)-6,mod(div(D[I],13),8)-3,10>#end
blob{#while(I<6)cylinder{M()#local D[I]=div(D[I],104);M().5,2
pigment{rgb M()}}#local I=(D[I]>99?I:I+1);#end}               /*- Warp -*/
Date: 3 May 2001 06:22:11
Message: <chrishuff-6B45AB.05194603052001@news.povray.org>
In article <3af12f13@news.povray.org>, Warp <war### [at] tagpovrayorg>
Just allowing them to take the same input you can feed to files would be
nice...
Christopher James Huff
