POV-Ray : Newsgroups : povray.advanced-users : collision detection Server Time
15 Jun 2026 11:15:44 EDT (-0400)
  collision detection (Message 1 to 10 of 30)
Subject: collision detection
Date: 22 Feb 2001 09:57:47
Message: <3A9528ED.EE6FFF0C@psu.edu>
How can I create a collision detection routine? More specifically, what
do I look at to determine if two objects have collided in pov-space ? I
can figure it out with...say... unit spheres, that is easy, but what
about rotated cubes and more oddly shaped objects??
thank you
paul
Paul Daniel Jones
The Pennslyvania State University
pdj### [at] psuedu
http://research.chem.psu.edu/glassgrp/paul
       C            The way is near, but men
     // \           seek it afar. It is in the
    N    N          easy things, but men seek it
    |    ||         in the difficult things.
    C    C          -Menicius
       C
Subject: Re: collision detection
Date: 22 Feb 2001 10:27:46
Message: <3A952FF1.C3480B75@gmx.de>
In general that's a very difficult task, one method would be doing a lot
of tests with 'trace'.
Finding out whether two boxes collide could for example be done by
'tracing' along all their edges.
Date: 22 Feb 2001 10:36:08
Message: <slrn99acfa.qbu.ron.parker@fwi.com>
In general, it's an impossible task.  The best you can do is an
approximation.  For example, try to determine whether the intersection
of two complex CSG objects is nonempty.
Even that wouldn't see the special case where one box is entirely enclosed
by the other box.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 22 Feb 2001 10:46:26
Message: <3A9533B0.CDE4E377@videotron.ca>
You can limit the number of traces necessary if you first find the
min_extent and max_extent of your objects.  If these don't overlap, then
your objects don't touch one another.  If they do, then you have to
start tracing along the side(s) where the bounding boxes overlap.
Note: You need MegaPOV to do this.
Francois Labreque |   //\\    Wear an ASCII ribbon!
    flabreque     |  ||  ||
        @         |   \\//    Support the campain
   videotron.ca        \\     against HTML e-mail
                      //\\    and news!
Date: 22 Feb 2001 11:07:27
Message: <chrishuff-67E254.11063222022001@news.povray.org>
In article <slr### [at] fwicom>, ron### [at] povrayorg
> by the other box.
But you could use eval_pattern() with the object pattern to catch this
case...you would still need to use trace() though, because there are
cases when two boxes intersect but all of their corners are outside.
And if you use a similar method to do collision with meshes, you could
tesselate (almost) any object with the tesselation patch and use the
resulting mesh for collision testing. It would be slow (a patch might be
needed to get a useable speed, like a "objects_intersect(ObjectA,
ObjectB, ...ObjectX) function), but you could speed it up a little by
using low-resolution meshes, either as a bounds test or for the actual
collision detection.
Christopher James Huff
Date: 22 Feb 2001 11:19:18
Message: <3A953C06.F7A4B59D@gmx.de>
As long as the shapes are basic mathematical objects (like sphere,
cylinder, box, etc.) it is possible to find an precise solution.  Of
course if the objects are approximated themselves (like isosurfaces) it is
not.
> by the other box.
All right, as Chris Huff mentioned you could use eval_pattern and the
object pattern (maybe it would be a good idea to make the Inside_Object()
function available in POV script just like trace()).
Date: 22 Feb 2001 11:27:01
Message: <slrn99afen.qd0.ron.parker@fwi.com>
But that is, as I said, an approximation.
Date: 22 Feb 2001 11:31:51
Message: <slrn99afnp.qd0.ron.parker@fwi.com>
>not.
Isosurfaces can be viewed as basic mathematical objects for the sake of
this exercise, since the approximation is purely visual.  The problem
of determining whether two "basic mathematical objects" overlap reduces
to a simple matter of solving a set of simultaneous equations and looking
for solutions within given ranges.  Unfortunately, the equations you're
solving aren't necessarily linear or even polynomial.  Presumably it's
possible to solve such a system for any given combination of objects
(though not necessarily) but it's either impossible or ridiculously
difficult to automate the process for any two arbitrary objects.
Date: 22 Feb 2001 11:56:28
Message: <3A9544B5.F763E135@gmx.de>
Seems you are right if you want to make it work for any CSG.  Anyway if
you only need the objects themselves (or unions) it could be reduced to a
set of independent equations.
After all, whether you need a numerical approximation to solve the problem
is not important in this case.
Date: 22 Feb 2001 11:57:42
Message: <3A954507.F4A1D04@gmx.de>
One could also use the brute force method using eval_pattern on the object
patterns of the two objects in a fine parallel raster...
I'm not even sure if that's slower, because tesselation is not needed.
