POV-Ray : Newsgroups : povray.advanced-users : rotating around x-axis inside povray Server Time
15 Jun 2026 11:17:47 EDT (-0400)
  rotating around x-axis inside povray (Message 1 to 10 of 10)
Subject: rotating around x-axis inside povray
Date: 26 Feb 2001 13:31:52
Message: <3A9AA182.3090402@home.nl>
How does povray rotate around the x-axis?
This way:
<0,1,0>*< 1,  0,  0,
0,  C,  S,
0, -S,  C>
Or this way:
< 1,  0,  0,	*< 0
0,  C,  S,	   1
0, -S,  C> 0>
Of course I cutted out the fourth row.
Thanks in advance,
Remco Poelstra
Subject: Re: rotating around x-axis inside povray
Date: 26 Feb 2001 14:08:52
Message: <3A9AA9D9.F47E26D0@aetec.ee>
Remco Poelstra wrote:
> Hi,
> This way:
> <0,1,0>*< 1,  0,  0,
> 0,  C,  S,
> 0, -S,  C>
> Or this way:
> < 1,  0,  0,    *< 0
> 0,  C,  S,         1
> 0, -S,  C> 0>
Deciding from matrices.c POVRay multiplies vector row with matrix. But
why is it important?
Date: 26 Feb 2001 15:32:30
Message: <3A9ABDC9.70904@home.nl>
Because I'm writing a program that does some matrix calculations and
outputs to povray.
Now I was wondering how the matrices on
http://enphilistor.users4.50megs.com/matrix.htm
are constructed. I redesigned them by hand, and came out by the same
matrices, except that I use the second method to multiply. ie, the
vector as a column, not a row.
Remco Poelstra
Date: 26 Feb 2001 16:31:06
Message: <3A9ACB70.FAF52A5@spiritone.com>
It's the difference between multiplying the vector to the right or left. I
believe a 1by4 vector is multiplied to the right by the 4 by 4 matrix in
POV-Ray
Josh
> outputs to povray.
> Remco Poelstra
eng### [at] spiritonecom
"He who hebetates is last."
Date: 27 Feb 2001 05:18:39
Message: <3A9B7F16.38B9520C@aetec.ee>
> outputs to povray.
If 3x3 matrix (i.e. without transformations) is used then matrix is
same, regardless of multiplying vector row with matrix (i.e. vectors are
seen as rows) or matrix with vector column (vectors are seen as
columns). Difference comes, when You use 4x4 matrix, then matrix is
different (translation is either in last row or column).
Date: 27 Feb 2001 08:09:40
Message: <3A9BA72C.FA4D5AE2@aetec.ee>
Duh, it should be------------> translations
Date: 27 Feb 2001 08:39:12
Message: <3A9BAE6C.7589C512@spiritone.com>
> > outputs to povray.
Actually, they don't. If v = <a,b,c> and M is a 3x3 matrix, multiplying the
row vector on the left gives you a different answer than multiplying the
column vector on the right.
v = <a,b,c>
M = d e f
       g h i
       j k l
vM = <ad+bg+dj, ae+bh+ak, af+bi+cl>
Mv = <ad+be+cf, ag+bh+ci, aj+bk+bl>
If you switch the order of the vector and the matrix, you have to transpose
the matrix
Date: 27 Feb 2001 09:05:40
Message: <3A9BB449.899ED163@aetec.ee>
> [Something very false]
Duh, of course, You're right :-( Next time I'll think more carefully,
what I write.
I'll not post false facts to usenet.
[98 x more]
Date: 27 Feb 2001 14:43:33
Message: <3A9C044A.51FD6E87@peak.edu.ee>
> [98 x more]
Not bad, but this is not usenet - better try it again and this time add
"... or private news servers"
Margus Ramst
Home page http://www.hot.ee/margusrt
Date: 1 Mar 2001 04:51:35
Message: <3a9e1ba7$1@news.povray.org>
"Margus Ramst" <mar### [at] peakeduee> wrote in message
news:3A9C044A.51FD6E87@peak.edu.ee...
> > [98 x more]
#declare N = 1;
#while(N<=100)
  #debug "I'll not post false facts to news.povray.org\n" #declare N = N +
1;
