POV-Ray : Newsgroups : povray.advanced-users : Isosurface function: rippled box Server Time
13 Jan 2025 11:46:55 EST (-0500)
  Isosurface function: rippled box (Message 1 to 6 of 6)
Subject: Isosurface function: rippled box
Date: 12 Oct 2000 14:00:29
Message: <39e5fc3d@news.povray.org>
Hello,
I am looking for an isosurface function to make a box with ripples like one
would find on a large pool of water. The ripples need to be not of the type
one would find after throwing a rock in, but like those found on a still
wind blown lake.
I wish for this to be subtracted from my pool of water, as I dislike normals
when true displacement is available.
I attempt this pedantic level of reality as all others have been covered
within current ability; Media falloff in the water with conservation of
energy, photons and radiosity, etc..
ian
Subject: Re: Isosurface function: rippled box
Date: 12 Oct 2000 14:35:28
Message: <39E60471.59CED5E8@schunter.etc.tu-bs.de>
ian wrote:
> Hello,
> wind blown lake.
> ian
You could try any pigment function with a pattern like you would use for a
normal statement.  Furthermore you could try a Ridged Multifractal function
which can give very realistic water.
Check out the entries in the last IRTC, there are a lot using isosurfaces for
realistic water.
Date: 12 Oct 2000 16:04:31
Message: <chrishuff-3B1D6C.15070712102000@news.povray.org>
In article <39e5fc3d@news.povray.org>, "ian" <ian### [at] aolcom>
> normals when true displacement is available.
I think a better idea would be to make the water itself an
isosurface...just use a plane function and displace it with a pigment
function, maybe a wrinkles pigment.
#declare WaterFunc = function {pigment {...}}
isosurface {
    function {y - WaterFunc(x,y,z)}
You could also try a height_field, though the fact that it is made of
triangles might give worse results, and the memory usage would be worse.
Christopher James Huff
Date: 13 Oct 2000 08:37:38
Message: <39e70212@news.povray.org>
The problem is that the pool of water is not evenly shaped, and needs to
refract light properly. It is a set of loop-stacked cylinders inside a
slightly larger vessel of the same shape. It is currently solid with a media
interior.
Would zeroing the effect of the current media container object in regards to
reflection and refraction, then placing said plane in the proper position
produce the described effect?
I do not see that happening as easily as a CSG from my current
configuration, but I am known for missing blatantly obvious things from time
to time..
thanks,
ian
Chris Huff wrote in message ...
Date: 13 Oct 2000 10:29:44
Message: <chrishuff-02AF16.09322213102000@news.povray.org>
In article <39e70212@news.povray.org>, "ian" <ian### [at] aolcom>
> to refract light properly. It is a set of loop-stacked cylinders
> inside a slightly larger vessel of the same shape. It is currently
> solid with a media interior.
What I meant was that you don't need a box function for this, you can
use a simpler plane function(you can't get much simpler than "y") in the
CSG, because only the top surface has waves. Perhaps I misunderstood
what you were asking about, but I thought you wanted a box function with
a displacement.
(I just had an interesting idea: a spherical or toroidal swimming pool,
in a large room aboard a spacecraft, held in place in the center by air
jets and magnetic fields, but otherwise free of support. What do you
think?)
Date: 13 Oct 2000 10:36:24
Message: <39E71DE8.4E373415@schunter.etc.tu-bs.de>
> think?)
I'm just not sure whether i would like to swim in that pool ... :-)
The whole idea reminds me somehow of the movie 'The Abyss'.
