POV-Ray : Newsgroups : povray.advanced-users : Rotation mathematics Server Time
14 Oct 2025 07:03:51 EDT (-0400)
  Rotation mathematics (Message 1 to 8 of 8)
Subject: Rotation mathematics
Date: 10 Jan 2001 17:08:25
Message: <3A5CDD81.33664EC6@yahoo.com>
  just finished my session and learned quite a few interesting things... such as
2D rotations, where in radians (0 <= r <= 2pi):
x = cos(rad);
y = sin(rad);
Now, I was wondering how to add the Z coordinate? Is it possible? I guess a
better use would be to have different angles, rotating around a given axis and
use the cos&sin functions just like for x&y but substituting x&z for a yAxis
rotation, etc...
Is there any better math out there to help about rotations? Except for
matrixes...
| Simon Lemieux           | http://www.666Mhz.net            |
| Email : Sin### [at] 666Mhznet |          Website in Beta Testing |
Subject: Re: Rotation mathematics
Date: 10 Jan 2001 18:49:23
Message: <3A5CF3DE.8E0CD427@faricy.net>
Simon Lemieux wrote:
> Hi,
> x = cos(rad);
> y = sin(rad);
> rotation, etc...
> matrixes...
This is exactly what matrices are for! But here:
Rotate x: <x,y,z> -> <x,y*cos-z*sin,z*cos+y*sin>
Rotate y: <x,y,z> -> <x*cos+z*sin,y,z*cos-x*sin>
Rotate z: <x,y,z> -> <x*cos-y*sin,y*cos+x*sin,z>
Date: 10 Jan 2001 18:49:52
Message: <3A5CF3FC.27A61A74@faricy.net>
This is just for left-handed systems BTW.
Date: 10 Jan 2001 18:52:06
Message: <3a5cf5a6@news.povray.org>
such as
> x = cos(rad);
> y = sin(rad);
a
and
yAxis
> rotation, etc...
> matrixes...
All transformations in POV-Ray are ultimately represented as matrices,
because they offer the most general and compact form of the transformations
available in POV-Ray.  But POV-script is designed to be written and read by
people, not just computers, and the rotate, translate and scale commands
offer a much more intuitive way of performing transformations.  In other
words, don't feel obliged to learn matrices if the other three functions
allow you to do what you wish.
Regarding rotations - they are indeed performed, like you describe, as 2D
rotations about each of the three orthogonal axes, x, y, and z.  For
example, rotate <40, -20, 165> is interpreted as rotating 40 degrees about
the x-axis, followed by -20 degrees around the y-axis, followed by 165
degrees around the z-axis.  If you want to rotate around the y-axis, then
around the x-axis, you have to use two rotate commands, e.g. rotate y*45
rotate x*-90.
Another common method of expressing rotations in 3D space are quaternions -
these are rotations around arbitratry axes, rather than just the x, y, and z
axes.  For example, you might want to spin an object around the diagonal
axis <1, 1, 1>.  Quaternions are often used when interpolating objects from
one orientation to another, as they provide a smoother result than limiting
yourself to the x, y, and z rotational axes.
Date: 15 Jan 2001 12:35:31
Message: <3A63353D.89EC1BCC@yahoo.com>
Thanks a lot! Is there a difference between left and right-handed systems?
| Email : Sin### [at] 666Mhznet |        Povray and OpenGL Gallery |
Date: 15 Jan 2001 19:20:13
Message: <0t476tgk7ku9npt3ag4c8hvuusnklirks1@4ax.com>
  See POV-Ray docs, section 2.1.1 "Understanding POV-Ray's Coordinate
System".
  I John VanSickle's FlipYZ macro can handle easy right to left-handed
conversion within a scene file. Here is where to find John's macros:
http://enphilistor.users4.50megs.com/macs.htm
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 15 Jan 2001 19:48:04
Message: <3A6399B6.69F204D3@videotron.ca>
Yes.  Take you thumb as the Y axis.  your fingers wrap toward a positive
rotation.
As you ca see, the rotations are oppsoite depending on whether you have
a LHS or a RHS.
As for the matrices go,
For a LHS:
     |  1    0     0   |
Rx = |  0   cos   sin  |
     |  0  -sin   cos  |
And for a RHS:
     |  1    0     0   |
Rx = |  0   cos  -sin  |
     |  0   sin   cos  |
(As you can see the sign of the sine changes)
Francois Labreque | Unfortunately, there's no such thing as a snooze
    flabreque     | button on a cat who wants breakfast.
        @         |      - Unattributed quote from rec.humor.funny
   videotron.ca
Date: 15 Jan 2001 21:28:45
Message: <3A63B0A4.806011C2@faricy.net>
If you know what the graphs of sine and cosine look like, you can mimic the
rotations with your hand and it should be apparent where these formulas come
from.
For a left or right handed system, thumb pointing out is x, index finger
pointing straight is y, and middle finger pointing perpendicular to palm is z.
So swap y and z from the left-handed system and you get a right-handed system.
In either system, point your thumb along the axis of rotation and your fingers
will curl in the direction of rotation.
