POV-Ray : Newsgroups : povray.advanced-users : collision detection Server Time
18 May 2026 06:23:29 EDT (-0400)
  collision detection (Message 11 to 20 of 30)
Subject: Re: collision detection
Date: 22 Feb 2001 12:05:12
Message: <slrn99ahm9.qdv.ron.parker@fwi.com>
On Thu, 22 Feb 2001 17:56:21 +0100, Christoph Hormann wrote:
>Ron Parker wrote:
>> Isosurfaces can be viewed as basic mathematical objects for the sake of
>> this exercise, since the approximation is purely visual.  The problem
>> of determining whether two "basic mathematical objects" overlap reduces
>> to a simple matter of solving a set of simultaneous equations and looking
>> for solutions within given ranges.  Unfortunately, the equations you're
>> solving aren't necessarily linear or even polynomial.  Presumably it's
>> possible to solve such a system for any given combination of objects
>> (though not necessarily) but it's either impossible or ridiculously
>> difficult to automate the process for any two arbitrary objects.
>Seems you are right if you want to make it work for any CSG.  Anyway if
>you only need the objects themselves (or unions) it could be reduced to a
>set of independent equations.
Yes and no.  Some objects, like isosurfaces, blobs, and polys, are fairly
ugly even then.  Other objects, like cubes and cones and cylinders, can
get fairly ugly after you apply transformations to them.
Even CSG intersections could be handled, if you could handle the solution of
the independent equations.  The problem is that that solution is not easy.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 22 Feb 2001 12:06:12
Message: <slrn99aho5.qdv.ron.parker@fwi.com>
On Thu, 22 Feb 2001 17:57:43 +0100, Christoph Hormann wrote:
>One could also use the brute force method using eval_pattern on the object
>patterns of the two objects in a fine parallel raster...
Or on the object pattern of the intersection of the two objects.
Date: 22 Feb 2001 12:29:26
Message: <3A954C77.4995DEA8@gmx.de>
I was only thinking about spheres, cylinders and objects made of planes
(like boxes) which would result in distances between points, lines and
planes.  I agree that everything else can get really ugly.
Date: 22 Feb 2001 12:38:34
Message: <chrishuff-3E6D98.12373922022001@news.povray.org>
In article <3A953C06.F7A4B59D@gmx.de>, Christoph Hormann
<chr### [at] gmxde> wrote:
> (maybe it would be a good idea to make the Inside_Object()
> function available in POV script just like trace()).
I haven't done it before, since this macro is pretty easy:
#macro InObj(Pt, Obj) eval_pattern(object {Obj}, Pt) #end
But all it should take is adding a "inside_object" token to parse.h and
tokenize.c, and adding this case to Parse_Num_Factor() in express.c
(make sure you put it with the float functions):
          case INSIDE_OBJECT_TOKEN:
            OBJECT * Object;
            VECTOR Point;
            GET(LEFT_PAREN_TOKEN);
            Parse_Vector(Point);
            Parse_Comma();
            EXPECT
                CASE(OBJECT_ID_TOKEN)
                    Object = Token.Data;
                    EXIT
                END_CASE
                OTHERWISE
                    Object = NULL;
                    UNGET
                    EXIT
                END_CASE
            END_EXPECT
            if(Object == NULL)
            {   Error ("Object Identifier Expected.");}
            GET(RIGHT_PAREN_TOKEN);
            Val = Inside_Object(Point, Object);
          break;
I haven't tested this patch (I haven't even compiled it), but it should
work.
Christopher James Huff
Date: 22 Feb 2001 12:48:48
Message: <3A9550F9.80FAA811@gmx.de>
> work.
The hardcoded version would probably be much faster so i think it's quite
a good idea when it should be used for collision detection where it would
be called quite often.
Date: 22 Feb 2001 13:39:03
Message: <chrishuff-99F94F.13380822022001@news.povray.org>
In article <3A9550F9.80FAA811@gmx.de>, Christoph Hormann
The patch I posted compiled and ran fine.
I tested the speed with a file that called the function or macro 64^3
(262144) times.
The macro version used 238 seconds, and the function version used 208
seconds, so the function version takes about 87% as long as the macro.
It seems macros don't have that much overhead...at least, the MegaPOV
macros, which have been optimized. However, in a collision detection
algorithm, which could easily use even more calls, this small
improvement would still be helpful.
Date: 22 Feb 2001 13:56:19
Message: <chrishuff-5E7B4E.13552522022001@news.povray.org>
In article <chrishuff-99F94F.13380822022001@news.povray.org>, Chris
I decided to do a more accurate calculation by subtracting out the
"overhead" of the rest of the scene (by replacing the call to the macro
or function with a 0), and found out a surprisingly large portion of the
time was spent in the loops themselves...and the function is a great
deal faster than the macro.
The scene with no calls but the same number of repetitions used 204
seconds, so the total time used by the function was 4 seconds and the
total time used by the macro was 34 seconds. The function only takes
about 11.7% as long as the macro...nearly 10 times faster.
Which figure is more relevant? The 11.7% is a better comparison of the
speed of the macro with the speed of the function, but the 87% figure is
closer to what you will see in real life...you will probably have the
call nested in a bunch of loops and other macro calls. Only a small
portion of the time was actually spent in the macro/function call.
Date: 22 Feb 2001 14:12:44
Message: <slrn99ap5e.qgb.ron.parker@fwi.com>
If we're gonna add functions, might as well make one that does the whole
apprxomated-collision-detection operation, especially if loops are that
slow.
Date: 22 Feb 2001 15:19:23
Message: <3A957448.A76A605@gmx.de>
> slow.
You mean something like:
collide(object, object, method, accuracy)
returning 1 or 0 for collision or no collision?
It yould be useful, but what's really needed in most cases is a function
returning where an object collides with another one if it is moved in a
certain way.  This would mean something like 'trace' with an additional
object parameter.
Date: 22 Feb 2001 15:42:33
Message: <chrishuff-4226B4.15413822022001@news.povray.org>
In article <slr### [at] fwicom>, ron### [at] povrayorg
> slow.
Agreed...a collision detection algorithm that works this way written
entirely in POV-Script would likely be almost unbearably slow.
In article <3A9### [at] gmxde>, Christoph Hormann
> object parameter.
One little problem...how do you define "where an object collides with
another one"? This will most likely not be a point.
Or do you mean a function that checks if objects *will* collide and
returns the first point of contact? You might as well just implement a
general kinetics system in POV. I've considered something like this, a
system that would handle solid objects, cloths and strings, and fluid
particles, all interacting with each other, but it would be a lot of
work. It'd make some fun animations, though. :-)
