POV-Ray : Newsgroups : povray.advanced-users : Array irritation. Server Time
18 May 2026 07:37:13 EDT (-0400)
  Array irritation. (Message 18 to 27 of 27)
Subject: Re: Array irritation.
Date: 19 Oct 2000 04:07:07
Message: <39eeabab@news.povray.org>
Thorsten Froehlich <tho### [at] trfde> wrote:
: Just curious, which architecture were you compiling for here?
  Sparc.
  The assembler instruction I wrote in my article was fictitious
(pseudo-assembler). It's not Sparc assembler.
: What is this program doing?
  No idea.
  A wild guess: Either a multiplication or a division?
Date: 19 Oct 2000 09:14:22
Message: <slrn8utstf.2pq.ron.parker@fwi.com>
>: Maybe it is optimising, but in a different way than you expect. On the one
>: hand "i" might be needed somewhere else and inc i could only work on
>: register variables (sorry, I don't know x86 assembler too well).
>  The 'inc' instruction works also directly with memory locations
>(ie. variables) but is slower than an 'inc' on a register. But of course
>loading the variable first on a register, incrementing the register and
>then storing the register on the variable is not faster (it's actually slower,
>I think).
It might pipeline better.
>  And besides, if it's not optimizing (as the original poster said), it
>should generate the simplest code, not the fastest.
If it's not optimizing, it's not checking to see whether the result of
the calculation is used, so it always computes it.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 19 Oct 2000 09:22:29
Message: <39eef594@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
: It might pipeline better.
  AFAIK instructions that handle the same register can't be executed in
different pipelines at the same time (at least this in a Pentium).
Date: 19 Oct 2000 09:28:20
Message: <tpttusgkh5soek049ibglpo603576eh6un@4ax.com>
Hi Warp, you recently wrote in povray.advanced-users:
>   Why would he do that?
Because he found that float was not precise enough?
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 19 Oct 2000 09:57:32
Message: <slrn8utvee.2rv.ron.parker@fwi.com>
That's probably true, but a load-modify-store sequence might be more easily
run in parallel with another such sequence.  Of course, if that's the case,
they would have microcoded inc as such a sequence.  I suspect the real
reason your compiler built it that way is the second reason I gave.
Date: 19 Oct 2000 10:59:44
Message: <39ef0c60$1@news.povray.org>
In article <39eeabab@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
>   Sparc.
OK.  I was asking because I was interested if Sparc supports rotations in
hardware.
>   No idea.
Good guess, it is a multiplication.  It plays around with bit patterns and
overflows to be able to accomplish the result in only 4 registers.
     Thorsten
PS: Division (recursive) could look like this ...
 addi $3, $3, 4
 addi $1, $1, 47
 sw   $1, 0($0)
 sw   $0, 1($3)
 addi $1, $0, 10
 sw   $1, 2($3)
 addi $1, $0, 1
 sw   $1, 3($3)
 jal  $1, sub
 lw   $1, 0($3)
 lw   $2, 1($3)
 lw   $2, 0($2)
wait:
 j wait
sub:
 sw   $1, 4($3)
 lw   $1, 2($3)
 subi $2, $0, 1
 beq  $1, $0, ret
 lw   $2, 1($3)
 lw   $2, 0($2)
 slt  $2, $2, $1
 subi $2, $2, 1
 beq  $2, $0, ret
 lw   $2, 1($3)
 sw   $2, 6($3)
 lw   $2, 2($3)
 sll1 $2, $2
 sw   $2, 7($3)
 lw   $2, 3($3)
 sll1 $2, $2
 sw   $2, 8($3)
 addi $3, $3, 5
 jal  $1, sub
 subi $3, $3, 5
 lw   $2, 5($3)
 sw   $2, 0($3)
 lw   $1, 2($3)
 lw   $2, 1($3)
 lw   $2, 0($2)
 slt  $2, $2, $1
 bne  $2, $0, ret_now
 lw   $2, 1($3)
 lw   $2, 0($2)
 sub  $2, $2, $1
 lw   $1, 1($3)
 sw   $2, 0($1)
 lw   $2, 0($3)
 lw   $1, 3($3)
 or   $2, $2, $1
ret:
 sw  $2, 0($3)
ret_now:
 lw  $1, 4($3)
 jr $1
// calculates x / y
int sub(int *x, int y, int cnt);
int main()
 int x = 47;
 cout << sub(&x, 4, 1) << "\n";
 cout << x << "\n";
 return 0;
 int temp;
 if(y == 0)
  return -1;
 if(*x < y)
  return 0;
 temp = sub(x, y << 1, cnt << 1);
 if(*x >= y)
  *x -= y;
  temp |= cnt;
 return temp;
Date: 19 Oct 2000 15:21:28
Message: <39ef49b8@news.povray.org>
First my apologies to the group for not responding in two days. I have been
working and not much else. I now know what 1,200mg of caffine does to the
human body. : (
I discovered my problem when I read Michael Andrews post, telling me that
the arrray is not as one would expect. I thought having an array of [N][N]
would mean I had an array of that precise size, and not [N-1][N-1].
That was my entire problem. Povray did not like the fact that I was calling
the array with the values it was defined with. My loops went from 3 to 1 and
10 to 1, not 2 to 0 and 9 to 0.
My thanks to the group for your help.
ian
Michael Andrews <M.C### [at] readingacuk> wrote in message
news:39EC99EF.283EA738@reading.ac.uk...
Date: 22 Oct 2000 10:22:17
Message: <39f2f818@news.povray.org>
Lutz Kretzschmar <lut### [at] stmuccom> wrote:
:>   Why would he do that?
: Because he found that float was not precise enough?
  Wouldn't a
typedef double DBL;
be better and easier to do?
Date: 24 Oct 2000 04:26:42
Message: <p5d9vs0894vnrsndusf589uk7muts9j6rh@4ax.com>
> typedef double DBL;
Yes, it would, I guess. Your guess is as good as mine about why
someone would write the example you quoted in the first place, you
certainly wouldn't find a construct like that in my code <g>......
- Lutz
Date: 24 Oct 2000 04:36:54
Message: <39f54a26@news.povray.org>
For things like this, look at:
http://web2.airmail.net/~sjbaker1/software/horrors.html
