POV-Ray : Newsgroups : povray.advanced-users : atmospheric scattering - blue skies Server Time
21 Dec 2025 09:05:30 EST (-0500)
  atmospheric scattering - blue skies (Message 1 to 10 of 10)
Subject: atmospheric scattering - blue skies
Date: 31 Oct 2000 15:31:25
Message: <39ff2c1d@news.povray.org>
Does anyone know of a way to model the sky using media, scattering etc to
create a blue sky? I'm not sure if it's possible. Basically I don't want to
use a sky sphere to mimic the sky, but try and create a 'true' atmosphere
which looks blue because of light scattering, and so I can make a 'sun'
which is way out in the distance, in scale with reality, and shines through
the atmosphere as happens in nature.
Subject: Re: atmospheric scattering - blue skies
Date: 31 Oct 2000 15:37:21
Message: <39FF2D80.BDE761CA@peak.edu.ee>
Wavelength-dependant scattering is not possible in POV (at least not yet). But
you should be able to simulate it well enough with regular scattering (or even
just emitting & absorbing) media, coloured appropriately.
Margus Ramst
Date: 31 Oct 2000 17:32:09
Message: <39ff4869@news.povray.org>
"Margus Ramst" <mar### [at] peakeduee> wrote in message
news:39FF2D80.BDE761CA@peak.edu.ee...
But
even
> Margus Ramst
> Personal e-mail: mar### [at] peakeduee
> TAG (Team Assistance Group) e-mail: mar### [at] tagpovrayorg
Well, I am just trying to simulate it as good as possible. I don't get good
enough results with using a simple sky sphere.
I expected to accomplish my goal with a sphere containing a semi-transparent
pigment (layered with a blue pigment), and then add my clouds, but I just
can't get it to work properly. The reason I want to do this is to try and
model the earth (or any other planet), with all entities their correct size
and relative distance. For example, the earth with an atmosphere surrounding
it, so I can have cloud formations at the correct height, etc. Can I maybe
have a spherical shell ( a sphere with most of its insides removed with CSG
difference, or the inside replaced with my earth) containing cloud media,
and a transparent texture/pigment to "let in the sun"?
Maybe I'm trying to make a mountain out of a mole hill, that's often the
case with pov and I :)
Date: 1 Nov 2000 00:55:57
Message: <39ffb06d@news.povray.org>
janger wrote in message <39ff2c1d@news.povray.org>...
I've been working on modifying POV-Ray to do this.  The (rather buggy)
source code for my first effort is available at
http://www.geocities.com/rengaw03/download/skypov.zip if anyone is willing
to spend the time trying to compile it.  Since something has added a bunch
of extra newlines to various files, I expect it will take about an hour to
get the source code to where it can be compiled.
I'll try to get a bug-free compiled version ready tomorrow, but I can't
guarentee anything.
Mark
Date: 1 Nov 2000 01:14:20
Message: <39FFB45A.F729A606@aol.com>
You'd get better results using a plane for your clouds.  The problem with your
thinking is that you are placing the viewpoint at the center of a sphere.  In
reality we are on the surface of a sphere surrounded by a slightly larger sphere
of air, so the sky appears largely flat.
Just something to consider.
-Mike
Date: 1 Nov 2000 17:34:37
Message: <MPG.146ab8e679379197989684@news.povray.org>
So why not use a very big sphere?
something like sphere{<0,-100000,0>, 100500}
when the camera near the origin.
Lutz-Peter
Date: 1 Nov 2000 19:16:57
Message: <3A00B27B.70B810F5@peak.edu.ee>
I usually create a plane or a large sphere to represent the ground, and a
slightly larger sphere to contain the atmosphere. The second sphere needs to be
hollow of course, in order for the atmospheric media to show up.
By using scattering media or a combination of emitting & absorbing media, you
will also get the natural darkening of the sky towards the zenith, since the
atmosphere is thinnest in that direction (relative to your viewpoint).
Here's a (very) crude example:
// This is the ground
sphere{
  -10000*y,10000
  texture{Whatever}
// The atmosphere
sphere{
  -10000*y,10500
  pigment{rgbf 1}
  interior{
    media{
      emission rgb <.5,.5,1>
      absorption rgb <1,1,.5>
  hollow
Margus Ramst
Date: 1 Nov 2000 21:30:39
Message: <3a00d1cf@news.povray.org>
"Margus Ramst" <mar### [at] peakeduee> wrote...
to
to
atmosphere
through
But
even
There seems to be a misconception here.  POV can do "almost" wavelength
dependent scattering.  The closest thing to wavelength in POV is color.  And
POV can _easily_ do color-dependent scattering.  That is as close as you'll
get until POV supports an arbritary division of the color spectrum, instead
of breaking it up into only three components (i.e. instead of using a
3-component RGB color vector, you might use a 7-component ROYGBIV color
vector).
That said, wavelength-dependent scattering can be simulated quite well using
POV.  It can even be simulates so well that simply moving the sun to the
horizon will produce nice shades of red, orange, and yellow for a sunset.
Different scattering colors can be used to achieve different sunset colors,
such as pinks and purples (this could be used to simulate different
atmospheric conditions, such as humidity and temperature).  Please see
"Scattering media sky" that I just posted in p.b.s-f.  Note that the
original code was created by somebody else, I only tweaked it.
-Nathan
Date: 2 Nov 2000 00:00:56
Message: <3a00f508@news.povray.org>
Thanx for the feedback everyone. I'll give Nathan's example a go and see if
it's what I want. But I'm pretty sure it is what I'm after...
"janger" <d_j### [at] hotmailcom> wrote in message
news:39ff2c1d@news.povray.org...
to
through
Date: 2 Nov 2000 11:28:16
Message: <3a01961f@news.povray.org>
Lutz-Peter Hooge <lpv### [at] gmxde> wrote:
: So why not use a very big sphere?
: something like sphere{<0,-100000,0>, 100500}
: when the camera near the origin.
  You might get some accuracy problems with numbers that are too big.
