POV-Ray : Newsgroups : povray.advanced-users : Converting Halos to Media Server Time
23 Feb 2025 19:38:34 EST (-0500)
  Converting Halos to Media (Message 1 to 6 of 6)
Subject: Converting Halos to Media
Date: 20 Dec 2000 13:17:22
Message: <3A40F892.A8F39EAF@io.com>
Hey all. After a long absence from POV-ray, I recently downloaded the
new version and discovered the new media statement. In the old version,
I enjoyed using halos to create all sorts of effects, but when I try to
change these halos over to using the new media object, it doesn't look
anything like what it used to. Can someone give me some advice? I've
pasted one of my halo codes below.
		halo{
			emitting
			spherical_mapping
			linear
			turbulence 1.5
			color_map{
				[0 color rgbt <1, 0, 0,  1.0>]
				[0.6 color rgbt <1,1,0,-1>]
				[1 color rgbt <1, 1, 0, -1>]
			 samples 100
			 rotate<0,90,0>
			 scale <0.6,0.5,0.6>
Subject: Re: Converting Halos to Media
Date: 20 Dec 2000 14:28:42
Message: <chrishuff-A4B9F8.14294920122000@news.povray.org>
In article <3A40F892.A8F39EAF@io.com>, philhall <phi### [at] iocom>
There is no way to directly translate from one to the other, you will
have to adjust things like density and samples until you get the desired
effect, but media is a more consistent and flexible model, especially
when you use the sampling method patches in MegaPOV(a patched unofficial
version, http://nathan.kopp.com/patched.htm). I never used halo, but a
rough translation of your code would be:
media {
    emission color White
    samples 100, 100
    //you will probably want to change the samples setting to
    //something more like: samples 75, 125
    //of course, the numbers depend on your scene...if you use
    //MegaPOV and method 2 or 3, you can get away with much smaller
    //numbers.
    density {spherical turbulence 1.5
            //use the "spherical" pattern to control the density
        color_map {
            //I don't know what you meant with the "t" channel,
            //you will need to adjust the brightness of these colors
            //to get the right results.
            [0.0 color rgb < 1, 0, 0>]
            [0.6 color rgb < 1, 1, 0>]
            [1.0 color rgb < 1, 1, 0>]
    rotate < 0, 90, 0>
    scale < 0.6, 0.5, 0.6>
You can generally ignore ratio, variance, and confidence, the defaults
are usually sufficient. Don't bother messing with transmit or filter,
the brightness of the color defines the density, black is completely
transparent. Try experimenting with emission media at first, it is the
fastest rendering.
Christopher James Huff
Date: 20 Dec 2000 15:03:30
Message: <3A41116E.42279D13@io.com>
Chris Huff wrote:
> media {
>     samples 100, 100
>     //numbers.
>         color_map {
>     rotate < 0, 90, 0>
> fastest rendering.
Thanks for your help. I'm getting slightly better results with your
advice but it still looks like a big splotch of color. I'm basically
trying to make a nebula type effect inside of a glass sphere. If density
is controlled by the brightness of the color, how can I get a nebulous
effect with vivid colors? Also, I don't seem to be able to get any
turbulence. Its more sort of rings of color that fade into each other.
Do you have any more advice or could you point me to some place that has
good examples and descriptions of getting this media thing to look good?
-Phil
Date: 20 Dec 2000 15:08:52
Message: <3a4111d4$1@news.povray.org>
Phil,
I have 3 media tutorials in the PRSG that may help you. Look in POV Advanced
under the tutorials section.
www.croswinds.net/~povstudy
Hope it helps,
C.J. - POV User
"philhall" <phi### [at] iocom> wrote in message
news:3A41116E.42279D13@io.com...
> Chris Huff wrote:
> > media {
> >     samples 100, 100
> >     //numbers.
> >         color_map {
> >     rotate < 0, 90, 0>
> > fastest rendering.
> -Phil
Subject: Thanks!
Date: 20 Dec 2000 19:57:26
Message: <3A41565C.9CFFACF0@io.com>
Thanks for the help guys! I've got the media working how I want to. I
appreciate the quick, helpful responses.
Subject: Re: oops
Date: 21 Dec 2000 13:39:24
Message: <3a424e5c$1@news.povray.org>
this is the correct address....
www.crosswinds.net/~povstudy
C.J.
"C.J." <hou### [at] yahoocom> wrote in message
news:3a4111d4$1@news.povray.org...
> Phil,
Advanced
> Hope it helps,
> C.J. - POV User
> > Chris Huff wrote:
> > > media {
> > >     samples 100, 100
> > >     //numbers.
> > >         color_map {
> > >     rotate < 0, 90, 0>
> > > fastest rendering.
> > -Phil
