POV-Ray : Newsgroups : povray.advanced-users : No reflection for a specific object? Server Time
18 May 2026 11:16:13 EDT (-0400)
  No reflection for a specific object? (Message 21 to 23 of 23)
Subject: Re: No reflection for a specific object?
Date: 15 Nov 2000 05:48:31
Message: <chrishuff-1B718E.05484415112000@news.povray.org>
In article <3a100021@news.povray.org>, Warp <war### [at] tagpovrayorg>
wrote:
>   I know that although it looks extremely simple, it's very hard to see
> why this works. If you think about it long enough, you'll figure out why
> it works.
What about cameras other than perspective which don't originate from a
single point?
Christopher James Huff
Date: 15 Nov 2000 06:29:20
Message: <3a127390@news.povray.org>
Chris Huff <chr### [at] maccom> wrote:
: What about cameras other than perspective which don't originate from a
: single point?
  May not work. If the rays don't originate form a single point, then the
other method may not work either.
  Also area ligths may cause problems.
  Btw, forgot to mention in my post that you should not transform the object
after the bounding box has been applied (the transformation would move
the bounding box out of the way).
Date: 15 Nov 2000 19:57:35
Message: <3A133134.8EF31B1@peak.edu.ee>
The other method (placing the object around camera/light) should still work, in
most cases.
AFAIK the only projections where the camera origin moves are orthographic and
cylindrical 3 & 4. Orthographic will be a problem since the bounding box around
the camera will have to relatively (as large as the up & right vectors). For
cylindrical projection you can use a very thin cylinder around the camera axis,
so there is little likelyhood of reflected rays hitting it.
Area_lights can have the same problem as orthographic camera, but they generally
fill a smaller area of the sky, so problems are less likely.
Margus Ramst
