POV-Ray : Newsgroups : povray.advanced-users : Length of spline... Server Time
15 Jun 2026 16:47:39 EDT (-0400)
  Length of spline... (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Length of spline...
Date: 23 Oct 2000 21:37:56
Message: <39f4e7f4@news.povray.org>
OK. Thank you both very much. I will try this code later tonight. I want to
figure the length so I can get my car chase animation working within the
realm of reality. I want to make the car go at specific speeds along the
path. If I don't know how long the path is, I won't know which speed is
appropriate. I think... anyway, thanks.
Date: 25 Oct 2000 03:33:55
Message: <39F68CC8.FA39C490@umh.ac.be>
If you know the exact form of the function (the spline) you
can calculate the length of the spline, this involve a simple integrale.
Actually this is what you do approximately by using straight line
between point.
> Tony[B] <ben### [at] panamac-comnet> wrote:
> > How can I get an exact/closely approximated measure of the distance
> traveled
> > along a spline and the total length of it? I am using a cubic_spline in
> > MegaPOV.
> Due to the maths involved, there is no known way to calculate the exact
> length of a cubic spline.  The best method is usually to sum the linear
> distances between a number of steps along the spline - obviously, the more
> steps, the more accurate the result (at the cost of speed).  In MegaPOV you
> should be able to do this quite simply using a while loop (the following
> presumes your spline clock ranges from 0 to 1):
>    #declare MySpline = spline {cubic_spline ..... }
>    #declare Length = 0;
>    #declare C = 0; #while (C <= 100)
>       #declare P1 = MySpline(C/100);
>       #if (C > 0) #declare Length = Length + vlength(P1 - P0); #end
>       #declare P0 = P1;
>    #declare C = C + 1; #end
> Also, a very rough approximation can be calculated if know the bezier hull
> points of the spline.  My own Spline Macro file uses a combination of both
> methods, so you can return the total length of a spline, return a point at a
> specified distance along a spline, or even specify a list of points and a
> length, and have the macro tension the spline through the points to fit the
> desired length.
Date: 25 Oct 2000 04:56:32
Message: <39f6a040@news.povray.org>
> steps, the more accurate the result (at the cost of speed)...
> between point.
Yes, it seems obvious that you could integrate the spline function to find
the exact length.  But like I said, there is simply no known way *to*
integrate the function.  To create my Spline Macro File I searched and
re-searched the web for the right formulas, and also started from first
principals to derive the functions myself, before attempting (without
success) the necessary integration in MathCAD.  I guess it shows that there
are limits to our knowledge of mathematics....
Date: 25 Oct 2000 16:07:23
Message: <39f73d7b$1@news.povray.org>
Isn't it a propertie of a cubic-Spline, to be 3-Times
differentiable and also (at every-Point) integratable ???
An Cubic Spline consists of several cubic-functions (every going
through 4 Points) and having at every Point the same
2nd-derivations ....
So there MUST be a way to integrate them ...
or am I completely wrong ???
I just though to have heard this last semester in the
"aproximation-theorie"-lecture ...
I just fear you can not use the pov-Spline to do this for you,
but you have to calculate the Spline yourself, with all its
matrices and so on ...
You know what I mean ???
Chris Colefax <chr### [at] tagpovrayorg> schrieb in im
Newsbeitrag: 39f6a040@news.povray.org...
the exact
the linear
obviously, the more
integrale.
line
> > between point.
function to find
way *to*
searched and
from first
(without
shows that there
Date: 25 Oct 2000 19:35:09
Message: <39F797F6.B9B4C593@ibm.net>
Exact length of a cubic f(x) = a*x^3 + b*x^2 + c*x + d:
http://www.eng.uwaterloo.ca/~ajclinto/test.html
assuming you have x=0 and x=1 as the bounds of the segment (and maybe a=1) it
would become SLIGHTly simpler, but I still doubt whether there would be any
practical use for this mess.
Andrew C
"Tony[B]" wrote:
> How can I get an exact/closely approximated measure of the distance traveled
> MegaPOV.
Date: 26 Oct 2000 08:13:37
Message: <39F82026.9B461477@reading.ac.uk>
Hi Andrew,
This is the length of a simple parametric spline where a, b, c and d are
scalars, yes?
The problem is that it would usually be used to produce a spline in 3d,
so a, b, c and d would be 3-component vectors. This would probably add a
whole new level of complexity, something like
f_x := a_x * t^3 + b_x * t^2 + c_x * t + d_x ;
f_y := a_y * t^3 + ... ;
f_z := ... ;
int(sqrt(diff(f_x,t)^2 + diff(f_y,t)^2 + diff(f_z,t)^2),t) ;
Try feeding that to Maple and see if it chokes :-)
Bye for now,
	Mike Andrews.
> Andrew C
> > MegaPOV.
Date: 26 Oct 2000 15:43:25
Message: <39F8B320.D72FBFBB@ibm.net>
Michael,
Ahh, I was thinking of this, but thought that maybe one could take the magnitude of
the vector returned by that (terribly ugly) formula to get the distance traveled.  I
understand how this is done with vectors now (there is a good page at
http://iq.orst.edu/mathsg/vcalc/arc/arc.html)
Thanks for clarifying
Andrew C
Michael Andrews wrote:
> Hi Andrew,
> scalars, yes?
> f_z := ... ;
> Bye for now,
>         Mike Andrews.
> > Andrew C
> > > MegaPOV.
Date: 27 Oct 2000 03:06:58
Message: <39F92976.1E395160@umh.ac.be>
Could you give me the form of the function (this mathematical form)?
Thanks,
Fabian.
> > between point.
Date: 27 Oct 2000 11:02:59
Message: <39F9995B.6457BAE8@reading.ac.uk>
Hi Andrew,
OK, with a little thought the problem reduces down to finding the
integral of the square-root of a fourth order polynomial, ie:
int(sqrt(A*t^4 + B*t^3 + C*t^2 + D*t + E), t);
where A to E are scalars derived from the coefficients of the x, y and z
cubic functions. So if you can get an analytic integration of this
please make it known ... I couldn't figure it out ...
Bye for now,
	Mike Andrews.
> Michael,
> Andrew C
> > Hi Andrew,
> > scalars, yes?
> > f_z := ... ;
> > Bye for now,
> >         Mike Andrews.
> > > Andrew C
> > > > MegaPOV.
Date: 27 Oct 2000 20:52:02
Message: <39fa2332@news.povray.org>
Here is the way I derived the basic cubic spline function, the constraints
being the two end-points and two end-tangents of the curve segment (known as
a Hermite curve).  The various cubic interpolating splines (e.g.
Catmull-Rom, cardinal, Bezier, Kochanek-Bartels/TCB) can be easily converted
to this simple definition, where p(t) returns the posiition (p) at the time
(t, with 0 <= t <= 1).
Let p(t) be cubic polynomial => p(t) = a*t^3 + b*t^2 + c*t + d
Let end-points be P0 and P1 => p(0) = P0, p(1) = P1
Let end-tangents be T0 and T1 => p'(0) = T0, p'(1) = T1
 => P0 = d
    P1 = a + b + c + d
    T0 = c
    T1 = 3*a + 2*b + c
Solve for a, b, c, d:
      a = 2*(P0 - P1) + T0 + T1
      b = 3*(P1 - P0) - 2*T0 - T1
      c = T0
      d = P0
Subsitute a, b, c, d into p(t), giving general Hermite curve:
   => p(t) = (2*(P0 - P1) + T0 + T1)*t^3  +  (3*(P1 - P0) - 2*T0 - T1)*t^2
+  T0*t  +  P0
           = T0 * (t^3 - 2*t^2 + t)  +  P0*(2*t^3 - 3*t^2 + 1)  +
 P1*(3*t^2 - 2*t^3)  +  T1*(t^3 - t^2)
