I was wondering why povray uses an 4d matrix internally, when the
vectors are only 3d.
Does anybody know this?
Remco Poelstra
Remco Poelstra <rjp### [at] home nl> wrote in message
news:3A6### [at] home nl...
> Hi,
> Remco Poelstra
This is because while you can skew, scale, or rotate a 3d vector with a 3d
(3x3) matrix, in order to add translation, you need a 4d (4x4) matrix.
because of this, povray probably uses 4d matrices so it doesn't have to
store a seperate transform for translation, otherwise, POV-Ray would need to
store two transform information structures, with 4x4 matrices, POV-Ray can
get by with only one data structure stored internally, and it can still do
any possible transformation of a given 3d vector.
I hope this helps, and is hopefully also understandable.
Thanks, it's exactly what I wanted to know,
Remco
