POV-Ray : Newsgroups : povray.advanced-users : Length of spline... Server Time
21 Dec 2025 10:47:02 EST (-0500)
  Length of spline... (Message 1 to 10 of 13)
Subject: Length of spline...
Date: 22 Oct 2000 21:51:50
Message: <39f399b6@news.povray.org>
How can I get an exact/closely approximated measure of the distance traveled
along a spline and the total length of it? I am using a cubic_spline in
MegaPOV.
Subject: Re: Length of spline...
Date: 22 Oct 2000 23:08:14
Message: <39F39D85.286CC421@peak.edu.ee>
> MegaPOV.
You could try using Chris Colefax's spline macros instead, I believe they are
capable of finding the (approximate) length of a cubic spline.
Finding the exact length is an exceedingly hairy problem, or so I gather.
Margus Ramst
Date: 22 Oct 2000 23:26:29
Message: <39f3afe5@news.povray.org>
traveled
> MegaPOV.
Due to the maths involved, there is no known way to calculate the exact
length of a cubic spline.  The best method is usually to sum the linear
distances between a number of steps along the spline - obviously, the more
steps, the more accurate the result (at the cost of speed).  In MegaPOV you
should be able to do this quite simply using a while loop (the following
presumes your spline clock ranges from 0 to 1):
   #declare MySpline = spline {cubic_spline ..... }
   #declare Length = 0;
   #declare C = 0; #while (C <= 100)
      #declare P1 = MySpline(C/100);
      #if (C > 0) #declare Length = Length + vlength(P1 - P0); #end
      #declare P0 = P1;
   #declare C = C + 1; #end
Also, a very rough approximation can be calculated if know the bezier hull
points of the spline.  My own Spline Macro file uses a combination of both
methods, so you can return the total length of a spline, return a point at a
specified distance along a spline, or even specify a list of points and a
length, and have the macro tension the spline through the points to fit the
desired length.
Date: 23 Oct 2000 21:37:56
Message: <39f4e7f4@news.povray.org>
OK. Thank you both very much. I will try this code later tonight. I want to
figure the length so I can get my car chase animation working within the
realm of reality. I want to make the car go at specific speeds along the
path. If I don't know how long the path is, I won't know which speed is
appropriate. I think... anyway, thanks.
Date: 25 Oct 2000 03:33:55
Message: <39F68CC8.FA39C490@umh.ac.be>
If you know the exact form of the function (the spline) you
can calculate the length of the spline, this involve a simple integrale.
Actually this is what you do approximately by using straight line
between point.
> traveled
> > MegaPOV.
>       #declare P0 = P1;
> desired length.
Date: 25 Oct 2000 04:56:32
Message: <39f6a040@news.povray.org>
> steps, the more accurate the result (at the cost of speed)...
> between point.
Yes, it seems obvious that you could integrate the spline function to find
the exact length.  But like I said, there is simply no known way *to*
integrate the function.  To create my Spline Macro File I searched and
re-searched the web for the right formulas, and also started from first
principals to derive the functions myself, before attempting (without
success) the necessary integration in MathCAD.  I guess it shows that there
are limits to our knowledge of mathematics....
Date: 25 Oct 2000 16:07:23
Message: <39f73d7b$1@news.povray.org>
Isn't it a propertie of a cubic-Spline, to be 3-Times
differentiable and also (at every-Point) integratable ???
An Cubic Spline consists of several cubic-functions (every going
through 4 Points) and having at every Point the same
2nd-derivations ....
So there MUST be a way to integrate them ...
or am I completely wrong ???
I just though to have heard this last semester in the
"aproximation-theorie"-lecture ...
I just fear you can not use the pov-Spline to do this for you,
but you have to calculate the Spline yourself, with all its
matrices and so on ...
You know what I mean ???
Chris Colefax <chr### [at] tagpovrayorg> schrieb in im
Newsbeitrag: 39f6a040@news.povray.org...
the exact
the linear
obviously, the more
integrale.
line
> > between point.
function to find
way *to*
searched and
from first
(without
shows that there
Date: 25 Oct 2000 19:35:09
Message: <39F797F6.B9B4C593@ibm.net>
Exact length of a cubic f(x) = a*x^3 + b*x^2 + c*x + d:
http://www.eng.uwaterloo.ca/~ajclinto/test.html
assuming you have x=0 and x=1 as the bounds of the segment (and maybe a=1) it
would become SLIGHTly simpler, but I still doubt whether there would be any
practical use for this mess.
Andrew C
> MegaPOV.
Date: 26 Oct 2000 08:13:37
Message: <39F82026.9B461477@reading.ac.uk>
Hi Andrew,
This is the length of a simple parametric spline where a, b, c and d are
scalars, yes?
The problem is that it would usually be used to produce a spline in 3d,
so a, b, c and d would be 3-component vectors. This would probably add a
whole new level of complexity, something like
f_x := a_x * t^3 + b_x * t^2 + c_x * t + d_x ;
f_y := a_y * t^3 + ... ;
f_z := ... ;
int(sqrt(diff(f_x,t)^2 + diff(f_y,t)^2 + diff(f_z,t)^2),t) ;
Try feeding that to Maple and see if it chokes :-)
Bye for now,
	Mike Andrews.
> Andrew C
> > MegaPOV.
Date: 26 Oct 2000 15:43:25
Message: <39F8B320.D72FBFBB@ibm.net>
Michael,
Ahh, I was thinking of this, but thought that maybe one could take the magnitude of
the vector returned by that (terribly ugly) formula to get the distance traveled.  I
understand how this is done with vectors now (there is a good page at
http://iq.orst.edu/mathsg/vcalc/arc/arc.html)
Thanks for clarifying
Andrew C
Michael Andrews wrote:
> Hi Andrew,
> scalars, yes?
> f_z := ... ;
> Bye for now,
>         Mike Andrews.
> > Andrew C
> > > MegaPOV.
