POV-Ray : Newsgroups : povray.advanced-users : Array irritation. Server Time
18 May 2026 07:37:13 EDT (-0400)
  Array irritation. (Message 11 to 20 of 27)
<<< Previous 10 Messages Goto Latest 10 Messages Next 7 Messages >>>
Subject: Re: Array irritation.
Date: 18 Oct 2000 11:30:24
Message: <39edc20f@news.povray.org>
Lutz Kretzschmar <lut### [at] stmuccom> wrote:
: Then he did a global search and replace and replaced DBL with double?
  Why would he do that?
Date: 18 Oct 2000 18:52:15
Message: <39EE26FE.15BB84D4@faricy.net>
David Wilkinson wrote:
> You're right David, concatenation is  absolutely redundant, although it does no
> harm in this instance.  It's a good example of how bugs arise when you are
> re-using code and don't think it through carefully enough :-)
Hmm, sounds like MS...
Date: 18 Oct 2000 22:34:17
Message: <39EE5D5E.CCAB2069@hotmail.com>
Warp wrote:
> Pabs <pab### [at] hotmailcom> wrote:
> : Maybe they thought that the compiler would insert instructions to convert an
> : int to a double at runtime, unlikely though it is?
>   It's just incredible how the compiler can figure out that what you are
> actually trying to do is a rotation and compiles the rather complex command
> into one rotation assembler instruction (instead of two shifts and an or).
Ever seen the sh*t f**cking code msvc produces with no optimisations for things
like the following?
++i;
the code is something like (I'm not to proficient in assembly so don't tease)
mov eax, i
add eax, 1
mov i, eax
The side effect is what we want since the value returned by the operator is just
discarded
What a waste of clock cycles - even I could tell you that
inc i
or something similar would achieve the desired result
Just because its compiled in debug mode doesn't mean I want the code to be bloated
like a bl**dy f**cking pig.
Grrrrrrrrrrrr!
Death to M$VC & M$ - NOW
Bye
Pabs
Date: 19 Oct 2000 01:28:45
Message: <39ee868d$1@news.povray.org>
In article <39ed87d0@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
> (supposing that 'var' is an unsigned int of size 32 bits)
> to this (in assembler):
Ah, so you are learning assembler (variants) now...
> rol [Variable], 5
> (ie. "rotate the value [Variable] to the left 5 positions").
Just curious, which architecture were you compiling for here?
>   In C there's no operation to rotate values like in most assemblers so you
> have to do it with two shifts and one or.
Yes, and there are many more tricks:
main:
 addi $0, $0, 10
 addi $1, $1, 15
 andi $2, $2, 0
 andi $3, $3, 0
for:
 andi $2, $2, 0
 beq  $0, $2, ret
 srl1 $0, $0
 sll1 $1, $1
 andi $2, $0, 1
 subi $2, $2, 1
 not  $2, $2
 and  $2, $1, $2
 add  $3, $3, $2
 j    for
ret:
 j    ret
Assume j is a unconditional jump, and srl1/sll1 are logical right/left
shifts by one bit.  Further assume all values are unsigned 8 bit ints.  $0
to $3 are registers (MIPS assembly notation), your input is in $0 and $1,
and the result is in $2.
What is this program doing?
   Thorsten
e-mail: tho### [at] trfde
Date: 19 Oct 2000 01:41:23
Message: <39ee8983$1@news.povray.org>
In article <39EE5D5E.CCAB2069@hotmail.com> , Pabs <pab### [at] hotmailcom>
> things like the following?
> ++i;
Maybe it is optimising, but in a different way than you expect. On the one
hand "i" might be needed somewhere else and inc i could only work on
register variables (sorry, I don't know x86 assembler too well).  This doing
either would give the same performance.  Especially if "i" is stored in a
rather complicated place or only used once, or a global variable, or a
million other things.
Or it might well be that the sequence it generates executes faster on modern
processors that translate your code to internal RISC-like instructions (like
P6 and later do).  Why come to this conclusion?
Well, what you see is a load/store (i.e. most RISC processors) way of
handling the problem.  Basically a load/store architecture based processor
will not have complex operations that work on memory and data at the same
time.  Everything first has to be loaded into a register, then it will be
processed and then placed back in memory.  This is usually more efficient
because these processors have much larger register files, 32 or even 64
registers compared to the 8 registers a x86 has.
    Thorsten
Date: 19 Oct 2000 01:49:56
Message: <39ee8b84$1@news.povray.org>
In article <39ee868d$1@news.povray.org> , "Thorsten Froehlich"
Correction: the result is in $3 or cousre.  And btw, you may assume all
registers are inited to 0.
Date: 19 Oct 2000 03:59:13
Message: <39eea9d1@news.povray.org>
Thorsten Froehlich <tho### [at] trfde> wrote:
: Maybe it is optimising, but in a different way than you expect. On the one
: hand "i" might be needed somewhere else and inc i could only work on
: register variables (sorry, I don't know x86 assembler too well).
  The 'inc' instruction works also directly with memory locations
(ie. variables) but is slower than an 'inc' on a register. But of course
loading the variable first on a register, incrementing the register and
then storing the register on the variable is not faster (it's actually slower,
I think).
  And besides, if it's not optimizing (as the original poster said), it
should generate the simplest code, not the fastest.
Date: 19 Oct 2000 04:07:07
Message: <39eeabab@news.povray.org>
: Just curious, which architecture were you compiling for here?
  Sparc.
  The assembler instruction I wrote in my article was fictitious
(pseudo-assembler). It's not Sparc assembler.
: What is this program doing?
  No idea.
  A wild guess: Either a multiplication or a division?
Date: 19 Oct 2000 09:14:22
Message: <slrn8utstf.2pq.ron.parker@fwi.com>
>I think).
It might pipeline better.
If it's not optimizing, it's not checking to see whether the result of
the calculation is used, so it always computes it.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 19 Oct 2000 09:22:29
Message: <39eef594@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
: It might pipeline better.
  AFAIK instructions that handle the same register can't be executed in
different pipelines at the same time (at least this in a Pentium).
