POV-Ray : Newsgroups : povray.advanced-users : contour mapping Server Time
15 Jun 2026 16:46:03 EDT (-0400)
  contour mapping (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: contour mapping
Date: 5 Dec 2000 10:04:52
Message: <3a2d0414@news.povray.org>
Wouldn't a pigment (gradient y?) be enough?
Date: 5 Dec 2000 10:20:10
Message: <3a2d07aa@news.povray.org>
Is this what you call a contour map?
http://www.cs.tut.fi/~warp/contour.jpg
  I made the image with this code:
#version Unofficial MegaPov 0.6;
camera { location <-2,15,-10> look_at 0 angle 35 }
light_source { <50,200,-100>, 1 }
isosurface
{ function { y-noise3d(x,y,z) }
  contained_by { box { <-5,0,-5><5,1,5> } }
  scale <1,4,1>
  pigment
  { gradient y color_map
    { [0 rgb 0][.1 rgb 0]
      [.1 rgb <1,.7,.2>][1 rgb <1,.7,.2>]
    scale <1,.25,1>
  finish { specular .25 }
Date: 5 Dec 2000 11:32:43
Message: <3A2D17A0.8989156E@psu.edu>
Sorry....
What I want is this: To take a height field, which may or may not be
visible, and to create a series of closed loops, each loop sitting on a
specific elevation and encompasing only one "hill" of the hf. Now,
imagine that I apply a gradient y pigment to the hf, it would be
possible to get this effect, except that I want each "countour line" to
be 3-dimensional, like a pipe.
One could also envision taking a hf and repeatedly intersecting it with
two plane, so you are left with some thin sliced in the shape of a loop.
I want those loops to be pipes.
I hope this helps.
paul
Christoph Hormann wrote:
> Paul Jones wrote:
> > Anybody have any ideas on how I could make a contour map of a height
> > field?  I tried trace() and dropping a sphere at a point if it had a
> > specific Y value, drop enough spheres and test for different heights and
> > you statrt to get something which is OK, but it take half-past forever.
> > Any other ideas? maybe a sphere sweep of some kind ??
> > -paul
> I'm not totally sure what you want to do, but as i understand it, you want
> that contour lines only in povray.
> How about just using a partly transparent gradient y texture on the HF.
> If that's not a good solution, it would help a lot if you would say what
> you want to use these lines for.
> Christoph
> IsoWood include, radiosity tutorial, TransSkin and other
> things on: http://www.schunter.etc.tu-bs.de/~chris/
Paul Daniel Jones
The Pennslyvania State University
pdj### [at] psuedu
http://research.chem.psu.edu/glassgrp/paul
       C            The way is near, but men
     // \           seek it afar. It is in the
    N    N          easy things, but men seek it
    |    ||         in the difficult things.
    C    C          -Menicius
       C
Date: 5 Dec 2000 11:34:54
Message: <3A2D1824.BCC93109@psu.edu>
Warp, that is very close to what I want, but I need (well, _need_ is
subjective :-) the contours to be 3-dimensional, like tubes or sphere
sweeps. In my final image, the actual height-field will not be visible.
-paul
p.s. I like the image :-)
> isosurface
>   scale <1,4,1>
>   pigment
>     scale <1,.25,1>
Paul Daniel Jones
pdj### [at] psuedu
    C    C          -Menicius
       C
Date: 5 Dec 2000 11:51:17
Message: <Xns9001B57DAseed7@povray.org>
Try using "trace" in combination with "evaluate pigment/pattern" to put
lots of spheres on your HF.
Ingo
Date: 5 Dec 2000 11:56:29
Message: <3a2d1e3d$1@news.povray.org>
Paul Jones wrote in message <3A2D1824.BCC93109@psu.edu>...
visible.
he show you proper way
just use gradient y with color map [0 black] [0.9 black][0.9 white][1
white]
and find tool in povray/links or in news/binaries which convert
ouputed image to array in pov
(I don't remeber name nor author)
than run loop which puts sphere on pixels (array entries) different than
black
or use even spline for neighbours
ABX
Date: 5 Dec 2000 12:02:50
Message: <3a2d1fba@news.povray.org>
Wlodzimierz ABX Skiba wrote in message <3a2d1e3d$1@news.povray.org>...
but I have net :-)
http://www.coe.uncc.edu/~adwoodfi/tga.html
ABX
Date: 5 Dec 2000 12:34:24
Message: <3A2D271F.DE0ABA2D@gmx.de>
> but I have net :-)
I think you don't need a program for that, eval_pigment is sufficient.
Anyway, using enough spheres to make a smooth pipe will take quite a lot
of time and memory.
Date: 5 Dec 2000 12:43:45
Message: <3A2D2951.9C95E056@gmx.de>
Paul Jones wrote:
> Sorry....
That makes things clearer...
I think it should be possible with an isosurface:
use the data for an image_pattern instead of the heightfield and use a
color_map similar to the one Warp suggested like:
color_map {
  [0.00 rgb 0]
  [0.59 rgb 0]
  [0.60 rgb 1]
  [0.61 rgb 0]
  [1.00 rgb 0]
Of course that's not enough, because the image_pattern is only 2d.  You
have to add a function for the y direction, for a round pipe it has to be
some trigonometric function.
Date: 5 Dec 2000 12:55:17
Message: <3a2d2c05@news.povray.org>
Christoph Hormann wrote in message <3A2D271F.DE0ABA2D@gmx.de>...
hmm, strange, there is no tool, I think, which make the same thing
but as macro instead of external program with output to include file
hmm, how will be first .... :-)
lot
> of time and memory.
set of spheres connected with cylinders shouldn't be slow
I don't know what quality he is looking for
ABX
