POV-Ray : Newsgroups : povray.advanced-users : collision detection Server Time
18 May 2026 06:23:24 EDT (-0400)
  collision detection (Message 21 to 30 of 30)
Subject: Re: collision detection
Date: 22 Feb 2001 16:10:13
Message: <3A958033.F2690729@gmx.de>
Chris Huff wrote:
> One little problem...how do you define "where an object collides with
> another one"? This will most likely not be a point.
> Or do you mean a function that checks if objects *will* collide and
> returns the first point of contact? You might as well just implement a
> general kinetics system in POV. I've considered something like this, a
> system that would handle solid objects, cloths and strings, and fluid
> particles, all interacting with each other, but it would be a lot of
> work. It'd make some fun animations, though. :-)
I meant the first contact, what happes afterwards is also influenced by
the mass distribution in the object and therefore quite tricky (one could
use a povray pattern for defining an inhomogeneous distribution of course,
would involve some very time consuming integration ...)
BTW, what happens after the second contact is easier again, you only have
to know the center of mass for that (as long as you don't need the
accurate description of movement for an animation).
The rest of the things you suggested sounds really complicated, most known
techniques for modelling those things would require tesselation of the
objects BTW.  It would sound quite reasonable to me to restrict things to
movement of solid bodies without elasticity.
Date: 23 Feb 2001 04:13:09
Message: <3a9629a5@news.povray.org>
"Ron Parker" <ron### [at] povrayorg> wrote in message
news:slr### [at] fwicom...
> Or on the object pattern of the intersection of the two objects.
Presumably the answer is "No", but is it possible to test directly whether
the intersection of two objects actually resulted in any actual shape (a
collision) or not?
Date: 23 Feb 2001 05:26:53
Message: <chrishuff-E536A4.05255923022001@news.povray.org>
In article <3a9629a5@news.povray.org>, "Tom Melly" <tom### [at] tomandlucouk>
> collision) or not?
"No"
You will have to do something like scan across the intersection of the
bounding boxes with trace() or inside_object() (or the InObj() macro) to
find out if there is anything left. And then there is the possibility
that you simply missed it because you didn't scan the bounding area at a
high enough resolution, and it would be slow, even if patched into
POV...and you wouldn't be able to detect if an object just touches
another this way.
Christopher James Huff
Date: 23 Feb 2001 07:36:01
Message: <3a965931$1@news.povray.org>
"Chris Huff" <chr### [at] maccom> wrote in message
news:chrishuff-E536A4.05255923022001@news.povray.org...
whether
> > collision) or not?
> "No"
Hmm, okay. How about this - if I render the following object:
#declare X=0.99;//1.1
intersection{
  sphere{0, 1 translate x*-X}
  sphere{0, 1 translate x*X}
  pigment{Red}
I will see at the end of render "CSG Intersection succeeded = 0 " (if X>=1)
or a positive value (if X<1).
Now, for collision detection, we are not interested in textures or
resolution. Would it not be fairly easy (?!?) to write a patch that would
render two objects as an intersection and return the CSG intersection
succeeded value?
The "render" would not have to produce any image output and all textures,
media, photons, radiosity, etc. could be ignored to speed up the process.
Would this be slower/harder to implement than any of the other suggestions?
Date: 23 Feb 2001 07:59:43
Message: <3A965EBF.EDD947E8@gmx.de>
> succeeded value?
Rendering in this case does nothing more than searching for intersection
in a certain raster like the method i suggested. The problems are the
same, if the intersection is too small in relation to the render
resolution or the object is not visible in the render camera, the result
will be wrong.  Furthermore scanning the whole camera angle is much less
efficient than scanning only the intersection of the bounding boxes.
Date: 23 Feb 2001 09:01:25
Message: <3a966d35$1@news.povray.org>
news:3A965EBF.EDD947E8@gmx.de...
Ah - a couple of thoughts occur.
1. If the intersection is too small, I suppose for most purposes it can be
ignored since it won't be apparent to the observer that something went
wrong.
2. What will happen to "off-stage" collisions? Does your suggestion
calculate collisions even if the relevant objects are off the screen and not
reflected? Would mine?
Date: 23 Feb 2001 09:16:48
Message: <3A9670D0.2CCC1167@gmx.de>
Your 'rendering solution' needs a camera to be specified and therefore
misses everything not in the view of that camera.  Using the bounding
boxes does not have this problem.
Date: 23 Feb 2001 09:25:28
Message: <chrishuff-27B695.09243523022001@news.povray.org>
In article <3a965931$1@news.povray.org>, "Tom Melly"
> intersection{
>   pigment{Red}
> X>=1) or a positive value (if X<1).
> succeeded value?
I'm not sure what you mean...are you talking about the render
statistics, and a setting that makes it simulate rendering without
actually generating an image or computing textures? That statistic is
just the number of rays from the camera that hit an intersection, not
whether there was something left from the intersection or not. Using it
for collision detection wouldn't work very well, the results would
depend on whether the objects are visible, how far away they are, how
large they are, what resolution you are rendering at, etc...it would be
much more efficient to just code a function that scans the bounding box
of the object with rays and/or insideness tests.
Date: 23 Feb 2001 11:54:48
Message: <3a9695d8$1@news.povray.org>
news:chrishuff-27B695.09243523022001@news.povray.org...
<SNIP>
So I gathered - I was more being curious rather than proposing a viable
solution. In a slightly related question, is it possible to return a
true/false as to whether any particular point is in the view of the camera
or not (ignoring reflections)?
Date: 26 Feb 2001 09:43:41
Message: <3A9A6A2F.6DD1F6B6@my-dejanews.com>
Francois Labreque wrote:
> You can limit the number of traces necessary if you first find the
> min_extent and max_extent of your objects.
My volume macro relies on eval_pattern.   To the accuracy you require, it gives
you the volume of an object.  If you have "all day," it can sit there and tell
the intersection of two objects based on the volume of their intersection.
> Paul Jones wrote:
> How can I create a collision detection routine?
There are several applications where a "field repulsion" gives the desired
effect.  Are you shooting birds (true collision detection req'd) or do you have
a flock that's trying to avoid collisions?  If you have the latter, see:
http://www.geocities.com/pterandon/boids.html
