POV-Ray : Newsgroups : povray.advanced-users : Macro Problem Server Time
16 Mar 2026 10:38:55 EDT (-0400)
  Macro Problem (Message 1 to 3 of 3)
Subject: Macro Problem
Date: 2 Oct 2000 05:21:29
Message: <39d85399@news.povray.org>
Can somebody tell me how to get the following concept to work...
macro ShapeMacro(Nums,Data)
       prism{ linear_sweep linear_spline 0,70,Nums,Data texture
{pigment{color Red}}}
# object {ShapeMacro (4),(<2107,1480>,<2105,1481>,<2104,1480>,<2107,1480> )}
The problem occurs in trying to split the number of sides and the data
coordinates.
Is there a way around this ?
I have a very long list of objects that will be generated by an outside
source and need to use a macro format rather than building each element
separately.
Thanks
David
Subject: Re: Macro Problem
Date: 2 Oct 2000 07:22:01
Message: <8FC185E05seed7@204.213.191.228>
>       #end
>coordinates.
Using arrays may be an option:
#macro ShapeMacro(DataArray)
   #local Num=dimension_size(DataArray,1)
   prism {
     linear_sweep
     linear_spline
     0,1,
     Num
     #local i=0;
     #while (i<Num)
        DataArr[i]
        #local i=i+1;
     pigment{color rgb 1}
#declare DataArr=array [5]{
   <0,0>,
   <0,1>,
   <1,1>,
   <1,0>,
   <0,0>
object {ShapeMacro(DataArr)}
>separately.
If the outside source is an appropriatly formatted textfile you can read
it with povray, within the prism statement
Ingo
Date: 2 Oct 2000 07:54:03
Message: <ndogtsk8snr5qe302h6qre7da958p056dj@4ax.com>
On Mon, 2 Oct 2000 11:19:24 +0200, "David Vincent-Jones" <geo### [at] galaxynetcom>
>       #end
>coordinates.
I would do it by using arrays of vectors. If you do it this way you can let the
macro decide how many points you have in the prism.
I have posted an example in p.b.s-f
dav### [at] hamiltonitecom
http://hamiltonite.com/
