POV-Ray : Newsgroups : povray.advanced-users : Automised visualization of a 'hasn't to be square' room Server Time
1 Nov 2024 21:22:25 EDT (-0400)
  Automised visualization of a 'hasn't to be square' room (Message 1 to 10 of 11)
Subject: Automised visualization of a 'hasn't to be square' room
Date: 24 Dec 2000 08:51:35
Message: <3A4750EE.7050301@home.nl>
I'm writing a little piece of software, which does some calculations
about reflections in a room.
The user specifies 6 planes, which are the walls, a 'listener' and a
'soundsource'.
I want to visualize the room and the first reflections with povray, but
I've a lot of problems doing so:
The 2 major problems are:
1. I used intersection{ to make the box out of the planes, but since I
don't know where the planes are, I can't know when I have to do inverse,
and when not, assuming that every wall will be at another side of 0,0,0
, but even that isn't for sure. How can I easyly create a box when I
have only 6 planes?
2. When I've the box created, how can I look "inside", to see what's
going an? TonyB suggested to make the box out of triangles and take a
few away, making a hole, but since I have only the 6 planes, I don't
know how the convert them to triangles and take the right ones away.
I hope someone can help me with this problem,
Remco Poelstra
Subject: Re: Automised visualization of a 'hasn't to be square' room
Date: 24 Dec 2000 09:44:49
Message: <chrishuff-367F16.09460324122000@news.povray.org>
In article <3A4### [at] homenl>, Remco Poelstra
If you don't know where the walls are, you have a problem...
> How can I easyly create a box when I have only 6 planes?
6 planes are all you need...
intersection {
    plane {y, 1}
    plane {-y, 1}
    plane {x, 1}
    plane {-x, 1}
    plane {z, 1}
    plane {-z, 1}
This will give you a box with 90 degree angles, you can adjust the
planes to do something different.
Make a wall transparent, or put the camera inside the "room"...if the
"listener" wall shows the sound waves graphically, you can make it show
them on both sides...a more precise description of what you are
attempting would help.
Christopher James Huff
Date: 24 Dec 2000 11:18:58
Message: <3A47737A.7050500@home.nl>
Ok, I'll try to explain it as clear as possible.
I want to calculate first reflections reverb of a room, outputting a
wave-file and an image of the situation.
I like to do it in the following way:
I let the user describe the room by giving the equation of 6 planes. He
also gives the position of the soundsource, imagine it being a speaker
and the position of a listener, imagine it being you.
I calculate the reflections points, ie, where the sound bounces off the
wall. Finally I calculate the wave-file.
What I want to visualize is the situation defined by the user, whereby I
use spheres for the source and the listener, cylinders for the path the
sound travels from source to wall to listener.
I made a small example of this, with only one soundpath.
http://www.beryllium.net/~remco/room.jpg   4.2kb
This is a very ideal situation.
My problem is now, that the planes can be everyware in any position,
depending on how the user defined them.
My questions stays the same: How can I let my software output a good
room( when all I have is 6 planes and a bunch of points), where I can
look thru, because just taking away one plane as I did in the example is
almost impossible.
Hope this explanation is a bit clearer,
Remco Poelstra
Date: 24 Dec 2000 14:09:15
Message: <chrishuff-7CAEBA.14102924122000@news.povray.org>
> almost impossible.
Ok, I understand what you are doing, but I still don't understand the
problem you are having...why not just put the camera in the room, or
make one or more walls transparent? Or are you having problems making
the room itself? Is your problem with the primitives you are using, like
CSG or a triangle mesh?
Date: 25 Dec 2000 07:18:14
Message: <3A488C8F.3010607@home.nl>
Thanks, you give a a good idea. I thought I couldn't place the camera in
the room, because I couldn't see all reflectionpoints then, but I can
make a 360 degree image.
A new problem arises with that, when I was experimenting a bit with 360
degree cameras, it seems that only fisheye gives me 360.
Ultra_wide_angle gives only 180,
althought I set angle to 360.
> or
The biggest problem is now the CSG of the planes. I don't know how to
determine when to use invert and when not. Just checking whether D (in
<A,B,C>,D) is negative doesn't work, like it would do for a perfect box,
with 0,0,0 in it's center.
Perhaps I should use a completly different method  to create the box,
but I don't know how, because just giving to points like in box{ can't
give me the possibillity to place walls rotated.
Any ideas?
Remco Poelstra
Date: 25 Dec 2000 11:59:11
Message: <chrishuff-FC7DFE.12002625122000@news.povray.org>
You shouldn't need to use "inverse". Just make sure that a point in the
room is "inside" all of the planes, and intersect them all together.
What is the data you have to work with? Axis-aligned planes and
transformations? Plane normal and distance? Vertices?
You could start with something like this as a base:
#declare CeilingTrans = transform {...}
#declare FloorTrans = transform {...}
#declare LeftWallTrans = transform {...}
#declare RightWallTrans = transform {...}
#declare FarWallTrans = transform {...}
#declare NearWallTrans = transform {...}
intersection {
    plane {y, 0 transform CeilingTrans translate y}
    plane {-y, 0 transform FloorTrans translate -y}
    plane {x, 0 transform LeftWallTrans translate x}
    plane {-x, 0 transform RightWallTrans translate -x}
    plane {z, 0 transform FarWallTrans translate z}
    plane {-z, 0 transform NearWallTrans translate -z}
This should give you an axis-aligned cube where you can adjust each wall
individually.
Well, you could do rhomboid or sheared rooms with a box, but you
couldn't do trapezoidal shapes. An intersection of planes should work
fine.
Date: 25 Dec 2000 20:45:19
Message: <533.394T1801T12314566PeterC@nym.alias.net>
Call me dense
(ok, you're dense - ed)
but why not use a box for the room object?  If placing the
camera inside the box, add the inverse keyword to the box.
It will render faster than six planes.
consider this macro, which is passed the offsets of the walls
and a texture:
#macro do_room(left_offset, right_offset, floor_offset, ceiling_offset,
near_offset, far_offset, room_texture)
  box {
    <left_offset, floor_offset, near_offset>,
    <right_offset, ceiling_offset, far_offset>
    texture { room_texture }
Pete
Date: 26 Dec 2000 08:36:32
Message: <3A49F06B.3040003@home.nl>
> intersection {
> individually.
Great! Looks like I'm going to use something based on this one.
Thanks for the help,
Remco Poelstra
Date: 26 Dec 2000 08:36:57
Message: <3A49F084.1020604@home.nl>
Pete wrote:
> Call me dense
> and a texture:
>   box {
> #end
I have considered to just use a normal povray box, but I can't place
walls rotated in that case.
Thanks for the idea anyway,
Remco Poelstra
Date: 26 Dec 2000 09:44:32
Message: <chrishuff-01FF3B.09455026122000@news.povray.org>
In article <533### [at] nymaliasnet>, Pete
If you use a box, even with the matrix keyword, you are limited to rooms
with opposite walls being parallel.
