POV-Ray : Newsgroups : povray.advanced-users : No reflection for a specific object? Server Time
18 May 2026 08:51:20 EDT (-0400)
  No reflection for a specific object? (Message 4 to 13 of 23)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: No reflection for a specific object?
Date: 11 Nov 2000 23:19:44
Message: <3A0E1A03.3FEA6199@faricy.net>
Chris Huff wrote:
> "cast_shadow"? You mean "shadowless"? Or was it "no_shadow", I can never
> remember which one is used for light_sources...
The way I remember is that no_shadow is singular but shadowless can be plural.
So no_shadow is for objects and shadowless is for lights.
> I think what you want is the "no_reflection" keyword in
> MegaPOV...standard POV doesn't have special support for this feature,
> you have to trick it by using fancy bounding.
Interesting, I never thought of that. You mean like bound it with a polygon
that from the camera's viewpoint contains the object?
Date: 11 Nov 2000 23:20:23
Message: <3A0E1A2F.EB049608@faricy.net>
Margus Ramst wrote:
> Specifically, bound the object with very small boxes/spheres near (or around)
> the camera, and any light_sources that you want this object to interact with.
Ah...
Date: 11 Nov 2000 23:20:53
Message: <3A0E1A4D.7D45F9EB@faricy.net>
That's right, I forgot lights...
Date: 12 Nov 2000 01:04:33
Message: <3A0E4122.5E4B6476@yahoo.com>
Interesting, so, will doing these bounding boxes hack make my object appear in
front of the camera but not in the mirror beside it?
Thanks,
	Simon
| Simon Lemieux           | Website : http://www.666Mhz.net  |
| Email : Sin### [at] 666Mhznet | POV-Ray, OpenGL, C++ and more... |
Date: 12 Nov 2000 01:12:57
Message: <3A0E366D.7A7D236D@erols.com>
Simon Lemieux wrote:
> Hi,
> I was wondering if it was possible to tell an object to cast
> no reflection? Probably much like a "vampire effect" ;) or like the
> media_interaction or cast_shadow in lights... etc...
I think the way to do it is to give it a bounding object that surrounds
the camera viewpoint.  This way the reflected rays miss the bounding
object and cause it to not appear.
object {
  Vampire
  bounded_by { sphere { CameraLocation,.01 } }
Rays from the camera will always intersect the sphere, hence the
object will directly appear; but the reflected rays will almost
certainly miss that sphere, causing the object to not appear in the
reflection.
John
ICQ: 46085459
Date: 12 Nov 2000 01:55:59
Message: <3A0E4D2F.367F2933@yahoo.com>
> object {
>   Vampire
> reflection.
Very interesting!...  But... it doesn't seem to work...
I tried the simplified scene with a white sphere and a mirror, the bounded_by is
set to the camera position, everything seems alright, but I see two spheres...
Do I need any other keywords in order to make this work?
Thanks,
	Simon
Date: 12 Nov 2000 08:55:20
Message: <chrishuff-53785A.08552912112000@news.povray.org>
In article <3A0E1A03.3FEA6199@faricy.net>, David Fontaine
> plural.
But if you have more than one light, you object has as many shadows as
you have light sources...
> polygon that from the camera's viewpoint contains the object?
Bound it with a union of spheres or boxes, one around the camera and one
around each light that you want it to interact with.
Christopher James Huff
Date: 12 Nov 2000 09:00:08
Message: <chrishuff-959C74.09001812112000@news.povray.org>
> bounded_by is set to the camera position, everything seems alright,
Don't forget the light sources...
Hmm, you probably need to tell POV not to ignore your bounding. On the
Mac it is just a checkbox, you will probably have to put something in
your .ini file.
I think it went this way: the earliest versions of POV didn't do
automatic bounding, so it was all manual. When autobounding was added,
it sometimes did a better job than manual bounding, so an option to
override manual bounding was added. I think this option is on in your
case.
Date: 12 Nov 2000 09:54:14
Message: <3A0EAF40.709AAF6C@peak.edu.ee>
It should, yes.
Margus Ramst
Date: 12 Nov 2000 11:37:54
Message: <3A0ED597.40992B28@yahoo.com>
> your .ini file.
> case.
Did it for the lights, did it for the switch, still doesn't work...
Anyway, I checked this, it shouldn't work anyway, since the very small sphere
will be seen in the other mirror...
try this:
#declare CameraLocation = <0,1,2>
  location CameraLocation
  look_at <0, 0, -1>
// no light source
plane { <0,0,1>, 0 pigment {rgb <1,1,0>} finish {reflection 1}}
sphere { <0,0,1>, 0.5 pigment {rgb 1} finish {ambient 1}
//bounded_by { sphere { CameraLocation ,.1 } }
remove the comment before the "bounded_by" and you should get the same image, at
least that's what I got... :/  Is there something else missing?
Thanks,
	Simon
