POV-Ray : Newsgroups : povray.advanced-users : Telephoto lens effect Server Time
30 Sep 2024 04:14:14 EDT (-0400)
  Telephoto lens effect (Message 1 to 6 of 6)
Subject: Telephoto lens effect
Date: 24 Nov 2000 10:14:00
Message: <3A1E8557.91062A0@videotron.ca>
Does (mega)POV do like real telephoto lenses do and "shrink" the
distance of far away objects?
Should I just RTFM more?
Francois Labreque | It is by caffeine alone I set my mind in motion, it
    flabreque     | is by the beans of Java that thoughts acquire speed,
        @         | the hands acquire shaking, the shaking becomes a
   videotron.ca   | warning, it is by caffeine alone I set my mind in
                  | motion.
                               - Stolen from Badger's .sig file
Subject: Re: Telephoto lens effect
Date: 24 Nov 2000 17:33:56
Message: <chrishuff-0A18F8.17342424112000@news.povray.org>
In article <3A1### [at] videotronca>, Francois Labreque
Look up the "angle" keyword for the camera.
Yep. Specifically, this part of the fine manual:
4.4.1.3 Angle
    The angle keyword followed by a float expression specifies the
(horizontal) viewing angle in degrees of the camera used.
...snip...
Christopher James Huff
Date: 24 Nov 2000 19:01:42
Message: <3A1F01BA.261970AF@peak.edu.ee>
One thing about "angle": with panoramic projection it must be the first keyword
in the camera block, in order to take effect.
Margus Ramst
Date: 24 Nov 2000 21:15:57
Message: <3A1F2079.6D3E4395@videotron.ca>
I did.  And it does not appear to be giving the desired effect.
I am talking about the fact that when you are taking pictures with a
zoom, the apparent depth of the scene shrinks.  i.e. objects directly in
front of you will appear relatively closer to each other than they
really are, such as here:
http://www.americascup.org/gallery/ac/race_04/030100_TNZvsPRA_s/assets/acp20000301mcl4zr70883ph7.jpg
(watch the word wrap)
Where it looks as if the two boats were about to hit each other when in
fact they were probably a few hundred feet apart.
                  | motion.
Date: 25 Nov 2000 01:28:52
Message: <3A1F5C79.2FEEA4DF@peak.edu.ee>
"Angle" does do just that. Basically, reducing the camera angle reduces the
perspective effect; angle -> infinity approaches orthographic projection.
Remember that reducing the camera angle reduces the FOV (Field of View). So if
you want a particular object to appear the same size as before, you need to
increase the distance between it and the camera.
Margus Ramst
Date: 25 Nov 2000 09:24:50
Message: <3A1FCB4C.431D3AD5@videotron.ca>
After I wrote my last reply, last night, I played around and got
satisfying results.
Thanks anyway.
                  | motion.
