ARGH!!! I am trying to make a lens which will generate parallel beams
of light with a spotlight put at it's focal point. I have tried using
some formulae from my physics book, but just can't get it. Is there
anybody out there who could help me?
-paul
Paul Daniel Jones
120 Chandlee Laboratory
Penn State University
814-865-2090
pdj### [at] psu edu
http://research.chem.psu.edu/glassgrp/paul
> -paul
> Paul Daniel Jones
> 814-865-2090
> pdj### [at] psu edu
I can't get anything realistic with the spotlight. Try putting a point
light source in a box with a circular shaped hole to make a light cone.
Dan Johnson
You want a parabolic mirror with a light at its focus, like in a
flashlight. I don't know how to find the focus of a parabola though, Warp
or somebody?
David Fontaine <dav### [at] faricy net> ICQ 55354965
My raytracing gallery: http://davidf.faricy.net/
Don't use a spotlight.
light_source {<9, 0, 0> rgb 1}
#declare Lens = difference { // f=5 units
sphere{0,2.5}
box{<0,-3,-3>,<3,3,3>}
texture{T_Glass1}
interior{ior 1.5}
object { //condensor, mak parallel beam
Lens
photons {
photons_pass_through
translate <4,0,0>
Ingo
Pov-Ray : http://members.home.nl/seed7/
A beam from the focus going directly horizontal should be reflected directly
upward, which means that the parabola at that point has a slope of 1 or -1.
Since the beam is horizontal, it gives us the y-coordinate of the focus.
So...
d/dx (a*x^2+b*x+c) = 2*a*x+b
2*a*x+b = 1 ==> x = (1-b)/(2*a)
y = a*x^2+b*x+c ==> y = (4*a*c-b^2+1)/(4*a)
Similarly with the x-coordinate:
2*a*x+b = 0 ==> x = -b/(2*a)
So, unless I made a mistake, the focus should be at <-b/(2*a),
(4*a*c-b^2+1)/(4*a)>
> or somebody?
Being one of those physicists, I can tell you that an ordinary
spherical glass lens lens *will not* actually produce a parallel beam.
Spherical lenses are actually just an approximation. This might
surprise you, but it's true.
If you really want a parallel beam, use a reflective parabola like
David Fontaine suggested.
Ben
Theoretically there should be some sort of lens that makes parallel beams. But
my guess is it is not made of intersected spheres...
There are so-called aspheric lenses which will focus light better, but
only light that is exactly on the optical axis.
But I recently read an article about a gradient index sphere that
should focus light coming from any direction. The trick here is that
the lens has a different index of refraction at its center than at its
edge. Very interesting, but pretty hard to model in POV.
Ben
> So...
> > or somebody?
But if you use a parabola and a point light to make a parallel light, only the
light that bounces off the parabola is parallel, you have to block the rest of
the light somehow.
Dan Johnson
> Ben
Spherical aberration is one of the reasons people didn't trust Gallileo's
telescopes. Philosophers liked to work with pure shapes, so it was commonly
known that glass distorts the truth. I think the answer might be in a book
down the hall on optics, but I don't feel like looking, because my experience
tells me that even when you know you have seen the answer before, you can't
find it again without looking for a least a few hours.
